Results 1 to 7 of 7
Thread: Is it necessary using a gas regulator for mig and TIG welding?
    Jul 2020
    Dubai
    Re: Is it necessary using a gas regulator for mig and TIG welding?
    Yes the tank pressure is 3,000 psi
    Quote Originally Posted by shasti View Post
  3. Likes CAVEMANN liked this post
    Kinda like trying to take a drink of water from a pressure washer.
  5. Likes shovelon, ronsii, 12V71, CAVEMANN liked this post
  6. #4
    Are you serious ?
    Quit while your ahead. Welding probably isn't going to go well for you. Lol.
  7. Likes CAVEMANN liked this post
  8. #5
    Jun 2017
    AJO, ARIZONA
    It's all about bringing the pressure down & making the volume variable, in some cases both pressure and volume may be adjustable, the gas replaces the flux in stick welding and flux core mig, it shields your weld while it cools, without a regulator or flowmeter it might get dangerous, REAL QUICK. That pressure just might make that little molten puddle a 3000 PSI projectile. BE CAREFUL!
    IMPEACH BIDEN!
    NRA LIFE MEMBER
    UNITWELD 175 AMP 3 IN1 DC
    MIDSTATES 300 AMP AC MACHINE
    GOD HELP AMERICA!
    RONALD REAGAN
  9. #6
    May 2021
    Yes, In my opinion it is necessary to use. If you ask which regualtor do I need for Mig and Tig Welding then answer is, Argon Regulators normally show Gas Flow Rate in Litres Per Minute and Cubic Feet Per Hour. It's important to make sure the Delivery Gauge reads Flow Rate as most Mig and Tig Welders will quote a recommended delivery in Litres per Minute. An Argon Regulator should also be used for Argon/Co2 Mixed gases.
  10. #7
    May 2012
    Ontario, Canada
Page generated in 1,623,828,921.17328 seconds with 13 queries
