Results 1 to 15 of 15
Thread: Flow meter duty cycle?
    Sep 2020
    VT
    I'm looking for a decent flow meter for my wire feeder and found a Victor on Amazon but it's telling me that it has a 20% duty cycle for CO. I had no idea that flow meters or regulators even had duty cycles at all. Can someone explain how that works?
    Thanks
    Glen
    Hobart Champion 16
    Miller XMT 304 CC/CV toasted
    Hobart Hefty CC/CV
    Hobart Handler 140
    Lotos LTP5000D
    Re: Flow meter duty cycle?
    CO2 will freeze a regulator/flowmeter if you're doing any amount of welding. You can get special flowmeters for CO2 or get inline heaters to use with them. Some people have used a light bulb to prevent freezing.
    Sep 2020
    VT
    That makes sense. Same issue with C25?
    Glen
    Hobart Champion 16
    Hobart Hefty CC/CV
    Hobart Handler 140
    Lotos LTP5000D
    Dec 2007
    Los Angeles
    I have been using CO2 with a basic regulator for years and have had zero issues with freezing.
    Ed Conley
    MM252
    MM211 (Sold)
    Passport Plus & Spool gun
    Klutch 120v Plasma cutter
    SO 2020 bender
    Beer in the fridge
    Sep 2016
    Detroit, Michigan
    Aside from the freezing/duty cycle, they don't list what the outlet pressure is for that model. The spec sheet just says "preset" but not what that figure is. Normally when they don't list the output pressure it's 50PSIG.
    The slightly more expensive Harris is the 0781...and they clearly list it as being 25PSIG outlet. I have one of those on my MM252 and have used it on a TIG as well...worked well. At that price point I slightly prefer the Harris 355-2 as it's 20PSIG output...and it's also made in the U.S. I don't recall if the Harris 0781 is made in the U.S. or not.
    http://mivise.com
    Everlast PowerTig 210EXT
    Sep 2020
    VT
    Ok, I'm a total novice here. Explain what difference the output pressure makes.
    Thanks
    Glen
    Hobart Champion 16
    Hobart Hefty CC/CV
    Hobart Handler 140
    Lotos LTP5000D
    Sep 2016
    Detroit, Michigan
    Quote Originally Posted by ArcTan View Post
    Thanks
    With the higher pressure output flow meters you get a pretty big blast of gas when you hit the trigger. It probably wastes a bit of gas compared to the lower pressure flow meters, but it's mostly just annoying. It's not really a big deal with MIG, but is very noticeable with TIG. Once I got spoiled with the lower pressure flow meters I found I noticed it more...again, not a huge deal, but for a few bucks I'd go with a lower pressure setup.
    http://mivise.com
  8. Likes ArcTan liked this post
  9. #8
    C-25 doesn't freeze the regulator. Think of CO2 as being similar to propane. It's basically boiling at a very cold temp. inside the cylinder and that creates the pressure. In colder temps using high withdrawal of propane will also freeze up. Here's a couple options. Victor has some special flowmeters that have cooling fins but they are more expensive.
    https://www.arc-zone.com/co2-heated-...h?cPath=7_746&
    https://www.arc-zone.com/co2-heater-...5?cPath=7_746&
  10. #9
    "Heating" fins...?
    (Come to think of it, I guess they'd "cool" the air in the room...by drawing the heat into the C02!)
  11. Likes 12V71 liked this post
  12. #10
    Sep 2020
    VT
    Thanks for all the info and advice. I think I'm going to go with a Harris 351. I don't think I'll be using straight CO2 so shouldn't have to worry about freezing at this point.
    Glen
    Hobart Champion 16
    Hobart Hefty CC/CV
    Hobart Handler 140
    Lotos LTP5000D
  13. #11
    Mar 2008
    Georgetown, Texas
    You won't have any problems with freezing while welding and using CO2. I've used it for close to 40 years now and have never had a single problem with it freezing. With the preset regulators for using CO2 for air tools, airing up tires and such, then a bit of freezing occurs but even then it's not enough to bother any thing. I always have a cylinder on every truck, equipped with a 150 psi regulator for using as air pressure and have little problems out of them.
  14. #12
    Sep 2005
    Cave Creek AZ
    He lives in Vermont, you live in LA, totally different scenarios. I can weld with co2 all day long in the winter with no problems, he might have problems right out of the gate because it is below freezing there.
  15. #13
    Cooling fins as in a heat sink. CO2 regulators freezing is enough of a problem they make special regulators for it. As previously stated these style are a little pricey.
    https://store.cyberweld.com/visrco2re.html
  16. #14
    Apr 2010
    Kelvin
    "Heating" fins...? (Come to think of it, I guess they'd "cool"
    the air in the room . . . by drawing the heat into the C02!)
    Back - in the day - I'd burn 40# plus .045 wire in an eight
    hour shift.
    The Power Box was 100% duty-cycle - and gassed with CO2.
    The regulators had enormous concentric fins - just as you
    have described . . . to heat the chill . . .
    ArcTan
    Your choice is good . . .
    hth
    Opus
  17. #15
    Apr 2010
    ArcTan
    - per - Welder Dave . . .
    These are them - and, you don't need one . . .
    best wishes . . .
    Opus
  18. Likes Welder Dave liked this post
Page generated in 1,632,483,116.81863 seconds with 14 queries
