Results 1 to 23 of 23
Thread: Moved A Fill Bong On Diesel Tank
    Sep 2014
    Diesel tank, took about five hours with a trip Coast Welding Supply, but it came out ok. It is going to get Bondo and paint tomorrow.
    Sincerely,
    William McCormick
  2. Likes motolife313, scsmith42 liked this post
  3. #2
    Apr 2010
    Re: Moved A Fill Bong On Diesel Tank
    William McCormick
    Diesel tank, took about five hours . . . it came out ok.
    William McCormick
    Bad Job . . .
    Air Plane Frames, NASCAR Frames, Pressure, and DOT
    Fuel tanks - require visible 'Virgin Weld Bead' profiles -
    Your product was passable - until you ground/grinded =
    Bondo is Fraud . . .
    hth
    Opus
  4. Likes Mikel_24 liked this post
  5. #3
    Mar 2005
    Under a Rock
    Thatís a good observation opus.
    Now that I think about it almost every Diesel tank I see has visible welds.
    Hypertherm PM 45
    1961 Lincoln Idealarc 250
    HTP 221
  6. #4
    Sep 2014
    William McCormick
    Bad Job . . .
    hth
    Opus
    If you look inside there is a visable weld puddle, I penetrated heavy.
    Years ago it was the exact opposite you had to grind the weld. And if you came across porosity or something like that you found out what went wrong, and fixed it. The reason they stopped grinding welds is because it exposes the horror.
    Sincerely,
    William McCormick
  8. #5
    Sep 2014
    William McCormick
    Bad Job . . .
    hth
    Opus
    To give you an idea while grinding I found a spot of Tungsten and ground it out, if it was any deeper I would have ground below the surface and went over the spot again. Guys do not penetrate anymore so if you grind the weld it fails, if you penetrate totally grinding is the right thing to do. It relieves the stress caused by the weld on the surface. But I hear you if that is the rule then that is the rule. But so many of the show trucks are done that way.
    Sincerely,
    William McCormick
  9. #6
    Jan 2016
    northeast USA
    Sincerely,
    William McCormick
    most show trucks are NOT street legal....
  10. #7
    Sep 2014
    And you get them to the show how?
    Sincerely,
    William McCormick
  11. #8
    Jun 2016
    Sincerely,
    William McCormick
    by an enclosed trailer
    lincoln 125sp
    monkey wards 250 ac/dc
    miller 211 w/spool gun
    ahp 200 sx tig
    lotos ltp5000d
    of course duramax diesel
  12. Likes Hobbytime liked this post
  13. #9
    Mar 2005
    Under a Rock
    Sincerely,
    William McCormick
    And how!
    Lots of things on the road these days are not street legal.
    My pet peeve are the idiots that put off-road LED lights on the front of their vehicle and blind everyone.
    Cars and big trucks
    Hypertherm PM 45
    HTP 221
  14. Likes William McCormick liked this post
  15. #10
    393.67 appears to be still in force with regard to fuel tanks. https://www.law.cornell.edu/cfr/text/49/393.67 For an actual view of the section, see CFR....available online on the FMCSA website. I don't see any mention of welding, other than all joints must be arc welded, brazed, etc.............see Sec C
    I found no requirement that the weld not be dressed, or smoothed, in any manner.
    IMHO, the better way would be to leave an exposed weld above the material surface. The bead provides addition reinforcement if not ground. But, that's just my opinion. I'm not a fan of welding thin material while solely relying on a gap to provide penetration.........I like that bit of metal above the seam.
  16. #11
    Jan 2016
    northeast USA
    Sincerely,
    William McCormick
    a trailer...as most of those show trucks are well over 100k easily, and all the chrome on them makes it unwise to drive on dirty roads, I have several friends with show cars and they get transported in enclosed trailers, if the show trucks are too big for a covered trailer they are tarped to keep road grime off of them, they can lose points at judging for having road crap all over their truck or cars..I dont have a clue about DOT tank standards, but a bit about show trucks and cars....
  17. #12
    Jan 2016
    northeast USA
    Quote Originally Posted by duramax-rob View Post
    holy crab rob we agree on something..are the planets aligned today????
  18. #13
    Nov 2014
    PDX PNW
    I think that’s for a big truck. Probably a 3 or 4 axle truck possibly more. I don’t think those fit into enclosed trailers
  19. Likes William McCormick liked this post
  20. #14
    Sep 2014
    The raised weld bead is on the inside. Not that you need it but it is there. Aluminum is a funny metal right after welding the weld is soft but after a couple of months, it gets age hardened. That is why I never recommend anything but 40-43 filler. Other more brittle rods, later on, will continue to get harder and harder.
    Sincerely,
    William McCormick
  21. #15
    Sep 2014
    The guys often make a show because they have a job on the way, many of the trucks are work trucks. To get a low flatbed to put the tractor on and another tractor to pull it is pretty costly. They just do what they love doing when they get to the show, and that is, polish up their trucks.
    Sincerely,
    William McCormick
  22. #16
    Mar 2005
    Under a Rock
    Sincerely,
    William McCormick
    Exactly.
    There are a couple trucks up in Boston I see like that.
    They ARE work trucks but then again they are not very practical.
    Most of them have very long (ridiculous) wheelbases
    And very low to the ground...
    I suppose if youíre going to just hit the freeway and do a drop and hook it would be OK. But to actually back in a 53 foot trailer anywhere tight is a royal pain in the nuts.
    Especially when youíre literally sitting on the floor and the gear shifter is at the ceiling..... LOL !
    Hypertherm PM 45
    HTP 221
  23. #17
    Sep 2014
    And how!
    Cars and big trucks
    My son has the light bar mounted on his Blacked out Chevy suburban. He only turns them on when someone is in the left lane and will not yield to the right. Haha. It is kind of funny to see. Years ago when he was younger he bought an AR15 and put one of those blinding bright lights on it. I was asleep I had to be up early. He comes into my room yelling "FREEZE ON THE GROUND", puts his foot on me to hold me down, and blinds me with the light. And then just leaves my room. I had a burned-in image of the light in my retinas. After a while, I started to think it was some kind of insane dream I had and fell asleep. So the next day I wake up and look at my white sheet and his boot print is on it. I said to myself "that little bastard" with that he comes in again and pulls the same stunt. That time I grabbed his gun and took it away. I love him so much though I cannot stay mad at him, he makes me laugh.
    Sincerely,
    William McCormick
  24. Likes ronsii liked this post
  25. #18
    Exactly.
    I know a couple of those guys...
  27. #19
    Seen a few myself
  28. #20
    Seen a few myself
    I had one guy that complained constantly about his 18 speed jumping out of gear in the front holes... I took away his 18" shifter extension and threw it in the scrap bin, his boss approved of that move, the extra weight would pop it out on a rough road.
  29. Likes ronsii liked this post
  30. #21
    But now he won't have that 'extra' leverage to really grind it in those 'sticky' gears!!!!
  31. Likes 12V71, William McCormick liked this post
  32. #22
    Apr 2014
    I'm not familiar with diesel tanks, but 21 replies and none pointed out the difference between a bong and a bung?
    vs
  33. Likes 12V71 liked this post
  34. #23
    It's actually spelled "Bhong" if you smoke out of it.
  35. Likes ronsii liked this post
Page generated in 1,627,399,852.19906 seconds with 13 queries
