Hello again guys, from Peru.
My next welding project is building the support for a plywood floor. It measures 10'10"x7'10".
It has a lip on the the 2 sides with brick (cement fascia), so I'll be bolting through the brick. The room that it will create will be used as an 'art and crafts studio' and a space for building RCA. It will be a storage area until I get the finished floor poured in the shop with the reinforcement.
I intend to build the same type of structure for the roof, to create a storage room above it. So, should I use C channel or tubing? The idea I have is to run the 7'10" sections across to the log run, with short sections between them. I'll be attaching the plywood with screws.
As you can see at the doorway, I have a little bit more than the thickness of a brick in space to fill. Yes, I use to be a Contractor in FL, home construction, so this is new to me. Everything down here is completely cement, rebar and brick. At least in Lima. There in the States, we all know it's wood, unless it's big commercial.
Any help in which metal would be best and size is greatly appreciated.
