Results 1 to 7 of 7
Thread: Questions about my new MigMax 215
    Aug 2020
    So I got the MigMax and I gave it a whirl last night. Had a few questions.
    - My test steel is 1/8th inch steel from Home Depot. When I look at the manual settings it recommends E4 manual setting for 220V and 0.30 wire.
    Why is the auto setting for 1/8th inch so much higher in terms of voltage? The welds I tried in manual seemed too cold and the ones in auto seemed too hot. Canít make sense of it.
    - When in auto setting do I set the wire speed at all or is that bypassed?
    HFs manuals are not for the uninitiated
    CT
    Re: Questions about my new MigMax 215
    In the auto mode, ignore your wire speed dial (it is all bypassed). If the welds are too hot, adjust the left knob down to get less heat input. In manual mode, wire speed represents your amps/heat input, voltage controls the weld bead profile (tall, ropey, convex on one end of the spectrum, flat or concave on the other end of the spectrum.). This video will help you set your machine in manual mode.
  3. Likes kyngfish liked this post
    Aug 2020
    Thanks!
    One more question. As the metal gets hotter do I need to turn the voltage down - if Iím welding the same piece for a longer time
    CT
    Potentially yes. Well either voltage or more likely wire feed speed. But unless you are welding a small piece of metal, that isn't too likely.
  6. #5
    Aug 2020
    Test welds. So yeah.
  7. #6
    CT
    If you are just practicing on coupons, you could always put them in a bucket of water to quench them. Not a normally recommended practice but for test coupons it won't hurt anything. That way you don't need to keep fiddling with your settings. I dunk them every 2-3 beads.
  8. Likes Broccoli1 liked this post
  9. #7
    Los Angeles
    You really wont need to adjust the settings during welding as you would/should not be making such a long weld.
    On a real project you will make it a banana in a second if you don't move around the piece.
    https://m.lincolnelectric.com/es-es/...on-detail.aspx
    When I was learning I just moved on to a separate test piece and let the first one cool down.
    MM211 (Sold)
    Klutch 120v Plasma cutter
  10. Likes wmgeorge liked this post
Page generated in 1,624,262,158.36977 seconds with 12 queries
