Re: Hobart g213 welder
Sounds like you did good, forhire. If needed I can take some pics of the crankshaft end with it laying on a tape measure for scale. I just welded a piece of 1" shaft down on the frame with a hole drilled for an implement pin to prevent it from bouncing off. Of course if it bounced that high it would probably wipe out the ceramic insulators I previously mentioned. That and the unfused 120v seems to be the only Achille's heels in this machine.
Hobart G-213 portable
Originally Posted by
Brand X
Those are cool.
* bookmarked for the future
Esab/Lorch ET-220i
Esab 160i caddy
Thermal Pee-Wee 85s
Thermal Drag-gun 35C
INE 1500
Klutch 140i
Lugs showed up today. Welding nicer now... I think the run time on the brushes has helped.. The machine is not as old as I was told,, Still old though..
They did not even make the Wisconsin THD until 1957
I cleaned up some of the grim off it, and it has a nice Patina, (that's staying) GW2225 is the model..
Last thing is to try my LN-25 pro on this thing.. Runs 7018/6010 nice..
Esab/Lorch ET-220i
Esab 160i caddy
Thermal Pee-Wee 85s
INE 1500
Klutch 140i
Brand X
My lugs showed up also.
Based on my spec # Hobart sent me a manual that was dated '73. It was newer than I expected, but sounds right because it has the 12V system rather than a magneto.
Cool,
the lugs are handy. Ran my LN-25 Pro with .035/45 Easb/Hobart Self-shielded flux-core, and some Esab .045 dual-shield with co2.. That worked ok but really the .035 self-shielded had the most range. It's not quite the same as having CV, but has some use. Still nice stick arc, and what it is about..Ran about a tank of gas through it, had some stumbles early on, float/seat must of had a bit of gunk in it was running a bit rich. cleared up, and was able to use a few gals without issues. Holds 3 gals or so.. It was nice to see it flowed, and ran the tank down towards the bottom.. Means the fuel pump is working correct..
PS,fine voltage control is working very well,a lot of range in each gear..only one I did not try is low gear.. #2 runs 3/32 rod well
Esab/Lorch ET-220i
Esab 160i caddy
Thermal Pee-Wee 85s
INE 1500
Klutch 140i
