Results 1 to 18 of 18
Thread: Thickness Gauge Conversions
    Hi. Wondering if anyone knows where I could down load a chart for conversions
    Thickness Gauge to fractions. decimal. and mm. I'm sure I have seen them on WW at one time
    Thanks.
    Sep 2008
    Dalton, GA
    Re: Thickness Gauge Conversions
    I googled steel gauge to inch chart. Many to choose from. Pick your favorite.
    Burt
    _____________________
    Miller Syncrowave 250
    Millermatic 211
    Miller 375 Plasma Cutter
    Hobart Handler 120
    10FtDrillBit.com
    Laredo, Tx
    HTP Invertig 400
    HTP Invertig 221
    HTP ProPulse 300
    HTP ProPulse 200 x2
    HTP ProPulse 220MTS
    HTP Inverarc 200TLP
    HTP Microcut 875SC
    Thanks Burt. and Oscar.
  6. #5
    Jan 2015
    Martha Lake, WA
    I compared the one I have been using to Oscar's and noticed mine is B&S gauge, which is quite a bit different. I looked up what the B&S stood for and got this:
    "The Brown & Sharpe (B&S) Sheet Metal Gauge (also known as the American Wire gauge, or AWG) is the American standard for ordering wire and sheet sizes. One side of this sheet metal gauge from General Tools is marked 0 to 36 in AWG sizes, while the decimal inch equivalents are marked on back. An essential tool for both jewelers and metalsmiths needing to quickly determine the thickness of sheet metal or metal wire."
    I didn't realize that there were multiple standards for specifying sheet thickness - can someone explain why there are 2 and which one is most correct for sheet metal?
    Tweco Fabricator 211i
    Sieg X2
    AMT radial arm drill press
    AMT belt/disk sander
    HF 4X6 bandsaw
  7. #6
    Jan 2015
    Martha Lake, WA
    Now I'm really confused. Looked at metalsupermarkets.com and they show gage charts for different alloys that have different dimensions.
    https://www.metalsupermarkets.com/wp...auge-Chart.pdf
    Sieg X2
    HF 4X6 bandsaw
  8. #7
    Quote Originally Posted by jrporter View Post
    Yep.... thermal expansion coefficients can really play havoc on numbers!!!!
    Remember those are by Gauge.... and if you look how 'Gauge' is determined you'll see why it varies.
  9. #8
    Laredo, Tx
    I downloaded mine from here years ago. Someone had posted it in a Microsoft Word and I just saved it as a PDF. For me as a hobbyist it's accurate enough.
    HTP Invertig 400
    HTP Invertig 221
    HTP ProPulse 300
    HTP ProPulse 200 x2
    HTP ProPulse 220MTS
    HTP Inverarc 200TLP
    HTP Microcut 875SC
  10. #9
    Feb 2012
    Gauge vs thickness depends on the metal in question.
    16 gauge copper is a different thickness than ss, aluminum or sheet metal etc. I think of it like Troy ounces or precious metal is not measured the same as other metals. That's the best analogy I can offer and I don't have time to goooogle it but as the op pointed out, there are different tables with different thickness for metal. I mostly see tables for sheet metal but I'm sure the sparkles are used to working with copper.
    Edit: I see ronsi already posted a chart before I posted. Good explanation ronsi, I honestly didn't know it had to do with thermal coefficient but that does explain a lot to me.
  11. #10
    Here list of steel gauges
    Note: look for wrong gauge charts each industry's used there own sizes.
    Overs year you remember the basic sizes
    Carbon Steel Gauge Chart*
    Gauge
    Number Inches MM
    7 | .1793 | 4.554
    8 | .1644 | 4.175
    9 | .1495 | 3.797
    10 | .1345 | 3.416
    11 | .1196 | 3.038
    12 | .1046 | 2.656
    14. | .0747 | 1.897
    16 | .0598 | 1.518
    18 | .0478 | 1.214
    20 | .0359 | .911
    22 | .0299 | .759
    24 | .0239 | .607
    26 | .0179 | .454
    28 | .0149 | .378
    Thanks.
  12. #11
    I believe Machinery's has tolerances on sheet metal, or maybe it was something else I read. Sheet metal is not standard. It has a range of thickness within each gage. I have the specs somewhere.
    https://www.ebay.com/itm/Precision-M....c100008.m2219
    I dunno if you can find these in real numbers anymore(I got mine about 100yrs ago)...........looks like all the ones out there are metric. Worthless. But anyways......these will give you the absolute true dimensions so there's no guesswork.
  13. #12
    Sep 2008
    Dalton, GA
    Just in case you are interested, Miller sells a handy material thickness gauge. It is around $5.00. I keep a couple close by, one hangs on my welder cart. I don’t think many people are aware of these.
    https://www.millerwelds.com/accessor...s-gauge-229895
    Burt
    Millermatic 211
    Hobart Handler 120
    10FtDrillBit.com
  14. Likes ronsii, whtbaron liked this post
  15. #13
  16. Likes whtbaron liked this post
  17. #14
    Yep, they are handy when dealing with thin stuff... I have 5 or 6 of them laying around... if I remember right they came with welders??? I think I also have a similar one without the miller name on it that came with an old plasma.
  18. #15
    Fredericksburg, VA
    I like these kind since they give a wider number of sizes.
    https://uploads.tapatalk-cdn.com/202...87e4640bbc.jpg
    https://uploads.tapatalk-cdn.com/202...411e2616e8.jpg
    Millermatic 252 MIG
    Miller Dynasty 200DX TIG
    Miller Spectrum 625 Plasma
    Altas 12x36 Metal Lathe
    Bridgeport Milling Machine
    www.psacustomcreations.com
  19. Likes ronsii, BD1 liked this post
  20. #16
    I got a couple of them when I bought a new machines .
    I prefer the round ones like Pat shows.
    Happy New Year Guys !
  21. Likes ronsii, psacustomcreations liked this post
  22. #17
    I have a Starrett and a cheap generic US Standard gage for sheet and plate.
    Pics tell the story. Starrett on the left. El-cheapo on the right.
    https://uploads.tapatalk-cdn.com/202...0cec9acf80.jpg
    https://uploads.tapatalk-cdn.com/202...2d703a0483.jpg
  23. Likes whtbaron, Rondo liked this post
  24. #18
    Dec 2015
    One caution that you want to remember is that a standard wire gauge will read 2 gauge numbers LOWER than a U.S standard gauge for sheet and plate. Thus making you think that you have a thicker piece of sheet than you have ! Also,copper sheet for the sheet metal industry,is determined by ounce designation per square foot. That is, 16 Oz. Copper sheet weighs 1 pound per sq.ft.
    16 Oz copper,one of the most commonly used in the sheet metal industry, is equal in thickness to 24 ga or a tight, tight 25 ga. on a sheet and plate gauge. 👍
Page generated in 1,624,261,872.39888 seconds with 13 queries
