Results 1 to 9 of 9
Thread: Muffler Replacement
    Mar 2014
    Troy MI
    Muffler Replacement
    The baffles on the muffler on my friend Rick’s tractor were shot, so it was very noisy. The original muffler had been welded to the exhaust pipe, so I cut through the weld of the old worn out muffler and welded on a new one. I like to weld the muffler to the pipe or a Nipple, because the threads of the muffler are in thin sheet metal and they crack off as shown in the following link.
    https://forum.millerwelds.com/forum/...ohn#post598219
    The first picture shows where I cut through the original weld. The weld looked like bird $hit, but it held up until the muffler wore out so I can’t complain.
    1. Old Muffler
    Name:  1. Old Muffler.jpg
    The new muffler had a 1” NPT thread on it and the pipe was ¾” nominal pipe size, so I screwed in a 1” NPT close nipple into the muffler to reduce the hole size as shown below.
    2. Muffler with nipple
    Name:  2.  Muffler with nipple.jpg
    Smith Oxyacetylene Torch
    Miller Dynasty 200DX
    Lincoln SP-250
    16" DuAll Saw
    15" Drill Press
    7" x 9" Swivel Mast Saw
    20 Ton Arbor Press
    Bridgeport
    Everlast PowerTIG 400 EXT
  3. #2
    Mar 2014
    Troy MI
    Re: Muffler Replacement
    More to come.
    Lincoln SP-250
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
  5. #3
    Mar 2014
    Troy MI
    Next I sawed off the nipple with about 1/16” protruding as shown below.
    3. Muffler with cut down nipple
    Name:  3. Muffler with cut down nipple.jpg
    Unfortunately, I didn’t take a picture of the weld, but I welded the nipple to the muffler. Then I welded the muffler to the exhaust pipe as shown below.
    4. Muffler welded to pipe
    Name:  4. Muffler welded to pipe.jpg
    Last but not least I painted it. I didn’t bother to purchase high temperature paint so it will burn off the hot exhaust pipe, but the paint should still protect the muffler.
    5. Muffler painted
    Name:  5. Muffler painted.jpg
    -Don
    Lincoln SP-250
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
  7. #4
    Jan 2016
    northeast USA
    why didnt you just weld a threaded coupling onto the pipe so the next time it needs replacing you just unscrew the old and screw the new one on??
  8. #5
    Mar 2014
    Troy MI
    I wasn't sure if the tractor could accommodate the additional length of the coupler and nipple.
    You will also notice that I welded the muffler crooked, just like the original, for the same reason.
    I am familiar with the nipple approach and have used it in the past:
    -Don
    Lincoln SP-250
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
  9. Likes Hobbytime, ronsii liked this post
  10. #6
    Jan 2016
    northeast USA
    Quote Originally Posted by Don52 View Post
    -Don
    I guess not having the unit the muffler goes on makes fitting it a bit difficult...better safe than sorry...nice repair either way...
  11. #7
    Mar 2014
    Troy MI
    On a previous repair, my customer didn't tighten the 1" NPT nipple properly into the exhaust pipe and the threads rattled around and wore out. Fortunately the nipple that I welded on was long enough to add additional threads. The first picture shows how I clamped the muffler to chase the 1" NPT threads deeper on the nipple.
    11. Muffler clamped to table with 1 inch NPT die
    Name:  11. Muffler clamped to table with 1 inch NPT die.jpg
    The next picture shows my friend John manually chasing the threads with a home made die stock.
    12. Chasing 1 inch NPT thread
    Name:  12. Chasing 1 inch NPT thread.jpg
    The next picture shows the deeper threads. If you look closely, you can see that the original threads are undersize compared to the new ones.
    13. Threads on nipple chased
    Name:  13. Threads on nipple chased.jpg
    The next picture shows me cutting off the damaged thread from the nipple on the muffler.
    14. Cutting off damaged threads
    Name:  14. Cutting off damaged threads.jpg
    And here it is all done.
    15. Nipple cut down.
    Name:  15. Nipple cut down..jpg
    The moral of the story is if you use the welded on nipple approach, be sure to firmly tighten the muffler.
    -Don
    Lincoln SP-250
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
  13. #8
    Mar 2014
    Troy MI
    Here is a picture of the muffler installed on the tractor.
    -Don
    Lincoln SP-250
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
  15. #9
    Bilbao, Spain
    Great save!
    I usually have any kind of muffler work. Steel is paper thin, rusted, etc.
    Mikel
Page generated in 1,713,252,551.40920 seconds with 22 queries
