Page 1 of 4 123 ... LastLast
Results 1 to 25 of 90
Thread: Hobart g213 welder
    Dec 2020
    Hobart g213 welder
    I am older than this welder and I still work!! Hope to get this old one back working after pulling from brush pile, Need to find a manual and parts list for it . it has a flat brass( looks like) coil that has broken in 2 parts I do not know if this is a open air transformer or maybe some type of choke. Any help will be appreciated
    Apr 2020
    Re: Hobart g213 welder
    I had good luck getting the manual from over at Hobart forum.
    Apr 2020
    I found the manual do you have a email I can send it to?
    Dec 2020
    Quote Originally Posted by Johndough05 View Post
    My email is lkoontz2@logantele.com Much thanks Hey everyone JUST SLOW DOWN!!
    Dec 2020
    Want to thank you for the manual, got it now need to find coil AAW3944 thanks again
    Apr 2020
    You can find the Wisconsin engine manual online also I don’t have that in email form though.
    Soda springs,Id
    lazy733,I have the engine manual if you need it. PM me if so.
    Ol' Stonebreaker
    Hobart G-213 portable
    Miller 175 mig
    Victor O/A setup
    Makita chop saw
  8. Likes ronsii liked this post
  9. #8
    Morton, Washington
    I just picked up a G-213 circa 1954 with the TJD-2 engine. Serial number AAW-72876. It appears to use the EEA100 starter. It turns over slow on 6V and about right on 12V. Looking at the parts breakdown the motor is a YA61. Can anyone confirm 12V is correct? It's using coil ignition so I'd assume 12V.
    I found these engine parts manuals online if anyone needs them.
    http://www.pittauto.com/customer/pia...ter_motors.pdf
    http://www.pittauto.com/customer/pia...d_final_v1.pdf
    Where is the best place to buy parts? I don't presently have any spark so I may need to source a few parts. Does anyone have the Wisconsin service/rebuild manual?
    mla2ofus I sent you a PM about your manuals.
  10. Likes ronsii liked this post
  11. #9
    Morton, Washington
    Quote Originally Posted by tackit View Post
    Will you please turn your repair into another one of your traffic and interesting repair threads? Haven't seen one in awhile now. forhire, what was the Aussies name that helped you make the sign for the forge. Man I miss him, he had a lot of good information to share, I wish he would come back. If you would PM me his email I would ask him to.
    You are thinking of Mick. I believe he was banned during the DotMatrix meltdown. You should be able to reach him here: https://snapncut.com/
  13. #10
    Morton, Washington
    I confirmed it's a 12V system... it was right in front of me on the regulators.
    I replaced the missing starter button and battery cables.
    I cleaned the sediment bowl with acetone. The varnish from the old gas was really stuck on. I also bead blasted the clamp parts and re-plated them with zinc. The finish isn't great but it was heavily pitted.
    When I removed the top cover to drain the fuel tank this giant house spider was waiting to attack me. The tank was surprisingly clean.
  14. Likes ronsii liked this post
  15. #11
    Morton, Washington
    The distributor was heavily rusted. My heart sank when I realized it completely frozen. I feared the bottom end would be completely destroyed.
    Fortunately this doesn't appear to be the original distributor and as luck would have it the pinion wasn't engaged on the worm. It clearly wasn't fully installed. I am so lucky!
    So I proceeded to clean it up. I stripped everything down. Bead blasted what needed to be cleaned.
    I then re-plated all the parts with zinc. I didn't really get any pictures of the plating process.
    After re-assembling the distributor, and installing fresh points, I now have very strong/healthy spark. Tomorrow I'll set the timing. Napa didn't have the cap, rotor, or condenser in stock but I have spark so I can continue while waiting for the parts to arrive. I suspect the carburetor will need some attention. Any recommendations on degumming the carburetor without tearing it down?
  16. Likes ronsii liked this post
  17. #12
    Mar 2005
    Under a Rock
    Hobart g213 welder
    Come on now...
    You were doing so good with this project don’t screw it up now.
    Take it apart and clean it.
    But if you want to Try firing it with the carburetor as-is, i’ve had moderate success with spraying Seafoam spray or deep creep before and after it fires.
    Hypertherm PM 45
    1961 Lincoln Idealarc 250
    HTP 221
  18. #13
    Morton, Washington
    Come on now... You were doing so good with this project don’t screw it up now.
    Take it apart and clean it. But if you want to Try firing it with the carburetor as-is, i’ve had moderate success with spraying Seafoam spray or deep creep before and after it fires.
    I know you're right. Considering the fuel line from the tank barely passed fuel, even overnight, I can only imagine the state of the carb.
    I did get it to belch a little this morning...
    Here's a photo of the distributor after replating everything.
  20. #14
    Jan 2005
    Not sure of the model, but looked at one yesterday. Not really sure if the guy wants to sell it. or if the price is right? It was the guy's dads unit, and has value to him there.. Anyway It's a twin, and mag/crank style twin ..Told me not to wrap your thumb around the handle when turning it over.. Both pistons rise, and fall together
    Blue Demon 140 MSI
    Blue Demon 200 AC/DC
    Esab 160i caddy
    Esab CV353
    INE 1500
    Lincoln 250 Idealarc
    Thermal LM-200
    Thermal 60i- 3phase
    Thermal 15c
    Topshak 40 plasma
    Miller Regency 200/LN-72
    Viking 250 mig/2410 feeder
    Weldcote 140
  22. #15
    Dec 2009
    Lake Havasu AZ
    Scott sounds like a Norton Commando
    Esab Multimaster 260
    Esab Caddy160I
    ESAB powercut 650
    Esab 220i tig
    Lincoln Precision Tig 225
    INE SKYLINE 1500
    Klutch 140i
    Firepower fp-200
    MEASURE TWICE IS FOR MORONS
  23. #16
    Jan 2005
    Quote Originally Posted by jim cafarelli View Post
    I don't know, because I never heard it run.. I did hear a story of how it broke the owners arm one day.. I guess you need to be a old/ tough/ welder to use one.. I am one out of three..
    Blue Demon 140 MSI
    Esab 160i caddy
    Esab CV353
    INE 1500
    Thermal LM-200
    Thermal 60i- 3phase
    Thermal 15c
    Topshak 40 plasma
    Weldcote 140
  24. Likes ronsii liked this post
  25. #17
    Soda springs,Id
    Mine is the TJD model which has the crank throws 180* apart whereas the THD has the crank throws as you describe.
    Ol' Stonebreaker
    Miller 175 mig
    Victor O/A setup
    Makita chop saw
  27. #18
    Jan 2005
    About time for Hobart to bring out a 270 degree unit...
    Blue Demon 140 MSI
    Esab 160i caddy
    Esab CV353
    INE 1500
    Thermal LM-200
    Thermal 60i- 3phase
    Thermal 15c
    Topshak 40 plasma
    Weldcote 140
  28. #19
    Morton, Washington
    My engine is a TJD and is missing the hand crank. My push button works pretty good. I need to get a crank and try it once I have it running. I priced them out and I may have to make one. The crank model number is U212, according to the manual.
    I pulled the carb today. Float is definitely bad. Cracked, rotted, and full of fuel. I need to order a rebuild kit. Napa lists a kit without the float. I may end up ordering something online. I believe it's a Zenith series 68, L-63-BC is stamped on it. It was definitely gunked up. I loosened it up using acetone and then put it in the ultrasonic cleaner with some diluted oil-eater. It cleaned up fairly well. I'm quickly remembering why I prefer diesel.
  29. Likes ronsii liked this post
  30. #20
    Quick search turned this up... from overseas.Looks close... but I'm not 100 percent certain it's an exact match???
    https://www.ebay.com/itm/Carburetor-...wAAOSwUIRfh~MU
    Ooops... posted wrong link at first..
    This one comes at a higher price and without the floats but says it's for a 63/2003 series... I couldn't find the differences from the 61,62,63's... so I don't know if the floats are the same or not???
  31. #21
    Morton, Washington
    I found a good picture of the series 68 kit here: https://www.carbkitsource.com/kits/ck0950.html
    I bought this one for for $12.67... all I really need is the float and gasket: https://www.ebay.com/itm/183776351256
  32. Likes ronsii liked this post
  33. #22
    That good price.
    Make job of rebuilding the carburetor easy.
  34. #23
    Jan 2005
    Got mine home today, 1945 model year..(from what I heard anyway..)
    Blue Demon 140 MSI
    Esab 160i caddy
    Esab CV353
    INE 1500
    Thermal LM-200
    Thermal 60i- 3phase
    Thermal 15c
    Topshak 40 plasma
    Weldcote 140
  35. Likes ronsii liked this post
  36. #24
    Thumbs up Re: Hobart g213 welder
    I like it
  37. #25
    Jan 2005
    I like it
    Yes, it has patina It generates power at 1800, and welds at 2200. The owner has a Bobcat 250 on his service truck ,and says the Hobart will air arc smaller rods, and the Miller fall flat on it's face..The Miller AEAD 200 I had made power at 1800, and welded at 3000 RPM.. The 360 degree twin in the Hobart is all about low end torque .
    Blue Demon 140 MSI
    Esab 160i caddy
    Esab CV353
    INE 1500
    Thermal LM-200
    Thermal 60i- 3phase
    Thermal 15c
    Topshak 40 plasma
    Weldcote 140
  38. Likes ronsii liked this post
Page generated in 1,713,300,119.21818 seconds with 20 queries
