Results 1 to 13 of 13
Thread: Invertig 221
    Jul 2020
    MA
    Invertig 221
    Hi, I just bought an Invertig 221. I have a Pro pulse 300, I'd like to put them together on one cart. I've already experienced what high frequency can and will do to electronic devices nearby. Cost $800 to replace a board on my brand new LN 25. So can I ground the machine and be safe, or separate carts?
    Haksa
    Mar 2005
    Under a Rock
    Re: Invertig 221
    Have you contacted HTP to see what they have to say?
    Hypertherm PM 45
    1961 Lincoln Idealarc 250
    HTP 221
    Jul 2020
    MA
    Re: Invertig 221
    not yet
    Laredo, Tx
    Re: Invertig 221
    I have my Invertig right next to my ProPulse 300. Never had any issues, although I suppose that doesn't answer your question. The machine case is grounded via a short ground wire on the inside, granted it is not a separate actual ground path, but still "eventually" is connected to ground.
    HTP Invertig 400
    HTP Invertig 221
    HTP ProPulse 300
    HTP ProPulse 200 x2
    HTP ProPulse 220MTS
    HTP Inverarc 200TLP
    HTP Microcut 875SC
    Jul 2020
    MA
    Re: Invertig 221
    Thanks Oscar, your th
    Dec 2003
    Fairfield,CT
    Re: Invertig 221
    Look up Jimbo's Garage on YT and IG. He has like 3 or more HTPs together on one cart. He never said he had an issue either.
    www.tjsperformance.com
    Dynasty 300 DX
    HTP 240
    HTP Microcut 380
    Hyperthem 85
    Bpt. Mill/DRO
    4' x 8' CNC Plasma Table
    Instagram: tjsperformance
    Jul 2020
    Re: Invertig 221
    Quote Originally Posted by haksa View Post
    Haksa
    How in the end did you decide to organize your equipment on one frame?
    Jul 2020
    MA
    Re: Invertig 221
    Hi, I been to busy to build a dual cart, that will come later this winter. I was worried about the HF burning up the board in my Pro pulse 300. As I said earlier I had a costly lesson.
    Haksa
    Laredo, Tx
    Re: Invertig 221
    How do you like that 300? Its a beast huh? have you ran pulse steel on 92/8?
    HTP Invertig 400
    HTP Invertig 221
    HTP ProPulse 300
    HTP ProPulse 200 x2
    HTP ProPulse 220MTS
    HTP Inverarc 200TLP
    HTP Microcut 875SC
    Jul 2020
    MA
    Re: Invertig 221
    Hi, Yes I have, with just 75/25. As far as the welder goes, like I told Pete at HTP, It's the best, smoothest, most adjustable machine I've ever used. I've been around a long time.
    haksa
    Laredo, Tx
    Re: Invertig 221
    haksa
    IMO it's a bit "smoother" on 92/8, but that's just my take on it.
    HTP Invertig 400
    HTP Invertig 221
    HTP ProPulse 300
    HTP ProPulse 200 x2
    HTP ProPulse 220MTS
    HTP Inverarc 200TLP
    HTP Microcut 875SC
    Jul 2020
    MA
    Re: Invertig 221
    I can't see how it could be smoother than it is. But I don't need a bunch of bottles around.
    Feb 2015
    Re: Invertig 221
    The PP300 is one of the best all around mig welders I have used as far as arc quality thick and thin, both steel and aluminum. For steel I run C10 on short arc and pulse. The machine has plenty of power.
Page generated in 1,623,864,510.76548 seconds with 11 queries
