Page 4 of 4 FirstFirst ... 234
Results 76 to 84 of 84
Thread: Bird Nest
  1. #76
    Ceres, California
    Re: Bird Nest
    one more thing. If you have a miller M25 gun. Make sure the outlet guide; Small piece of liner sticking out the end of the gun is not missing or bent.
    Other guns make sure they are pushed all the way in and almost touching the drive roll. Large gap between drive roll and gun end will bird nest if the wire stubs on the plate for any reason.
  2. Likes ronsii liked this post
  3. #77
    Mount Tabor VT
    Re: Bird Nest
    Outlet guide is there, not bent. I'm working from memory here, but it occurred to me the liner needs to bend for the gun, there is springiness to it, and the guide should be longer to push the liner to match the angle of the contact tip. Now I've got to dismantle it to inspect that. I wonder if a short piece of tubing could be slid into the end of the gun tube to better align the liner to the tip?
  4. #78
    Ceres, California
    Re: Bird Nest
    Don't cut the liner to long or to short. a long liner will cause feeding problems.
    When you install the diffuser the liner will accordion pleat inside the gun and cause a lot of friction. short liner will leave a large gap between the liner and the tip.
    Load liner into gun. use the diffuser to figure out where to cut. place on the end of the liner and see how much goes in side. mark diffuser then lay diffuser next to gun in correct position. pull liner out then push back in. pull back out 1/8 of an inch and cut at mark. Liner will stay in contact with diffuser with out accordion pleating. Cut liner with wire cutters, not cutting wheel.
    Cutting wheel leave a sharp edge that will scrape the wire and cause feeding problem sooner and later.
  5. #79
    Re: Bird Nest
    Stretch the gun out when installing the liner and make sure it's long enough with a curve in the gun. Have seen a few liners installed that were either too short or too long because somebody didn't take the time to check the length before cutting.
  6. Likes CAVEMANN liked this post
  7. #80
    Mount Tabor VT
    Re: Bird Nest
    I had another thread with my frustration with porosity & worm tracks in Dual Shield.
    Yesterday I used a fair amount of Dual Shield. Roughly twice as much wire ended up in the trash as on the bucket I was welding. I'd say 12 birdnests in two hours. I believe it happens less when I had a full inch of stick out. I'm convinced the problem is gripping the contact tip. I'm going to get a drill a bit bigger than the hole in the tip.
    Otherwise, welding with the dual shield was a success yesterday.
  8. #81
    Mar 2021
    Near Roanoke, VA
    Re: Bird Nest
    I have not read EVERY post,, but, many of them,,
    of the ones I have read,, everything has been discussed pertaining to wire delivery, rollers, gun,, etc,,
    Have you considered the ground lead as the issue?
    At lower voltage, and amperage, a poorly assembled ground lead can cause issues,, possibly the birdnesting,,
    I would completely disassemble the ENTIRE ground lead, and check the wire and ALL connection points.
    I was looking at the manual for one of my welders last night,, that ground lead disassembly and check is recommended every 500 hours,,,
  9. #82
    Sep 2016
    Detroit, Michigan
    Re: Bird Nest
    You actually have a welder manual that uses the term "ground lead"?
    http://mivise.com
    Hobart Champion Elite
    Everlast PowerTig 210EXT
  10. #83
    Mar 2021
    Near Roanoke, VA
    Re: Bird Nest
    I interpreted,, it simply shows a pic of cables with bare wire, and loose connections,,
  11. #84
    Mount Tabor VT
    Re: Bird Nest
    I did upgrade the clamp a year or two ago. I will check the connection at the welder end. My habit is to touch connections after a session of welding see if they get warm. If they do, they need attention.
Page generated in 1,621,095,676.15977 seconds with 12 queries
