Results 1 to 16 of 16
Thread: Miller 215 vs Miller 235
    Dec 2020
    What do I get for the additional money with the 235?
    Thanks,
    firheat
    CT
    Re: Miller 215 vs Miller 235
    additional duty cycle and the ability to hold larger spools. The duty cycle difference is enough that the 215 comes with a 100 amp gun while to the 235 comes with a 250 amp gun.
    Nov 2020
    If you were to buy one of these two, which one would you prefer?
    CT
    I actually am going to buy the 255. But of those two, it really depends on what kind of material you normally work with, and if you would benefit from larger spools or not
  6. #5
    Look at the duty cycle @ 60%
    The 235 is 170 amps.
    The 215 is 125 amps.
    I would choose 170 amps @ 60% duty cycle. Better for larger jobs
    Quote Originally Posted by firheat View Post
    Thanks,
    firheat
  7. Likes Louie1961 liked this post
  8. #6
    I picked the 235. Though 215 class machines weren't considered.
    Mig runs very well on the 235. Ive ran the machine most everyday since I got it about a month ago.
    It also burns 7018 decent .
    Also look at the hobart 240, esab 235.
    I've got alot of trigger time on the esab mig only 235. The miller runs every bit as good and I like the mdx250 gun better. I was going to buy the esab but the mig only is no longer available so the multi 235 was decided on after a few phone calls and lots of research.
    Many dont need 60% duty cycle. I weld buckets and heavy stuff i plan to torture this 235 burning half inch. I think itl do it.
    Good luck deciding and have fun with whatever you get.
    I did have slight remorse wondering if I should have stepped up to the 255 or 252. Its looking like this 235 will work well for me as long as it just keeps working when I pull the trigger.
  9. #7
    Dec 2020
    I'm just a hobbyist. I have been welding with an older Montgomery Ward 250 amp ac/dc stick and have gotten to the point I can stick things together to stay, but there's no beauty here. Never did MIG in my life. I don't think duty cycle would be a consideration for me as I do a lot more thinking than welding. However, I'm a little concerned when they say can weld up to 3/8 mild steel. Around the farm, I could see wanting to go possibly a little thicker at some point. Are they talking 3/8 single pass? I've got time and I can multi-pass easily enough, but I'm just not sure where I am here. I'm comfortable with the stick so I want to have that option, but I hear MIG is easier, specially for thinner stuff. I don't have any mentors in the neighborhood so it's just me and Jody (and used to be Chucky2009, but I don't know what happened there).
  10. #8
    CT
    It sounds like you'll be fine with the multimatic 215. Use it to stick weld or TIG anything over 3/8ths, and leave the wire feeder for 1/4 inch and under. I am a firm believer that once you get over 1/4 to 3/8, short circuit MIG just isn't the best process to choose. Personally at that point I would either stick weld it or go with a gas shielded flux core wire, which is very much like stick welding, but with an endless electrode. There's lots of good videos out there explaining why limiting short circuit MIG to around a quarter inch is best. Yes you can do multiple passes, but its not the best answer.
  11. #9
    Los Angeles
    You could get a lot more machine for cheaper with a Hobart Ironman 240
    https://store.cyberweld.com/hobart-i...SAAEgIoV_D_BwE
    No Tig or Stick function but you already have a Stick Machine.
    If you want to add Tig process to the MM215 you'll need to buy the Tig kit which adds another $412.00 to the cost.
    MM211 (Sold)
    Klutch 120v Plasma cutter
  12. #10
    Researching the 235 i learned mostly about the 215 lots of forgiving arc characteristics comments.
    My 235 is damn forgiving itl weld well damn near anywhere the dials are set and is the first machine that ive run were auto set works. 215 sounds to be the same.
    Being able to fine tune within auto set is cool.
    Lots of people talk highly of the 215 i cant seeing you being disappointed. I rarely hit the duty cycle with a 30% machine. Mostly when running longer than 6", with it screaming bloody mearcy for all its worth doing work it probably shouldn't.
  13. #11
    Dec 2020
    Thanks for the input. I figured maybe the 215 is all I need for what I do normally, but I'm gathering now that if I did come across something thicker than 3/8, I could go stick. I know this a Ford vs Chevy kind of question, but I assume the Lincoln 210 MP has basically the same capabilities - anybody out there have a preference, and if so, why? (guess I'm in the Miller sub-forum so I know the answer in advance).
  14. #12
    The C25 MIG arc on the 215 is one of the most forgiving I've experienced making it one of the easiest units I've ran to get dialed into quality output.
  15. #13
    Los Angeles
    Ford vs Chevy- Pretty much.
    My business partner bought the Lincoln 210 and likes it. I have had Lincolns before but didn't like the Lincoln 210. Could be that I just really like my Passport Plus and am used to it.
    We did have a MM211 (transformer model) for a bit but sold it off as neither one of liked that thing. Terrible on Aluminum.
    I'm a fanboy of the Miller Passport Plus- no longer made- I can only assume the new Miller inverters are just as nice.
    I prefer it over the MM252.
    MM211 (Sold)
  16. #14
    I don't weld thicker than 1/4" very often
    3/8 and thicker i usually do multiple passes anyways.
    I don't think tig or stick adds any capacity to weld thicker materials with one pass. It's not what the 215-235 class machines are designed to do
  17. #15
    Aren't
  18. #16
    I would just add 2 comments. The 235 will not take 120v power. the 215 does. I am thinking of selling the 215 for a 255 but the portability is so nice. The reason to upgrade for me is 215 limits what kind of wire you can use.
    Sent from my SM-G960U1 using Tapatalk
Page generated in 1,623,920,857.46440 seconds with 12 queries
