Results 1 to 5 of 5
Thread: Can i run a digipulse feeder of a heliarc 252 power source?
    Dec 2020
    Hello this is my first post
    My name is Rich
    i have a heliarc 252 power source. can i run a digipulse feeder off that?
    thanks
    Jul 2016
    Midwest
    Re: Can i run a digipulse feeder of a heliarc 252 power source?
    I'm going to say no you can't. You could probably run a voltage sensing feeder off it though.
    Thermal Arc 320SP ( Lorch )
    Cobra Pythons
    ESAB 301i AC/DC ( Lorch )
    Thermal Arc 161STL ( WTL )
    Thermal Arc 190S ( Sanrex )
    Victor Gas Apps.
    You have to post spec on both.
    Most likely it work just find.
    Most wire feeders use 120v ac
    The only time you can run problems is with spool guns most are 24v ac.
    Quote Originally Posted by Lectrician10 View Post
    My name is Rich
    thanks
    Jan 2005
    Most wire feeders are 24 volt, and 42 volt.. Older ones were 120 volts.. The 252 is a cc only machine, and it will take a LN-25 type voltage sensing feeder to run of the stick mode in DC output..No CV output from the power supply.The Digipulse is for a CV power supply.
    Blue Demon 140 MSI
    Blue Demon 200 AC/DC
    Esab 160i caddy
    Esab CV353
    INE 1500
    Lincoln 250 Idealarc
    Thermal LM-200
    Thermal 60i- 3phase
    Thermal 15c
    Topshak 40 plasma
    Miller Regency 200/LN-72
    Viking 250 mig/2410 feeder
    Weldcote 140
    Ceres, California
    The digipulse wire feeder is a microprocessor controlled feeder and it will control the SVI 450i welder. ESAB or L-Tec and allows for pulse welding. In its day it built a lot of car frames.
    The heliarc 252 Is a TIG / stick welder. The two can not be adapted together and work.
Page generated in 1,713,255,256.11692 seconds with 18 queries
