Results 1 to 14 of 14
Thread: How close to Empty do we use Argon bottles?
    Mar 2009
    Northern Virginia
    I am in the middle or the start of a new TIG welding project.
    My two bottles are less than 500, one about 200 another about 400.
    So I was wondering what most people do?
    Are the regulators accurate enough?
    How close to empty to we suck the bottles down?
    Thanks in advance.
    Dec 2016
    New Jersey
    Re: How close to Empty do we use Argon bottles?
    I run it until it's empty - i.e. the weld puddle flames out brown soot. Seems my needle buries down to very close to zero for a while before this happens too from what I've noticed.
  3. Likes vdotmatrix liked this post
    SoCal-LA
    I like to run the needle to the post or until I pickup contaminants. Otherwise I leave just enough pressure as to not let in moisture.
  5. Likes vdotmatrix liked this post
  6. #4
    Mar 2009
    Northern Virginia
    Okay!!! Thanks to everyone who responded....who would have thunk I would be needing ARGON again.
  7. #5
    Aug 2018
    I run it down to about 100....
    Welds last longer than Love...
  8. Likes vdotmatrix liked this post
  9. #6
    Depends on how critical the weld is and the position it's in. On critical work a lot of places change cylinders at around 100 PSI so there's no chance of running out of shielding gas. It can be a real pain to have to grind out a bad weld in an awkward location. On less critical stuff you could use till you notice a problem.
  10. Likes sapperb, vdotmatrix liked this post
  11. #7
    Apr 2008
    NW ON Canada
    I run mine to completely empty. Then replace with full. Gas is too expensive to return the bottle not empty.
    Jason
    Thermal Dynamics Cutmaster 52
    Miller Bobcat 250
    Torchmate CNC table
    Thermal Arc Hefty 2
    Ironworkers Local 720
  12. Likes vdotmatrix liked this post
  13. #8
    All my home tanks, run until empty.
    Work tanks were different. Shop truck deliveries to job determines when we return.
    We would tag tank contents of cylinders so shop could use them up.
  14. Likes vdotmatrix liked this post
  15. #9
    Tennessee
    I also run al cylinders empty, with the exception of those for scuba lol
    "Stick-man"
  16. Likes ronsii, vdotmatrix, small_e_900 liked this post
  17. #10
    Nov 2019
    North East Ohio
    I don't tig but I run my bottle empty. Unless I have a ton of welding to do one the weekend and fear I will not make it.
  18. Likes vdotmatrix liked this post
  19. #11
    Jul 2020
    Dubai
    I run my argon bottle until it empty
  20. Likes vdotmatrix liked this post
  21. #12
    Jul 2018
    Cumbria, UK
    run to empty. Several times I've actually used it right to the point of arcing up and getting nothing.
  22. Likes vdotmatrix liked this post
  23. #13
    That is where all the bad gas comes from. From guy's that don't leave pressure in the tank. You like to leave the valve open too so it can air out ? Lol.
    You are never "SUPPOSED" to run them empty. When they are empty they have to vacuum the tank down before they can fill it. While no gas supplier enforces it they often have a charge for running them empty. It takes a lot longer to fill if you have to vacuum it down first.
  24. #14
    Jul 2018
    Cumbria, UK
    I'd argue that any supplier that doesn't vacuum bottles down first, is a poor supplier.
Page generated in 1,713,277,098.77920 seconds with 19 queries
