Results 1 to 13 of 13
Thread: Shop Heaters
    Sep 2009
    ocala Fl.
    Shop Heaters
    I sure could use some input from anyone who heats there shop with a Master brand or any other Kerosene / Diesel heaters. I am looking at 140,000 BTU at Tractor Supply. The shop is 24x24. Pict of the shop, this is the area I need to heat. Name:  Shop.jpg
    Miller 252
    Lincoln Square Wave Tig 200
    MM 211
    Red face AC/DC 225 Buzz Box
    Power Max 30
    Sep 2008
    Dalton, GA
    Re: Shop Heaters
    Nice shop.
    Mine is 30’x40’. I’m in north Georgia so cooler than Florida. I tried kerosene and 220v electric but now I use propane with a wall heater. It has a fan to help circulate.
    Seems cheaper and warmer than electric and since I have a large propane tank I don’t have to store and refill kerosene. I use the tank for grill and gas logs in the house. The gas company tops off my tank twice a year. Costs about $65-70 each time. I do not need heat every day but it works well. It is ventless so a little odor but not as bad as kerosene.
    Just a suggestion. You may get tired of hauling and handling the kerosene.
    Burt
    _____________________
    Miller Syncrowave 250
    Millermatic 211
    Miller 375 Plasma Cutter
    Hobart Handler 140
    www.10FtDrillBit.com
  3. Likes Thats Hot liked this post
    Re: Shop Heaters
    I would insulated the building or you will spend a lot on fuel.
    It is only a 576 square foot building it should only at most 60,000 but heater or less..
    If do insulate use a infrared type heating for spot location.
    https://www.harborfreight.com/15000-btu-tank-top-propane-heater-63073.html
    If gets very cold use two this type will outside too. This is type used for 20 years and each heater would use about one tank (4gal) a week.
    Quote Originally Posted by Thats Hot View Post
    Mar 2005
    Under a Rock
    Re: Shop Heaters
    Seeing you are in FL.
    you may get away with just a Hotdawg propane job.... they do pretty good.
    I'm in the north east... I installed a 100K btu house furnace (hot air) in my 22 x 24 2 level garage.
    I am satisfied.
    Hypertherm PM 45
    1961 Lincoln Idealarc 250
    HTP 221
  6. #5
    city of Four Flags
    Re: Shop Heaters
    I have used a propane HotDawg heater for years.
    Works great.
  7. #6
    N 48° 38.680 W 080° 40.837
    Re: Shop Heaters
    My 500 sqft shop is 2"x4" walls, insulated with pink fibreglass, with ply interior walls and 3/4" ship-lap overlaid with steel on the outside. I have 14" of cellulose insulation blown into the attic. I was using a 50,000btu Mr Heater ceiling mounted propane heater with 2x420lb tanks sitting outside for the last ten years. This year I installed a 7500W 240v heater and a small circulating fan as the lead heater in place of the propane. The propane is still there with 2x100lb tanks as backup to the electric heater but it has yet to run. So far I see no difference in either cost or comfort and the electric heater is doing all the work.
    I am at 48.5' north.
  8. #7
    Mar 2015
    Re: Shop Heaters
    I use a radiant deisel heater one of those big round ones works great no fumes no smoke bring something in that is all frosty or snowed on roll it over there and it is all melted off in a hurry
  9. Likes Thats Hot liked this post
  10. #8
    Apr 2011
    minnesota
    Re: Shop Heaters
    That heater will heat that area pretty quick. If you are just looking for occasional use it will suit your needs. If you are looking to maintain a constant temp you’d be better served with something else
    Millermatic 252
    millermatic 175
    miller 300 Thunderbolt
    lincoln ranger 250
    smith torches
    lots of bfh's
  11. #9
    Sep 2009
    ocala Fl.
    Re: Shop Heaters
    Yes.. it would just be for the time I am in there working. Thanks.
    Miller 252
    MM 211
    Power Max 30
  12. #10
    Aug 2018
    'ta town, KS
    Re: Shop Heaters
    We have a wee little vornado fan/heater combo that my wife uses at work, her office is about 8 degrees colder than the rest of the building. Anyway we have used that in the garage this winter just about a 20 minute preheat and you can play Mario Cart on the projector in your shorts. Well as long as your feet are not bare on the concrete. Just a thought, quick cheap heat, one time purchase without reoccuring costs.
    Mac
  14. #11
    Re: Shop Heaters
    If you need a *lot* of heat do what the amazon guys do for the warehouses they work in... get a couple of these 800.000 btu's or they make even bigger ones if you need it
    This one is supposed to run over 40 hours on only 300 gallons of diesel.
    BTW: these are the indirect fired versions so they are safe to use indoors(ducting) without killing yourself the regular direct fired burners NEED a well ventilated area to heat!!! at least if you want to breathe in that area
  15. #12
    Jun 2011
    Eastern Washington
    Re: Shop Heaters
    When my brother replaced his old electric house furnace, I used it to replace the woodstove in my shop(36x60). What a difference. It can be below freezing outside and I can come in, turn it on, and in 20 min. it is 50 degrees. My shop is well insulated, so it only costs about $1.50 a day to keep it comfortable while I am working out there.
    Might look on Craigslist, I often see old furnaces for free there.
  16. #13
    Sep 2016
    Detroit, Michigan
    Re: Shop Heaters
    I don't know if you have an AC unit in the shop, but if not I would highly recommend getting a mini-split with the heat pump option. I use a 30K BTU unit (Mitsubishi Mr. Slim) to heat and cool the 24 x 40 side of my shop. I only cool the shop to the mid-70s in the summer and only heat it to around 60 in the winter to keep the electric bill reasonable...it's surprisingly cheap to run. The only downside is most units with the heat pump will only work down into the mid teens, but that shouldn't bother you in Florida! Even if you don't run one 24/7 they would heat/cool that space very quickly and no carbon monoxide issues, or fuel to deal with.
    http://mivise.com
    Hobart Champion Elite
    Everlast PowerTig 210EXT
  17. Likes ronsii, Thats Hot liked this post
Page generated in 1,713,240,173.04984 seconds with 20 queries
