Results 1 to 13 of 13
Thread: Invertig 221
    Jul 2020
    MA
    Invertig 221
    Hi, I just bought an Invertig 221. I have a Pro pulse 300, I'd like to put them together on one cart. I've already experienced what high frequency can and will do to electronic devices nearby. Cost $800 to replace a board on my brand new LN 25. So can I ground the machine and be safe, or separate carts?
    Haksa
    Re: Invertig 221
    Have you contacted HTP to see what they have to say?
    Jul 2020
    MA
    Re: Invertig 221
    not yet
    Re: Invertig 221
    I have my Invertig right next to my ProPulse 300. Never had any issues, although I suppose that doesn't answer your question. The machine case is grounded via a short ground wire on the inside, granted it is not a separate actual ground path, but still "eventually" is connected to ground.
    Jul 2020
    MA
    Re: Invertig 221
    Thanks Oscar, your th
    Dec 2003
    Fairfield,CT
    Re: Invertig 221
    Look up Jimbo's Garage on YT and IG. He has like 3 or more HTPs together on one cart. He never said he had an issue either.
    www.tjsperformance.com
    Dynasty 300 DX
    HTP 240
    HTP Microcut 380
    Hyperthem 85
    Bpt. Mill/DRO
    4' x 8' CNC Plasma Table
    Instagram: tjsperformance
    Jul 2020
    Re: Invertig 221
    Quote Originally Posted by haksa View Post
    Haksa
    How in the end did you decide to organize your equipment on one frame?
    Jul 2020
    MA
    Re: Invertig 221
    Hi, I been to busy to build a dual cart, that will come later this winter. I was worried about the HF burning up the board in my Pro pulse 300. As I said earlier I had a costly lesson.
    Haksa
    Re: Invertig 221
    How do you like that 300? Its a beast huh? have you ran pulse steel on 92/8?
    Jul 2020
    MA
    Re: Invertig 221
    Hi, Yes I have, with just 75/25. As far as the welder goes, like I told Pete at HTP, It's the best, smoothest, most adjustable machine I've ever used. I've been around a long time.
    haksa
    Re: Invertig 221
    haksa
    IMO it's a bit "smoother" on 92/8, but that's just my take on it.
    Jul 2020
    MA
    Re: Invertig 221
    I can't see how it could be smoother than it is. But I don't need a bunch of bottles around.
    Feb 2015
    Re: Invertig 221
    The PP300 is one of the best all around mig welders I have used as far as arc quality thick and thin, both steel and aluminum. For steel I run C10 on short arc and pulse. The machine has plenty of power.
Page generated in 1,634,495,134.12188 seconds with 13 queries
