Page 1 of 5 123 ... LastLast
Results 1 to 25 of 108
Thread: How cheap can you go??
    Jan 2005
    I am about to find out. Not ebay China cheap, but from a real store, but still China made.. I have this thing about getting a new sub-$100 stick welder that works. Last one was $129.99, and a real 3 year warranty..Worked very well too..Sold it to my friend, so moving the bar down even farther..Just want something cheap to throw into the truck/car Just don't want to do that with my little Sanrex PeeWee. Those were about $500.00 back in the day twenty years ago..(120 volt only)
    Duty-cycle is not too bad at 40% @ 75 Amp
    Coupon code (271577) brings it to $79.99 to my door.. (back ordered till next month)
    https://www.northerntool.com/shop/to...3033_200833033
    Esab/Lorch ET-220i
    Esab 160i caddy
    Thermal Pee-Wee 85s
    Thermal Drag-gun 35C
    INE 1500
    Klutch 140i
  2. Likes Kevin_Essiambre, machineart liked this post
  3. #2
    Dec 2015
    Western New York State, USA
    Re: How cheap can you go??
    Chinese welding store from 20 years ago. even then smaller welding machines are popular for doing stainless handrail and window bars and balcony railings, with a connected to tig torch scratch start. garage door street level shops often welding stuff on the sidewalk. carry back in at end of day
    Jan 2005
    I don't think I want my shop to look like that one above.. I do have one more cheaper 120 volt China unit,just for beating around outside. It's really powerful for a 120 volt unit flux-core unit but the Valve in torch design for gas use was like a 20 pound trigger pull.. This one cost me more then a small HF Ti. 125 or Century FC-90 machine.($260) Worth it for being able to run 10 pound spools, and it has a real handle on top..3 year warranty is another advantage. I would of just bought the little China made Hobart, but it's a transformer unit, and weighs a ton.. Had a better gun design then the Klutch, but not the advantage of the inverter of the one built in the Klutch unit.Sweet welder now..
    The work lead, and torch lead was very short,and just a POS mig gun.. I looked through my spare parts bin, and came up with a nice upgrade.I also added female dinse for a longer work lead. and better ground clamp. Then took a 15 ft Tweco Mini Mig gun, and converted it to a flux-core only gun. Just cut 5 ft off the end, wrapped the exposed copper wire in a shield,put the liner end into the feeder like the factory job. Then hooked up the trigger wire to the board inside.. It can be converted back to factory in case of a warranty issue. The way these cheap gas/flux core machines are setup for gas welding is through the gun trigger controlling all the gas flow.. Gas tube runs through the machine without any electronic gas valve. The feeder has enough power to push the extra length gun,and the power supply will output everything .035 flux-core could give it.. general use it's fine on a good 20 amp breaker push the machine in the 170/180 amp range, and it will pull a bunch of juice out the wall..
    One thing this country can still do very well, is some good old Hillbilly engineering
    Esab/Lorch ET-220i
    Esab 160i caddy
    Thermal Pee-Wee 85s
    INE 1500
    Klutch 140i
  5. Likes Oscar liked this post
  6. #4
    Laredo, Tx
    Yea, looks like B/C/D-stock items that didn't make the amazingly high QC standards at the factory. So they get to chill in a street-level flea market for people to pick one up during their lunch break.
    It's funny/interesting how you are intrigued with "going down the ladder" instead of UP! But you aren't really gonna "throw" it anywhere, right? Seeing as how you do need it to work.
    HTP Invertig 400
    HTP Invertig 221
    HTP ProPulse 300
    HTP ProPulse 200 x2
    HTP ProPulse 220MTS
    HTP Inverarc 200TLP
    HTP Microcut 875SC
  7. #5
    Jan 2005
    I have had/used all the high-end machines from all over the world.. I am generally more impressed just how good the cheap stuff is today.. I am not really sure if it would be all that smart to throw one of your pulse machines around either. If I can get a good solid warranty on a cheap machine for little money, I am all in.. I will not spend a lot of money on a China made machine. It's just has to fit a lower end cost mode for me, and do the job. My other friend that has had many machines, has came to the same conclusion on some of these low rent units.. Tough, and really good value, if you know what to look for.. That is the key, understanding what you are buying. If you look at some of the Cheaper units from Lincoln in the mig units.. They are not even close to the toughness of the older SP units, They are now just in the range of all the little China units, and if you want a tough unit, buy a used old one.. Fence builders are about the worst on machines, and they just don't hold up.. unless you spend really big bucks.. In that case i will just use my LN-25 setup for toughness.
    Esab/Lorch ET-220i
    Esab 160i caddy
    Thermal Pee-Wee 85s
    INE 1500
    Klutch 140i
  8. #6
    Laredo, Tx
    Yep, I agree. The stuff being produced today at the price point they are selling it is crazy, even with typical inflation the lower-end stuff just keeps getting lower in price! I think by next year we might have vending machines for welding machines the size of a 1L bottle of soda pop! So small, you can't even plug in the dinse connectors! Pop in a $5 bill, out comes a 200A stick welder at the break/lunch room of your workplace!
    HTP Invertig 400
    HTP Invertig 221
    HTP ProPulse 300
    HTP ProPulse 200 x2
    HTP ProPulse 220MTS
    HTP Inverarc 200TLP
    HTP Microcut 875SC
  9. #7
    Do they come with one of those shields you have to hold in your hand ? so you can go to your office and start welding right there on the desk.
  10. Likes ronsii liked this post
  11. #8
    Jul 2020
    Out of curiosity - what situations would you find yourself in that would benefit from such a small welder? What are you potentially going to be welding on and where?
  12. #9
    Jan 2005
    I don't have very much China made stuff in my shop.. But what I do have is outstanding value. That said, if I am buying higher end stuff I just don't feel the trade off is worth it to me.. Had to good of luck with spending the big bucks one time.. Mid grade things like my tire machines/balancer/mid rise lift have been excellent value, and have paid for themselves very quickly. Buying higher end just was a matter of having or not having it now. It's easy to dump all our Problems on being made in China. We do have real issues with them for sure, but It will come out in the wash I believe.
    Many little maintenance stuff can be done with these machines.. I just don't want to drag 240 volt machines with me,just for tacking a fence together
    Esab/Lorch ET-220i
    Esab 160i caddy
    Thermal Pee-Wee 85s
    INE 1500
    Klutch 140i
  13. #10
    Jan 2005
    Who the hell works in a office? No my high end Italian machine came with a hand shield in it's case. Nothing with the china units, just the machine.
    Esab/Lorch ET-220i
    Esab 160i caddy
    Thermal Pee-Wee 85s
    INE 1500
    Klutch 140i
  14. #11
    Jan 2005
    Speaking of China Dinse connectors. These male/female pair are a good deal.. Pretty decent quality, meaning you can tighten the set screws up without breaking them.It's what I used on the work lead extension. Yes i have the real deal(Dinse) on some of my machines, and Lenco/Tweco ones too.
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    Esab/Lorch ET-220i
    Esab 160i caddy
    Thermal Pee-Wee 85s
    INE 1500
    Klutch 140i
  15. #12
    Wow. Cheap.
  16. #13
    Those are pretty small ones.... #6-#4 wire size... I wonder if they're making them like the 'brass' hose ends on the china hoses at the Home depot???? lools like brass... smells like brass... tastes like brass... but it AIN'T brass
  17. #14
    Jan 2005
    Some of them are garbage,and crack when you tighten them up. These have no issues,and work as well as my original Dinse 25 on my other machines. They also work together well too.
    Esab/Lorch ET-220i
    Esab 160i caddy
    Thermal Pee-Wee 85s
    INE 1500
    Klutch 140i
  18. Likes ronsii liked this post
  19. #15
    Jan 2008
    Richmond, Virginia
    Brand X, any update on this welder? They seem to be in stock now. Through 11/9/2020, this $20 off coupon code should work: 272422
    Syncrowave 250 w/ Coolmate 3
    Dialarc 250, Idealarc 250
    SP-175 +
    Lincwelder AC180C (1952)
    Victor & Smith O/A torches
    Miller spot welder
  20. Likes ronsii liked this post
  21. #16
    Apr 2016
    It looks a lot like the old Klutch st80i. I learned with that welder. I still have an old guard from a forklift that is covered in practice beads!
  22. #17
    I bought a HFT welder that looks just like the one in the OP and it was a total POS. Could BARELY get an arc started with 3/32 6010 and keeping the arc lit was almost impossible. I returned it.
  23. #18
    Got ya beat on the cheap deal Scott I got this little inverter stick welder with my CM52 when I bought it. Was some sorta corporate sales gimick. All's I know is that the thing is some kinda purple color (shrug). It's still sitting in its case. I think it's some sorta 85amp midget.
  24. #19
    I think it's actually a Thermal Dynamics midget (as Scott knows.........I gotta thing for midgets) CHECK OUT SMOKIN' ACES ASSASINS BALL
    Midgets galore!!!!!!!
  25. #20
    Then........................lest we ferget.........there was Smokin' Aces I
  26. #21
  27. #22
    Bilbao, Spain
    That is to be expected. Not even all name brand inverters are able to run 6010 reliably. Seems like you need a high OCV, and small inverters usually do not provide it.
    For 6013, 7014, 7018, etc... it should be ok.
    Mikel
  28. Likes ronsii liked this post
  29. #23
    Jan 2005
    Sammy, my Cutmaster 60i and cheap china unit together are under $500..00
    If I throw the little Amazon Prime plasma cutter at $92.00 blows you totally away
    I had are versions of the 120 volt stick units, The first one made was the smallest version, and most costly .Still have that one. The Little Ironton is just as nice. Yu can tell it has a nice hot start for a 120 volt unit.. The Thermal does it with a lot of OCV.
    Jim here bought one of these plasma's too He is also impressed.
    Esab/Lorch ET-220i
    Esab 160i caddy
    Thermal Pee-Wee 85s
    INE 1500
    Klutch 140i
  30. #24
    Laredo, Tx
    Speaking of cheap, sub-$100 welders, this thing popped up on my Amazon. Claims to run 6010s for $90. Thinking of buying it just for the heck of it.
    HTP Invertig 400
    HTP Invertig 221
    HTP ProPulse 300
    HTP ProPulse 200 x2
    HTP ProPulse 220MTS
    HTP Inverarc 200TLP
    HTP Microcut 875SC
  31. Likes Brand X, 12V71 liked this post
  32. #25
    Wow!! even runs on 110V...
  33. Likes 12V71 liked this post
Page generated in 1,620,360,744.33253 seconds with 13 queries
