Results 1 to 22 of 22
Thread: Uploaded Picture Orientation
    Sep 2016
    Detroit, Michigan
    I see that many folks struggle with uploading pictures here (and other forums) because many cell phone pictures only display properly if the picture was taken with the phone held sideways rather than upright. I have a website and was able to find a plugin that corrects for that so no matter how the picture was taken, it will display correctly. The plugin was free on my platform, and seems to work perfectly. I know other forums run some sort of plugin to account for this and figured it was worth asking about here...a lot easier than always remembering to take pictures with the phone sideways!
    Any chance someone could look into this?
    http://mivise.com
    Hobart Champion Elite
    Everlast PowerTig 210EXT
    Apr 2013
    Re: Uploaded Picture Orientation
    You don't need to take landscape photos to make them appear right side up. Portrait ones work also.
    Sep 2016
    Detroit, Michigan
    Quote Originally Posted by Robb M. View Post
    Okay, then how do you do that? Any time I upload a cell phone picture that was taken in portrait it displays 90* off. I recall that's a problem mainly with iPhone pictures...what I'm using. I added a free plugin on my website and now it makes them display properly.
    http://mivise.com
    Sep 2016
    Detroit, Michigan
    Taken in portrait with an iPhone 11 Pro....can't find any settings here to correct this.
    http://mivise.com
    Does your Iphone automatically rotate the screen when you rotate the phone...like from portrait to landscale for instance???--- in camera mode...
    here:
    https://support.apple.com/en-us/HT204547
    Sep 2016
    Detroit, Michigan
    However you hold an iPhone, the image will be displayed properly when you take a picture. If I then look at that picture on the phone it will rotate to stay properly oriented if I rotate the phone while viewing, but that's not really the issue.
    The problem is when you take a picture with the phone held vertically (portrait orientation) and then post it to the forum...it will display on the screen rotated 90* to the left. If you take a picture with the phone held horizontally (landscape) and then post it to the forum it will display properly. This is a known issue with iPhone pictures and many websites are running a plugin to correct for it.
    If you send an iPhone photo to a Samsung mobile device or Windows computer, save it, edit to rotate it and save it again you can then post it on this forum and it will display properly.
    As an experiment I took an iPhone pic taken in portrait, edited it and rotated it 90* right then saved it and posted it here...still displayed 90* left, so it's not something you can easily correct.
    I found this problem when I set up my website several years ago and it was a known issue...add a plugin and the problem goes away. I just did a Google search on the topic and the first hit said something like "most websites already correct for this" or something similar.
    http://mivise.com
    Mar 2019
    SoCal
    I was just trying to post some photos and have exact same problem.
  8. Likes G-ManBart liked this post
  9. #8
    Mar 2019
    SoCal
    Also as an FYI, my pictures are all shot in portrait. I guess I won’t post pics here as I’ve had this problem here every time. I did look up Irfanview, however it seems it’s for PC’s and not iPhones.
  10. #9
    Sep 2016
    Detroit, Michigan
    Anything? I'm not the only one having this problem...comes up time and again.
    http://mivise.com
  11. #10
    Apr 2013
    are you holding your phone upside down?
    i am including three images. one portrait, one portrait mode portrait and a screenshot with an arrow pointing to the portrait/landscape identifier in the iOS camera app. all shots taken with my 11 Pro Max.
    cheers,
    robb
  12. #11
    Apr 2013
    well that’s interesting. the photo mode, portrait oriented is sideways. the portrait mode in portrait orientation is as expected.
    I'll have to dig into this, I have never experienced a sideways image before.
  13. #12
    Apr 2013
    testing
  14. #13
    Sep 2016
    Detroit, Michigan
    I was definitely holding my phone properly. I don't think I've used portrait mode, just photo mode so far...
    http://mivise.com
  15. #14
    As long as I reset the exif rotation tag it put pics up fine no matter where they are from.
    Not sure why some devices are different... although I have noticed if you're using an android device it will do it if you don't have autorotation turned on for the phone.
  16. #15
    Los Angeles
    Click on
    Go Advanced
    Manage attachments
    and you can preview your image and check orientation before posting.
    MM211 (Sold)
    Klutch 120v Plasma cutter
  17. #16
    Sep 2016
    Detroit, Michigan
    Click on
    Go Advanced
    Manage attachments
    That lets you check the orientation, but I can't find how it will let you change the orientation....that's the real problem.
    http://mivise.com
  18. #17
    Los Angeles
    If it does not show correct orientation then I'll go back to the photo on my computer and rotate it- seems to work then.
    Some times I just rotate it a full 360 back to normal and then it will load to the forum correctly.
    MM211 (Sold)
  19. #18
    Sep 2016
    Detroit, Michigan
    I haven't been able to get that to work on my Mac. I've read that it will work on a PC, but I don't have one at home. I've actually e-mailed an image from my iPhone to my work Samsung, saved it, rotated it, saved it with a new name, sent it back to my Mac and uploaded it and had it work....but that's kind of ridiculous.
    There are plugins that do this automatically, so I'm not sure why there isn't one here. My dinky blog site has a plugin to fix that issue....crazy.
    http://mivise.com
  20. #19
    Los Angeles
    Interesting, I'm on an iMac.
    I'll pull the photo out of iPhoto to the desktop, open the photo in Preview and then rotate 360
    MM211 (Sold)
  21. #20
    Sep 2016
    Detroit, Michigan
    Interesting, I'm on a iMac.
    I just went to my post in the classifieds and saved the sideways picture I posted. I then opened it on the Mac, rotated it 90* and saved it again. Then I uploaded it here and it displayed properly.
    The problem is, if I take a picture with my phone my Mac (tried this on a Mac Mini, MacBook and iMac) orients it properly when I look at it so when I go to upload, it's sideways here. I tried to trick the system and rotated a picture 90* to the right, saved it that way so it showed up sideways 90* to the right on the Mac, then upload it here...still displays rotated 90* to the left.
    I can't imagine why saving it from here, then rotating it right, and uploading it again works...ugh.
    http://mivise.com
  22. #21
    Sechelt, BC
    That little icon you pointed to with the red arrow is the front/back camera selector. It does rotate with camera orientation but that is all it does.
  23. #22
    Stokes County, NC
    And the issue with the site continues. The pictures are saved in the correct orientation and display correctly elsewhere so the issue seems to be site related.
    https://weldingweb.com/vbb/threads/7...re#post8811662
    The pictures were taken with an Android tablet. They display correctly on that and on my laptop. They get inverted during the upload process to WW.
    Any help to get the pictures rotated would be appreciated.
    Thanks and best regards,
    Lance
    Multimatic 255 w/MDX-250 EZ-Select gun
    Hypertherm Powermax45 XP
    Heck Bevel Mill 4000
    Miller/Smith heavy duty torch set
    9" Evolution circular saw
  24. Likes wb4rt liked this post
Page generated in 1,638,353,862.68817 seconds with 13 queries
