Results 26 to 50 of 52
Thread: 3" hole Mild Steel 3/8" thick
    Re: 3" hole Mild Steel 3/8" thick
    I'on kno wat hapent?
  2. Likes ronsii liked this post
  3. #27
    me ther..???
  4. #28
    Oct 2012
    Sacramento, California
    I'll let you borrow this, but you need to record video of it.
  5. Likes ronsii liked this post
  6. #29
    Mar 2007
    MidWest
    Well i want to apologize to all who posted recommendations/suggestions. Indeed we cut holes in the sq tubing with carbide tipped hole saw and 1/2 inch drill. Took our time and it worked fine, nice clean cuts. I will try and post pick or two. Much obliged
    Geezer
    Power Mig 255C
    185 TIG
    Blue 175 MIG
    Ranger 8 Kohler 20HP
    Victor/Harris O/A
    K 487 Spool Gun
  7. Likes 12V71 liked this post
  8. #30
    Jun 2014
    A 3 inch hole saw can get stuck.
    Sent from my SM-A115AZ using Tapatalk
  9. Likes tapwelder, whtbaron, farmersammm liked this post
  10. #31
    Brethren, Mi
    cutting horizontal is good, chips fall out and I am not against using a little water and fully grasp the concept of this being one off in nature. Even if the saw was disposable the cost isnt a deal breaker.
  11. #32
    Apr 2016
    Quote Originally Posted by bubmiller View Post
    you would think they could have come up with a better emergency operator safety system.
  12. Likes 12V71 liked this post
  13. #33
    Jun 2014
    Quote Originally Posted by Weldalittle View Post
    Like an idiot operator shutdown sensor? I actually figured the gears were the weak spot, never guessed it was the handle.
  14. Likes 12V71, Weldalittle, whtbaron liked this post
  15. #34
    Jun 2014
    Back to topic, I don't have the resources of a machine shop, so I use hole saws regularly in heavy metal. I usually drill a hole in a block of wood first, then clamp it in place as a guide instead of using a pilot bit.
  16. Likes Weldalittle, scsmith42, geezer liked this post
  17. #35
    A regular quality bi metal hole saw will easily do it fairly quickly if there is only one to do no problem. Slow and clean chips out often. Maybe use air to blow it clean and keep teeth clean. Cutting oil will help keep teeth clean, cool and cutting. Good steady pressure at slow speed and keep saw making chips. Any hint of loading up stop and clean it again.
    Anytime I use a hole saw the arbor drill bit has been replaced with solid rod. Never use bit in hole saw to make the pilot hole. Use a separate bit to drill pilot hole then the solid rod in hole saw will keep hole saw guided straight and not woller out your pilot guide hole. The diameters are more accurate and cut is straight and clean.
  18. Likes bubmiller, Weldalittle, geezer, LtBadd liked this post
  19. #36
    Nice drill 2 piece type.
  20. Likes bubmiller, Weldalittle liked this post
  21. #37
    Mar 2008
    Georgetown, Texas
    I don't think there is any cutting oil better than good ol, kerosine. It's been used for over a hundred years now.
  22. Likes geezer liked this post
  23. #38
    Sep 2014
    Quote Originally Posted by geezer View Post
    Friend of mine ask me if I could make a hole in a cast steel column sq and 3/8" thick. I immediately thought of my torch. But he would like to have a clean 3" hole and I do not believe i can do that with oxyacetylene. Would a hole saw and going slow work? He would like a clean cut. Thanks
    If you have a drill mag you can easily do it. I use bees wax to lubricate the hole saw. I cut really nice four inch holes in 1/2” steel I make a lot of them with one hole saw and bees wax. You can do it by hand too with a nice slow hand held drill and bees wax. On smaller holes you can get through in under five minutes with a slow hand drill motor.
    Sincerely,
    William McCormick
  24. Likes Lis2323, geezer, whtbaron liked this post
  25. #39
    Don't guys drill a hole where the saw kerf runs? Something about allowing the chips to clear the hole saw instead of building up.
  26. Likes bubmiller, William McCormick liked this post
  27. #40
    Jan 2011
    W. Wisc
    I have, mainly on thicker stuff. On something like 1/8" it isn't thick enough to become an issue but even 1/4" thick is enough where you either have to stop frequently to clear out packed chips, or you drill the extra hole which allows you to keep going longer.
    -Dave
  28. Likes bubmiller liked this post
  29. #41
    Sep 2014
    Over the years I have found that doing something like that sometimes helps and sometimes hurts. I cut for about 20 seconds and retract the hole-saw clear the chips, and touch the teeth and sides of the hole-saw with the bees wax and cut some more, once the teeth are below the surface. That has proven to be the fastest. The other method can sometimes introduce a spot that causes debris to jam and take off teeth.
    Sincerely,
    William McCormick
  30. #42
    Sincerely,
    William McCormick
    I used to have a switchable magnetic base holding a regulated pressure air nozzle with shut off to direct a stream of compressed air at the hole saw’s kerf.
    It worked really well but it got disassembled when I needed the base back for my dial indicator.
    I’ve always meant to purchase a cheapo import base but I think its time to try William’s beeswax.
  31. Likes 12V71, William McCormick liked this post
  32. #43
    I just used a welding magnet and a needle valve with a chunk of 1/4" brake line aimed in the right spot. I would like to try it with a water mist.
  33. Likes William McCormick liked this post
  34. #44
    I just remembered. I used a small knob type flow control valve to throttle the flow and act as a shut off.
  35. Likes William McCormick liked this post
  36. #45
    Brethren, Mi
    Best thing ever for a bit of water in a fab shop is a gallon weed sprayer.
  37. Likes bubmiller, William McCormick liked this post
  38. #46
    Apr 2016
    I've been using a 1/2 gallon sprayer for autobody work the whole past week! Great for wet sanding, and rinsing before blow gun. I have a couple gallon ones, but what's been through them is questionable... They're great when a garden hose isn't available. Wow, I'm getting off-topic...
  39. Likes William McCormick liked this post
  40. #47
    Brethren, Mi
    Yes, I ruined one a while back on a 062 alum tube, a 3 inch. It caught and ripped teeth right out, would have never thought of it before it happened.
  41. Likes William McCormick liked this post
  42. #48
    Sep 2014
    Yea, any tubular or unleveled penetration will ruin those things in seconds. I think I had drilled a hole in the wrong spot with like a 2 1/2” hole saw and my plan was to cut a three inch hole in a piece of wood that I would clamp down to the part a half inch off center, to move the new hole over a half inch. It started off great then it jammed and I lost the hole saw. I was able to finish it but I had to recut the hole because the new hole saws teeth were wider than the old hole saw. Just one of those days.
    Sincerely,
    Wiliam McCormick
  43. #49
    Sincerely,
    Wiliam McCormick
    The rest of us NEVER have any of those
  44. Likes William McCormick liked this post
  45. #50
    Brethren, Mi
    Yes, it was in a tube, was a small tube and as you said, uneven. I was on a run nut not under a delusion that it wasnt gonna grab at some point but that soft tube rippem right out of the saw. I think I might have saved it in scrap, didnt occur to me that it might even still work fine on steel. I have cut those sized before and not above doing it for one off or prototype but under 2 inch really cuts rather well.
    I did one on this job where I lay a hole out off by exactly 1/2 inch. It was 3/8 plate. After I fot over the duh moment cleaned up the plug and welded it back in both sides and recut the hole and didnt bother it a bit.
  46. Likes William McCormick liked this post
Page generated in 1,642,409,179.01522 seconds with 13 queries
