Results 1 to 7 of 7
Thread: Hobart handler 135 won't shut off
    Sep 2020
    VT
    Hi everyone,
    My little 135 is such a reliable machine it decided not to stop welding! I was using it last night for some short beads and when I finished one and released the trigger I noticed that the gas didn't stop flowing. Then I also realized that the gun was still energized. The wire had stopped feeding, though. So I shut the regulator and flipped the off switch and still heard a humming noise! Finally unplugged it to get it to stop. I'm guessing I have a sticking relay or something like that. Any ideas?
    Thanks
    Glen
    Hobart Champion 16
    Miller XMT 304 CC/CV toasted
    Hobart Hefty CC/CV
    Hobart Handler 140
    Lotos LTP5000D
    Apr 2009
    Re: Hobart handler 135 won't shut off
    Either that or trigger sticking. Just throwing that in.
    Sep 2020
    VT
    The wire does stop feeding when I release the trigger so I think that's ok. Guess I'm gonna be a welder surgeon this afternoon.
    Sep 2020
    VT
    Took the cover off and blew out all the dust and junk from the last umpteen years. Lightly tapped on the relay and now it's working normally. I'm guessing the relay is at the end of it's life cycle. Probably should order a new one so I'll have it on hand when it finally dies.
    Aug 2012
    AR
    You might consider spraying some electronic contact cleaner in the relay if it's not a sealed one. If it's sticking and/or slightly corroded that may help.
    Sep 2020
    VT
    Good idea. I'll try that if (when) it happens again.
    Just kill it like they did old West
    Take out the 6 shooter.
    Quote Originally Posted by ArcTan View Post
    Hi everyone,
    Thanks
Page generated in 1,624,247,506.84734 seconds with 11 queries
