What's the most likely cause?
So my 3.5 Eco boost fuel rail pressure leaks off after the truck sits for a while. The low pressure fuel pump then sometimes can take 3-4 minutes to pump up and shut off before the truck will start again. If I don't wait until the LPFP shuts off it won't start. I believe the pump is ok because the truck runs fine after it starts... What's the most likely cause?
Owner of Fast Leroy's Bar and Grill
Liquor up Front, Poker in the Rear
Re: What's the most likely cause?
Pressure regulator or fuel injectors are leaking down.
Originally Posted by
mechanic416
Thanks, any way to troubleshoot to know which for sure?
Fast Leroy
Install a test gauge to the system while running & then kill the engine & keep an eye on the gauge, not really much else than I can think of that would cause it.
UNITWELD 175 AMP 3 IN1 DC
MIDSTATES 300 AMP AC MACHINE
JEFF
There should also be a backflow preventer/check valve in the fuel pump IIRC. If it fails, it will bleed back down into the tank. But it should also exhibit hard starting, and possible low fuel pressure too.
