Page 1 of 18 12311 ... LastLast
Results 1 to 25 of 450
Thread: Air tank build for cleaning chainsaw oil/fuel caps
    Nov 2014
    PDX PNW
    2.5” id with 3/16 wall. 2’ long. 1/4 end caps and 1/2” for the fitting boss. Going to put a small gauge on it also. Not 100% sure how I wanna fill it. I’m open to ideasName:  35F6851C-51B8-4B8E-A1D6-21A6F350E7E4.jpg
Size:  118.8 KBName:  D8744CED-B872-4609-ADCB-F7B817A8406B.jpg
Size:  85.3 KBjust wanna blow the wood chips and dust away from the caps each time before filling upName:  B7455784-E487-4559-808E-0D940B920B0E.jpg
Size:  245.5 KB49” bar on that puppy and it pulls it like nothing
  2. Likes ronsii liked this post
  3. #2
    Re: Air tank build for cleaning chainsaw oil/fuel caps
    I keep a little stiff bristle brush handy in the saw box... works great for brushing the dirt off the bark where you're going to part the stump after someone running the hoe splashes dirt on everything
  4. Likes motolife313 liked this post
  5. #3
    Mar 2005
    Under a Rock
    An old 20lb. propane tank and a short hose will hold a lot more air.
    a couple fittings is all you need.
    Hypertherm PM 45
    1961 Lincoln Idealarc 250
    HTP 221
  6. Likes 12V71, MinnesotaDave, 12345678910 liked this post
  7. #4
    Apr 2010
    motolife313
    . . . Iím open to ideas . . .
    Don't reinvent the wheel . . .
    Opus
  8. Likes walker, MinnesotaDave liked this post
    Dislikes motolife313 disliked this post
  9. #5
    Nov 2014
    PDX PNW
    That’s a lot more heavy. Don’t need much to blow off the caps Is what I’m thinking
  10. #6
    That’s a lot more heavy. Don’t need much to blow of the gaps Is what I’m thinking
    That 2.5" pipe isn't going to hold much air. A carpenter buddy of mine has a little Craftsman cordless pancake compressor that cost less than $100 bucks and pumps an honest 125 PSI. I think I'm gonna get one just for pumping the garden tractor tires and stuff like that. Way easier to carry to the flat tire.
  12. #7
    Nov 2014
    PDX PNW
    I’ve got a 3 gallons compressor oiled but I like to keep the weight down and take less stuff when out milling in the bush. Will see. I’ll probably get the thinnest air line to keep my volume down and pressure up. It’s also a welding project for fun and keeping my skills up. If I can get 12-24 good burts I think it may be worth it, Probably about a gallon or more in the tube, haven’t added it up yet. Bore x bore x stroke x.7854 I think lol.
  13. #8
    About a half gallon - your cylinder 117.8 cu/in gallon ~230 cu/in
    Have you thought about putting a thicker end on as a boss for the pressure gauge? then mount one of the little 1/8 back mount gauges like the fire extinguishers have on them...
  14. Likes motolife313 liked this post
  15. #9
    Nov 2014
    PDX PNW
    The plan was putting the gauge and hose on that 1/2” plate with 2 holes. Probably could have used a smaller hole for the gauge.
    Thanks for adding that up. I think it’s actually 25.5” long just for the guys who don’t think it’s big enough lol. I figured little bigger wouldn’t hurt. Edit no homo on that last one lol
  16. #10
    Moto, off the top of my head, I'm thinking you might wind up with a pipe bomb. I'm in no way sure what kind of pressure that thing will hold without coming apart in lots of pieces. Like I say.........I DON'T ACTUALLY KNOW. But it would be a good idea to get an idea what burst pressure is on something like that.
  17. Likes Scott Young liked this post
  18. #11
    I think that is tubing so it would be a tubing bomb...
  19. Likes Broccoli1 liked this post
  20. #12
    Nov 2014
    PDX PNW
    Guys put over 100 psi in pvc tube so I’m guessing this would hold about 300+ psi. 125-150 ain’t much for such a strong tube setup. Being only 2 7/8” round makes it very strong
Size:  40.6 KBim thinking this valve is a good idea for letting the air in and trapping it
  22. #13
    I've seen aluminium tanks considerably bigger with thinner walls rated for 150.. so burst ought to be a bit higher of course I don't know what alloy they were...
  23. Likes motolife313 liked this post
  24. #14
    https://www.clintonaluminum.com/alum...0and%20bottles.
    Scroll down, and read about the alloy most commonly used. I dunno if it's used in the annealed, or heat treated condition.
  25. Likes motolife313 liked this post
  26. #15
    Nov 2014
    PDX PNW
    Like the one at HF???
  27. #16
    I hate it when guys guess at stuff
  28. #17
    Haven't seen the HF one but... I'm gonna GUESS it similar
  29. #18
    We don't want Moto to be half the man he used to be
  30. #19
    Sorta like hydraulic cylinders...........not just plain ol' metal..........they buy "mother tubes" to make 'em out of, and it ain't A-36
  31. #20
    Nov 2014
    PDX PNW
    This stuff is 6061 and I’ll be using 5356 with singles passes and I’ll be preheating Name:  594EAEB9-22DE-4170-8260-F5E15216A973.jpg
Size:  95.4 KBtank I made in the past. 3/8” end caps.
  32. #21
    Flat ends are the worst choice for pressure tanks!!! they will have huge amounts of flex on the adjoining welds.
  33. Likes 12V71, CAVEMANN liked this post
  34. #22
    https://www.chicagotube.com/products...andrel-st52-3/ I know this isn't for air, it's used in hydraulic cylinders, but it illustrates the possible mistakes one could make................say.........using regular DOM for a cylinder. Just a thought.
  35. #23
    While I'm sure the 100-150 psi you'll be using is way below what a 2.5 pipe of that thickness is capable of holding... it would be a good thing to build yourself one of those hydro testers like tackit made and yours is small enough it could easily be charged for testing with a grease gun.
  36. #24
    Nov 2014
    PDX PNW
    Depending on how thick the metal is how much pressure you use and how strong the welds are that’s true
  37. #25
    Nov 2014
    PDX PNW
    I’m really not worried. This puppy ain’t gona move. Should have seen a guy brazing a square 16 gauge or less Square box and put over a hundred in it on here. Braze job looked very poor if I remember right and it held. If plastic pvc can hold it’s a no brainer aluminum will hold
Page generated in 1,624,349,085.92908 seconds with 13 queries
