Page 5 of 18 FirstFirst ... 3456715 ... LastLast
Results 101 to 125 of 450
Thread: Air tank build for cleaning chainsaw oil/fuel caps
  1. #101
    Soda springs,Id
    Re: Air tank build for cleaning chainsaw oil/fuel caps
    The ends should be your worry!!
    Ol' Stonebreaker
    Hobart G-213 portable
    Miller 175 mig
    Victor O/A setup
    Makita chop saw
  2. #102
    Feb 2016
    Myrtle Beach
    Quote Originally Posted by Joker11 View Post
    This is awesome.
    So many arguments.
    You know what a pony bottle is in SCUBA diving?
    Itís small but filled to 3000psi. You can fit an air hose on it with a regulator and have way more air than that cylinder at 125psi.
    I am mot joining the arguments. Thatís all you guys.
    6 CF Catalina Scuba Dive Pony Tank Bailout Bottle with Thermo Valve Din Yoke Reg 3000psi $59.99
    https://www.ebay.com/i/164580960924?...RoCatkQAvD_BwE
    Lincoln 350MP
    Millermatic 350P
    Syncrowave 250
    1969 SA200
    HTP Invertig 221
  3. #103
    Nov 2014
    PDX PNW
    Too thick too budge and has small diameter So it’s very strong and will have full pen key hole weld with 5356. Plastic can hold 4 times the pressure of what I’m putting in at the same diameter why wouldn’t this hold a 1/4 of what plastic can hold? Given no corrosion inside if that’s what your stuck on
  4. #104
    Nov 2014
    PDX PNW
    I’m guessing those pony tanks are made from 7075?
  5. #105
    Nov 2014
    PDX PNW
    Quote Originally Posted by Capt B View Post
    Probably need to go to the scuba shop to fill it
  6. #106
    Feb 2016
    Myrtle Beach
    You don't need to put 3,000psi in it just put 125psi in it from a compressor.
    Lincoln 350MP
    Millermatic 350P
    Syncrowave 250
    1969 SA200
    HTP Invertig 221
  7. Likes motolife313 liked this post
  8. #107
    Sebeka and Bemidji MN
    Very true.
    In a math comparison, head types on the vessel were:
    Hemispherical (Hemi)
    Semi Elliptical (SE)
    Flanged and Dished (F&D)
    Flat
    The cylinder was 1/2" thick.
    The thicknesses of each head type were calculated to match the known design pressure of the 1/2" cylinder.
    Results:
    Hemispherical: 0.2474"
    Semi Elliptical: 0.4947"
    Flanged and Dished: 0.8901
    Flat end: 3.9120"
    Flat needed 3.9120" to match 1/2" wall cylinder pressure specs....
    Moto, you still believe you understand all the risks and the physics behind what you are doing?
    Syncro 350
  9. #108
    Nov 2014
    PDX PNW
    Very true.
    In a math comparison, head types on the vessel were: Hemispherical (Hemi)
    Flat
    Results:
    Flat.end: 3.9120"
    Flat needed 3.9120" to match 1/2" wall cylinder....
    Yes I do Dave. This tank won’t corrode inside and I’ll be filling from a safe air compressor
    The 3000psi ones have 1/2” or so wall I believe. Mine is also about half the diameter of the ones I seen online. Which makes it strongerName:  59F5225B-D55D-4617-BEB1-C5FED3C6B14B.jpg
Size:  85.1 KBmine is under 3” on the outside
  10. #109
    Mar 2006
    Yuma, Arizona
    It was an example, one could use a paintball gun cylinder and do the same as scuba. Get it filled at any sporting goods store.
    Also, almost every welding supplier sells breathing air refulls as well as air refills as well as co2 refills.
    Options are open.
    Lincoln Power Mig 210MP MIG
    Lincoln TIG 300-300
    Lincoln Hobby-Weld 110v Thanks JLAMES
    My brain
  11. Likes motolife313 liked this post
  12. #110
    The 3000psi ones have 1/2” or so wall I believe. Mine is also about half the diameter of the ones I seen online. Which makes it stronger mine is under 3” on the outside
    Unfortunately, you missed the point...but oh well.
    The numbers I posted show how bad it is to use flat end caps btw...there is more too but doesn't seem like you're open to learning right now.
    Syncro 350
  13. Likes Oscar liked this post
  14. #111
    Mar 2005
    Under a Rock
    LMAO !
    seems like all you guys do is Ride poor Moto....
    takes the heat off me for pointing out his usual nonsense.
    Hypertherm PM 45
    1961 Lincoln Idealarc 250
    HTP 221
  15. #112
    Nov 2014
    PDX PNW
    I donít know what 1/2Ē tube your taking about what diameter tube your taking about and I couldnít see needing over 3Ē thick ends Unless your talking about a 3í diameter tube trying to hold 500 psi Iím clearly missing something not sure what pressure youíre talking either. Thank you for trying to help
  16. #113
    Nov 2014
    PDX PNW
    LMAO !
    Ya they like to over think that’s for sure.
  17. #114
    Mar 2005
    Under a Rock
    better to over think than not think at all
    Duhhhh...
    Hypertherm PM 45
    HTP 221
  18. #115
    Nov 2014
    PDX PNW
    Duhhhh...
    You guys are bunch of losers
  19. #116
    2.5” id with 3/16 wall. 2’ long. 1/4 end caps and 1/2” for the fitting boss. Going to put a small gauge on it also. Not 100% sure how I wanna fill it. I’m open to ideasAttachment 1721044Attachment 1721045just wanna blow the wood chips and dust away from the caps each time before filling upAttachment 172104649” bar on that puppy and it pulls it like nothing
    " I'm open to ideas"🤣
  20. Likes motolife313 liked this post
  21. #117
    Nov 2014
    PDX PNW
    " I'm open to ideas"��
    “ not sure how I wanna fill it open to ideas” yes that’s right. Schrader valve was suggested and I said that was a good idea. Comparing apples to oranges like your friends
  22. #118
    Nov 2014
    PDX PNW
    Good try tho
  23. #119
    No, your not open to ideas. Your looking for an" attaboy" big pay on the back for your nonscencacle " innovation". IMO that device would make a better piggy bank than an air tank since it would be hard pressed to inflate a basketball with that volume of air. As for the safety , go with it, it's your risk. But saying your open to suggestions means pay me on the back and praise the shlt out of me.
  24. #120
    Nov 2014
    PDX PNW
    Thanks for your opinion
  25. #121
    Feb 2009
    Central CA
    Nevermind
  26. #122
    Nov 2014
    PDX PNW
    I’ll just leave this here. Working pressure of the Pvc pipe is 450, yes 450, yes 450 psi and it didn’t blow till over 1,100 psi
    flat ends we’re used looks like. And I’m using aluminum btw Incase you over thinkers forgot which is way stronger, which is way stronger then plastic.
  27. #123
    That's a hydrostatic " test". Big difference between that and air pressure. The former is a leak, the latter a bomb.
  28. #124
    Nov 2014
    PDX PNW
    Ok, be nice to figure out the equivalent to air pressure. Probably still extremely high pressure.
  29. #125
    Fredericksburg, VA
    I use this setup like Joker was mentioning. A scuba tank, adjustable scuba regulator, 5 foot hose and QD for air tools. I keep something loke this in my work truck. The steel tank is next to a 19 cubic foot aluminum tank then the 6 cubic foot aluminum pony tank also mentioned earlier. I have also used this to power a nailgun inside and on top of the house.
    Moto does not have a dive certification card and will not be able to get a scuba tank filled at a dive shop.
    I would be very surprised if a welding shop would fill a scuba tank. As a diver who is also certified in a bunch of other diving related maintenance and inspection tasks, I would not trust their air quality. Although some places might have industrial quality high pressure air compressors.
    I have access to and can make a set of fittings which allows me to fill this tank from a shop compressor. That would be to about 135 to 160 psi. Moto could potentially do the same. He will not.
    Millermatic 252 MIG
    Miller Dynasty 200DX TIG
    Miller Spectrum 625 Plasma
    Altas 12x36 Metal Lathe
    Bridgeport Milling Machine
    www.psacustomcreations.com
Page generated in 1,624,345,772.78656 seconds with 13 queries
