Page 6 of 7 FirstFirst ... 4567 LastLast
Results 126 to 150 of 152
Thread: Welding Fixture Table
  1. #126
    Re: Welding Fixture Table
    I am not sure how much shipping for those are to you. If it cost prohibitive, could you just cut off the side with the seam?
    Alternatively, use your hydraulic press to make one?
    Both good ideas. I’ll have to see how long/thick a piece I can form in the press but I’m liking the idea of removing the entire side with the seam.
    IMO $20 for you guys in the USA is a good deal. My cost to Canada with exchange taxes and shipping would be close to double the price.
  3. #127
    Fredericksburg, VA
    You can always try to make a jig similar to how you made the hooks. A "U" shaped bottom die and then a pusher on top.
    Miller Spectrum 625 Plasma
  5. #128
    ATM I’m leaning towards trimming one wall off the square tube.
    Might be easier to make a couple at a time without worrying about repeatability on my bends with the press. Production work isn’t one of my strong suits.
  7. #129
    Since Terry uses quite a few receiver tubes, I thought he might be interested in a few of these mounts and ideas.
    All came from the Trick Tools catalog.
    Thought the same thing when I saw it. Love that catalog!
    I've been pondering a swing-out wall mount for my Jet 2x48 grinder. It'd be nice to have it tucked up against the wall when I don't need it, but still easy to pull out and lock in place when I do need it.
  9. #130
    Pensacola , Fla
    this is how I remove the seam in 2-1/2" tube for 2" to slide inside.
    Hypertherm 65
    Everlast PowerTig 255 EXT
    Miler 180 Mig
    13" metal lathe
    Mill/ Drill
    ECT, ECT,
  10. Likes ronsii, Pontiac Freak liked this post
  11. #131
    It wouldn't fit up under the table as tight, but the receiver I used for the Shorty leg vise came from Princess auto.... it was a 14" weld on hitch on sale for $14 Cdn. Hardly worth messing with tubing for that price. I think regular is around $20 but it's drilled, thick tube, and no welds to deal with.
    https://www.princessauto.com/en/clas...t/PA1000000638
    Cut 50 Plasma
  13. #132
    In the past I’ve bought a length of seamless tube.The same stuff the trailer hitch guys use.
    I needed 2 foot lengths to pass under my 3” top welding table to accommodate heavy situations.
  14. Likes whtbaron, ronsii, Pontiac Freak liked this post
  15. #133
    I have to buy new 1/2”x24” belts for my belt sander. I made the HUGE mistake of buying a box of Klinspoor off eBay.
    They were either way past their “best before date” or stored improperly as the taped splices break easily.
  17. #134
    I wanted mine nitrided but apparently no one in North America has tanks big enough.
    Most are done in Europe and Asia.
    I thought you had to heat the table to 1400 degrees in an atmosphere of nitrogen, CO2, and hydrogen to nitride it?
    Sincerely,
    William McCormick
  18. Likes ronsii liked this post
  19. #135
    These are the guys to use, I buy everything from them and my 6"x 48" belts just keep cutting and so do the 2"x 42" belts.
    https://www.empireabrasives.com/sanding-belts/
    Sincerely,
    William McCormick
  21. #136
    Sincerely,
    William McCormick
    Thanks for the link William but looks like they don’t ship to Canada.
  22. Likes whtbaron, William McCormick, ronsii liked this post
  23. #137
    Sincerely,
    William McCormick
    Not certain. I've had conflicting info in the past. Also heard it is dipped in a tank???
  25. #138
    Try using a hot glue gun on inside and outside joint. I did that with old belts and it helped. I also added a strip of heavy duty Super glue Tape to the inside.
    https://www.hobbylobby.com/Home-Deco...ape/p/80953553
  26. Likes ronsii liked this post
  27. #139
    Thanks Bob I will try the Super glue tape.
    I tried burnishing Gorilla tape strips on but with limited success. Perhaps part of the problem is the narrowness of the belt widths I am working with. (1/2" wide).
  28. Likes ronsii liked this post
  29. #140
    I used it on 1x42 belts. The hot glue made a difference for sure.
    Mine may not have been as old as yours.
  30. #141
    ATM I’m leaning towards trimming one wall off the square tube. Might be easier to make a couple at a time without worrying about repeatability on my bends with the press.
    For what you're trying to accomplish, you could just make up some "staples" from some 2"x1/4" flat bar. The longer tubing is a nice convenience, but if you think about what does the actual holding, it's only the little part right there by the tightening bolts. Instead of trying to bend one piece that's 8" long, you could break it down into smaller pieces that'll fit in your press and then weld them to the underside of the bench. Probably 50% of the standard tube isn't really doing much work as-is.
  32. #142
    Never know until you go for the test drive...
    And something like that you would want to test drive many times, just to make sure or course.
    Sincerely,
    William McCormick
  34. #143
    Good idea forming "staples" for horizontal receivers ......but I need the full tube for most of my vertical installations.
  35. Likes ronsii liked this post
  36. #144
    I was thinking about the "staple" concept as well.... but as usual, thicker and uglier but very sturdy. I was contemplating thick angle iron on the sides with a top plate of welded on flat iron...
    Cut 50 Plasma
  37. Likes Lis2323, ronsii liked this post
  38. #145
    thicker and uglier but very sturdy. ...
    Who you calling ugly?!!!!
  39. Likes ronsii, whtbaron, William McCormick liked this post
  40. #146
    Now now!!! look at the bright side... he did say very sturdy
  41. Likes William McCormick liked this post
  42. #147
    He also said “thicker” but I didn’t notice until I read it a third time.
  43. Likes ronsii, William McCormick liked this post
  44. #148
    lol.... perhaps we should say "rubenesque".
    Cut 50 Plasma
  45. Likes ronsii liked this post
  46. #149
    Here’s my receiver mounted welder stand with patented Lis2323 “tilt and drop” securement tray for Miller inverter welders and plasma cutters.
  47. Likes ronsii liked this post
  48. #150
    Feb 2009
    Coastal NC
    Nice mount Lis,
    Does the plasma have the same footprint as the Maxstar?
    Do you have a Tig set up for that little guy?
Page generated in 1,624,550,503.19367 seconds with 14 queries
