Results 1 to 5 of 5
Thread: Miller 330 A/BP
    Sep 2016
    Detroit, Michigan
    Miller 330 A/BP
    Miller 330 A/BP with a water-cooled torch, pedal, work cable/clamp, flow meter and Bernard cooler. I set it for 230V, put a 6-50 plug on it, flushed the cooler and ran it a bit...it does need a good cleaning. I haven't done any stick welding with it, but I did test the DCEP when balling a pure tungsten and it worked fine. I was going to play around with it for a while but I've got a lot of projects lined up and I "accidentally" bought a surface grinder at auction today, so this needs to go.
    You can test it on my bottle all you want, and I can load it for you on your truck or trailer...it's about 800lbs!
    $800
    Sorry...WW still hasn't fixed the issue of iPhone pictures taken in portrait mode showing up sideways. Come on guys.....my dinky little blog website has a plugin to fix that.
    http://mivise.com
    Hobart Champion Elite
    Everlast PowerTig 210EXT
    Sep 2016
    Detroit, Michigan
    Re: Miller 330 A/BP
    http://mivise.com
    city of Four Flags
    Re: Miller 330 A/BP
    " I "accidentally" bought a surface grinder at auction today"
    I like your style!
    Good luck with the sale.
  4. Likes G-ManBart liked this post
    Sep 2016
    Detroit, Michigan
    Re: Miller 330 A/BP
    Quote Originally Posted by vwguy3 View Post
    I like your style!
    Thanks...have someone coming to look at the 330 tomorrow! I brought the surface grinder home today. It's an import (said to be Taiwan) and nothing fancy, but was under $500 out the door. It started raining the last 20 minutes of the trip and the rain mixed with oil and turned it into a mess, so I set it on the tarp and then spent half an hour wiping it down...seems pretty solid.
    http://mivise.com
  6. Likes vwguy3 liked this post
  7. #5
    Sep 2016
    Detroit, Michigan
    Re: Miller 330 A/BP
    Welder has been sold. Thanks
    http://mivise.com
Page generated in 1,623,825,432.02189 seconds with 13 queries
