Results 1 to 25 of 37
Thread: Antique homebrew HOBART MR-300 with a flathead 6
    Jul 2011
    Saskatchewan, Canada, (right above North Dakota and Montana)
    Hobart 300 welder with a flathead 6, home brew combo! Coming home soon! Worst case scenario she's a parts machine.
    Was welding when parked around 20 years ago.
  2. Likes ronsii liked this post
  3. #2
    Re: Antique homebrew HOBART MR-300 with a flathead 6
    Quote Originally Posted by MilitiaMetals View Post
    Looks great!!!! a little paint and charge the battery she'll be purrin' like a kitten
    Jul 2011
    LOL just realized the fan-shroud is made from a piece of culvert!
  5. Likes ronsii, N2 Welding liked this post
  6. #4
    LOL, lots of repurposed parts on there... lead spool, gas tank...which is probably full of water from the plug
  7. #5
    I think replace the engine so find parts.
    Looks a great welder
    I only seen that one in catalogs
  8. #6
    Mount Tabor VT
    Looks like Chrysler industrial engine. If it is, there are four choices:
    216 was used in WWII vintage Dodge military trucks.
    230 was used in the Dodge Power wagon introduced in 1945, used till 1960. It was prone to cracked block & head gasket fails as first two & last two cylinders were too close.
    236 was used in many welders, air compressors, and low production farm tractors.
    251 was in later Power Wagons.
    236 & 251 were two inches longer making room for more iron between 1-2 & 5-6 bores.
    Parts are still available. I overhauled a 236 years ago stuck from sitting, and had a 230 rebuilt fully later. My block was cracked. I eventually found a rebuildable block in a cement mixer. It now powers my Power Wagon.
  9. Likes MinnesotaDave liked this post
  10. #7
    Jul 2011
    I'm thinking a future revival custom with a V8 lol
  12. #8
    Oh yeah... Small block Chevy, fake blower with a set of Zoomie pipes.
  14. #9
    Flat head Ford V-8. My old Hobart homebuilt had a Chrysler IND 251. Had to steal an updraft manifold off an old combine and make a U shaped adaptor to fit the updraft carb but it worked good. One of theose things I should ahve taken some pics. of. Those old Hobarts were good welders.
  15. #10
    Jul 2011
    Fake? If I went to all that trouble of mounting a blower it would be a real one.
  16. Likes ronsii, 12V71 liked this post
  17. #11
    Even better
    Had a buddy at an exhaust shop that built a Buick heat racer for the demolition derby years back that built his own vertical zoomies with 8 individual tiny glasspacks, It sounded pretty good... To me anyway.
  18. Likes ronsii liked this post
  19. #12
    Apr 2010
    MilitiaMetals
    . . . Coming home soon! Worst case scenario she's a parts
    machine. Was welding when parked around 20 years ago.
    Great photo quality - Pls post more pics - when you, 'get it out
    of the weeds'.
    This a high-example of deep-farm Canada [ana?]. Think, of all
    the work [someones] Granddad did with this machine, to save
    money, in the struggle to pay off the Wheat Ranch.
    If this were 'my trophy' - I would strive to make the engine and
    welder cooperate [make a spark]. Do nothing to the externals,
    with the exception: of a period [farmer] gage console, and show
    at vintage farm equipment events . . .
    hth
    Opus
    ps -
    'Hobart the Welder' - may be solid with Mud Dabber Condos - if
    this is the case - still show it, as is, without 'Spark' . . .
  20. Likes MickOz liked this post
  21. #13
    Jul 2011
    MilitiaMetals
    of the weeds'.
    hth
    Opus
    ps -
    Now you've inspired me to leave it as is!
  22. Likes 12V71 liked this post
  23. #14
    Sebeka and Bemidji MN
    Here's how my brain processes your pics.
    That looks awful....I think I can save it
    Syncro 350
  24. Likes 12V71, ronsii, CarterKraft, 12345678910 liked this post
  25. #15
    Jul 2011
    My thoughts exactly! Makes me also think about the stories it could tell if it could talk.
  26. Likes ronsii, 12345678910 liked this post
  27. #16
    Jul 2011
    On the way home.
  28. #17
    Jul 2011
  29. Likes N2 Welding, ronsii liked this post
  30. #18
    Jul 2011
    Engine is 1946-1948 Dodge 230 c.i. from a car
  31. #19
    Mount Tabor VT
    Worst case scenario! I went 230 to keep my truck correct. I console myself that it isn't numbers matching, many got replacement blocks under warranty. My truck was under 30,000 when it received its third engine.
  32. Likes ronsii liked this post
  33. #20
    May 2012
    Ontario, Canada
    On the way home.
    Did the tires hold air with no work ?
    Just getting it out of the weeds it's a hundred times less pitiful
  34. #21
    May 2012
    Ontario, Canada
    The stencilling in the frame says Rumely ?
    If that's related to Rumely tractors, that's pretty cool too.
    I'd look at keeping that instead of paintin g over it
    http://mbagmuseum.ca/artifact/rumely-oil-pull-model-s/
  35. #22
    Mount Tabor VT
    Quote Originally Posted by 12345678910 View Post
    I thought the same thought. The frame is the same channel as Rumley tractor, but nobody would cut up a Rumley tractor for this purpose...........would they?
    You know, I think they did!
  36. #23
    Jul 2011
    I literally just hooked up and left, never put any air in, 12 mile trip home.
  37. #24
    Jul 2011
    ** Engine is 1946-1948 Dodge 230 c.i. from a car.
    ** Frame is from a 1931 or older Advance-Rumley Oil Pull tractor
    ** Radiator is from a 1949-1950 Oldsmobile
    I won't paint anything.
    Will update details as I research it more.
  38. #25
    Jul 2011
    Lol they definitely did......dang hillbillies! I can say that cuz I are a hillbilly lol
  39. Likes ronsii liked this post
Page generated in 1,624,245,849.43940 seconds with 13 queries
