Page 18 of 18 FirstFirst ... 8161718
Results 426 to 450 of 450
Thread: Air tank build for cleaning chainsaw oil/fuel caps
  1. #426
    Feb 2019
    Snyder TX
    Re: Air tank build for cleaning chainsaw oil/fuel caps
    I don't have time to read all 17 pages. Did it blow up or not?
  2. #427
    Soda springs,Id
    In moto's case I don't know if no news is good news.
    Ol' Stonebreaker
    Hobart G-213 portable
    Miller 175 mig
    Victor O/A setup
    Makita chop saw
  3. #428
    Jan 2013
    So I thought I would sum this thread up for anyone not wanting to read it all.
    Moto- Is my idea good?
    Everyone- No, in fact it's dangerous
    Moto- I actually don't care what you all think.
  4. #429
    ^^^ About sums it up.
  5. Likes MinnesotaDave, Dave66 liked this post
  6. #430
    Nov 2014
    PDX PNW
    It’s been holding 80 psi for a week.
  7. #431
    It's when it doesn't hold a given PSI that the problem starts
  8. Likes Capt B, William McCormick liked this post
  9. #432
    That's what this is for
  10. Likes William McCormick liked this post
  11. #433
    Man I get tired of trying to flush that crap out of systems. Had a Kenworth a while back that took bulk brake cleaner and 175 PSI air to get the cab and sleeper lines cleaned out... GRRR.
  12. Likes ronsii, CAVEMANN liked this post
  13. #434
    If it's so effective, why the UV dye?🤣
  14. Likes 12V71, ronsii, mla2ofus, farmersammm liked this post
  15. #435
    NW New Jersey
    I've used these Bimba reservoirs on vacuum systems that need a cleaning pulse for the filters. These are much lighter than the ones made from 2" black iron parts threaded together.
    Last time I bought some they were under $50 (that was a couple of years ago, prices subject to change without prior notice, quotes only good for 30 days, YMMV)
    Miller Synchrowave 180 sd
    Miller Econo Twin HF
    Lincoln 210 MP
    Dayton 225 ac/dc
    Victor torches
    Snap-On YA-212
    Lotos Cut60D
    Primeweld 225 ac/dc
    Primeweld mig180
    Miller AEAD-200
  16. #436
    Fredericksburg, VA
    Quote Originally Posted by mbarasing View Post
    Plenty beefy for sure. Thanks for the cut away. I'd like to see the bottom if you have one...seems like they're kindof dimpled inward. I guess so that it stands up well.
    I forgot I had a picture of what an aluminum 80 cubic foot scuba tank looks like cut in half. Here you go. The side walls are 1/2" thick while the top and "corners" at the bottom are over 1" thick.
    Millermatic 252 MIG
    Miller Dynasty 200DX TIG
    Miller Spectrum 625 Plasma
    Altas 12x36 Metal Lathe
    Bridgeport Milling Machine
    www.psacustomcreations.com
  17. #437
    Cool!!! that looks like it would make a neat welding project to put it back together and see how good your welds hold up under a hydro test that is
  18. Likes psacustomcreations, mbarasing, 12V71 liked this post
  19. #438
    I am a happy camper when I pick up 50# of CO2 and it's in an aluminum cylinder.
  20. Likes ronsii liked this post
  21. #439
    Dec 2015
    Why don't you just buy a small battery powered blower? You can blow off all your equipment and they are less dangerous and not any heavier to carry.
    Sent from my SM-N960U using Tapatalk
  22. Likes William McCormick liked this post
  23. #440
    Oh... you missed the posts a few pages back... had something to do with his testes...
    Cut 50 Plasma
  24. Likes ronsii, William McCormick, N2 Welding liked this post
  25. #441
    Mar 2009
  26. #442
    Sep 2014
    I don't know...American Society of Mechanical Engineers (ASME) would be unlikely to tackle coconuts since most of them are overseas...have to use a foreign equivalent I think
    It could lead to a whole new high-pressure standard, instead of bar or psi we could say twenty coconuts. I am more afraid of the new Motto standard.
    Sincerely,
    William McCormick
  27. Likes MinnesotaDave liked this post
  28. #443
    Jun 2016
    does anyone know at what pressure an air tank that looses pressure from a leak become a rupture destructive leak or just an air leak? have there been studies on it? i have had probably 10 different type of compressors over the years bought used or given that developed various leaks and never exploded. some were rusted, couple were fittings failed. most were 175psi compressors.
    just wondering?
    lincoln 125sp
    dayton 250 ac/dc
    miller 211 w/spool gun
    ahp 200 sx tig
    lotos ltp5000d
    kubota b3200 FEL BH
    of course duramax diesel
  29. #444
    Quote Originally Posted by duramax-rob View Post
    just wondering?
    It's not a given pressure but rather the material and the the weakness that is affecting an area. It's just like a tire. A dry rotted tire with cracks will blow out at a lower pressure than a tire with newer rubber that has been zippered.
  30. Likes 12V71, Capt B liked this post
  31. #445
    Big Lake/Monticello MN
    just wondering?
    It's just a roll of the dice I'm afraid. I've welded an air tank that was previously brazed (someone else).
    I ended up cutting out 2 hand sized holes, one near each end, and welding in new material. Rust made them thin enough to poke holes easily with a chipping hammer.
    I did that 15-20 years ago, never blew up thankfully.
    Some tanks just zipper open and blow. Most just leak.
    Syncro 350
  32. Likes 12V71 liked this post
  33. #446
    Nov 2014
    PDX PNW
    Better go to the casino with your odds rolling the dice rob
  34. #447
    Stopped by another friends place to see how his tank builds were going.... these are 20 foot by 2 foot pipe 3/8th wall I think and prolly 1/2 on the ends... might be 5/8ths
  35. Likes Capt B, motolife313 liked this post
  36. #448
    Feb 2016
    Myrtle Beach
    What are they used for?
    Lincoln 350MP
    Millermatic 350P
    Syncrowave 250
    1969 SA200
    HTP Invertig 221
  37. #449
    Quote Originally Posted by Capt B View Post
    Floating boom of some kind? I built one for a marina years back with 16" pipe.
  38. Likes ronsii, Capt B, motolife313 liked this post
  39. #450
    What kind of pressure do they hold?
Page generated in 1,664,113,735.02614 seconds with 13 queries
