Results 1 to 12 of 12
Thread: Undercarriage for Miller bluestar welder
    Feb 2019
    Pittsburgh pa.
    I picked up this bluestar 2e very cheap non running. I got it all fixed up and running good, then made this undercarriage for it so I can move it around. I think the welder weighs close to 600 lbs. I am not a professional, but I am learning as I go. I got the square tubing free from work, and this was my first experiment with angles. The handles took me some time to figure out how I wanted to do the hinges, but I was happy with how they turned out. I tiged most of this.
Size:  91.3 KBName:  DSC05663.jpg
Size:  91.7 KBName:  DSC05664.jpg
Size:  86.9 KBName:  DSC05665.jpg
Size:  99.7 KBName:  DSC05666.jpg
  2. Likes 12V71, farmersammm, whtbaron liked this post
  3. #2
    Mar 2005
    Under a Rock
    Re: Undercarriage for Miller bluestar welder
    looks great.
    Hypertherm PM 45
    1961 Lincoln Idealarc 250
    HTP 221
    It's the wrong color, but looks pretty goodName:  tkqe4fh-smiley-two-thumbs-up175028_285604.gif
    Dec 2011
    Tampa FL
    Looks good. it appears you got have the angles figured out and well executed. The only thing I see that i think I would change would be to cap the ends of the round tubes on the handles, just something that I was taught to do.
    Mike
  6. #5
    NW New Jersey
    Great design, and very well crafted. Are you planning to paint the welder too ? It is in great looking condition. I have an AEAD-200 which looks the same but just a little older and much more beat up. Did you use that to TIG weld the frame ? I have never used mine to TIG weld(scratch start) but its a great stick welder for sure.
    Miller Synchrowave 180 sd
    Miller Econo Twin HF
    Lincoln 210 MP
    Dayton 225 ac/dc
    Victor torches
    Snap-On YA-212
    Lotos Cut60D
    Primeweld 225 ac/dc
    Primeweld mig180
    Miller AEAD-200
  7. #6
    Great job on the cart. Showcases your talents by having the angles on the "roll bar". You could buy plastic plugs to put in the round tube. I'd sand the welder down and paint it the same as the cart. Welder looks in great shape and you can read the front panel.
  8. #7
    Nice work! As you well know the cart is worth more than the welder.
  10. #8
    Feb 2019
    Pittsburgh pa.
    I diddnt plan on painting the welder, I hate painting plus It earned its scratches and bruises. I kind of like it the way it is. I didn't use this machine to weld it. I used my little everlast 160 amp inverter machine. I stick welded the angle iron frame that the welder is sitting on, and tig welded everything else. Thank you for the complements.
  11. #9
    Feb 2019
    Pittsburgh pa.
    Thank you! half of the money I have into it is the leads. Im sure I could get my money back out of it if I ever wanted to sell it, but I plan on keeping it for now. I got it more for a project than anything else. Their aren't a whole lot of parts available for it anymore though...
  12. #10
    Or in this case perhaps PLUG the tubes. Easier and (arguably) stronger.
  13. #11
    Dec 2012
    Valley City, Ohio
    Very nice! And it is the perfect color!
  14. #12
    that is a beautiful undercarriage i also have a 2e bluestar. i have recently had to do some repairs that i guess are very common on these single cylinder tecumseh. The flywheel magnets come loose and take out the stator . parts for these engines are nla so if you have the time pull the flywheel and jb weld the magnets in the flywheel make sure to mark them otherwise if the north south is incorrect it will not charge. i also added a rope wrap pull start pulley to mine was 2o$ on ebay and seems to start better with pulling it over than the electric start . beautiful 2e
  15. Likes mikejxms liked this post
Page generated in 1,713,308,343.44710 seconds with 20 queries
