Results 1 to 10 of 10
Thread: Lincoln AC225 S
    Feb 2021
    Lincoln AC225 S
    Hi all, my first post on your page... well I can't seem to locate info. using my code: 8712-705 I need DC to use 7018 rod so I bought a 300amp full wave rectifier. will age have any effect on the transformer adding this rectifier? I rarely use this welder only projects in the garage. 1/4in. Fillet welds, Lap Joints. Thanks for your advice.
    Jan 2011
    Hutchinson Kansas
    Re: Lincoln AC225 S
    It would be a lot easier to just buy a box of 7018 AC
    Lincolin Power Wave 450, Lincoln Powermig 255, Lincoln Pro Mig 140, Lincoln Squarewave Tig 275, Miller Big 40 G(with Hobart Hefty suitcase), Thermal Arc 95S and Esab PCM875 in an already full machine shop.
    Big Lake/Monticello MN
    Re: Lincoln AC225 S
    Quote Originally Posted by propanehotrod View Post
    I was thinking the same
    Syncro 350
    Feb 2021
    Re: Lincoln AC225 S
    I watched a guy weld using AC 7018 Rod on his Lincoln AC225. after he installed a Rectifier and welded it was a big difference, the flow was better, less splatter as well. I was mainly trying to find info. on my code. the video was on YouTube. thanks
    Ceres, California
    Re: Lincoln AC225 S
    You will need an inductor to go with the rectifier to stabilize the DC arc and a noise suppressor. Using the AC rod will be a lot cheaper.
    I have an old 300 amp Glen stick welder that has higher OCV. It burns anything I try.
    and welds great. Have used it to repair a lot of farm equipment.
    Aug 2019
    Re: Lincoln AC225 S
    Quote Originally Posted by rogagogo View Post
    Agree with others. DC is desirable for other rods. But why 7018/14? Why not 6011? Maybe 6013? 1/4 mild steel will weld fine w both rods
    Returning to your OP, your question re ‘age on transformer’ makes little sense to me. Perhaps you can clarify.
    Aug 2019
    Re: Lincoln AC225 S
    ...so I bought a 300amp full wave rectifier..
    Are you fully prepared for the buildup to convert your buzzer to DC? There are many builds on WW you can search. I have found several consistent issues w this type of build. Most buy this 25$ rectifier and think it done. But the rectifier alone is only part of the system. Most ignore and subsequently fail upon the thermal considerations. You’ll need a choke of considerable inductance. This will need to run the secondary current so the windings must be sized accordingly. Lastly you’ll need to rework your cabling with dinse or other swappable connectors to switch AC DCEP DCEM.
    It’s a fun DIY project for sure. If done correctly I think a DC conversion really doesn’t save money if you are considering your time as money.
    Regards
    Jun 2014
    Southern Illinois
    Re: Lincoln AC225 S
    It can be done but I would suggest buying a Miller Dialarc 250 or Lincoln Idealarc250 and be done with it. Nothing experimental about those machines. Unless you just want to do a conversion project.
    Steve
    Miller Dialarc 250 (1990)
    Miller Maxstar 140 STR (2003)
    Lincoln MP210 (2015)
    Victor and MECO torches
    Re: Lincoln AC225 S
    Is this the smaller counter top AC 225S? Not worth even trying to convert it to DC.
    Re: Lincoln AC225 S
    Quote Originally Posted by Sparkie1957 View Post
    Yep, and either can be had for under $300. Sometimes near $200.
    Excellent machines that weld much better than a converted 225 AC machine, or their 225 AC/DC machine.
    I have 2 of the little lincolns in the student classroom. They work, but they are unimpressive on DC when compared to Dialarc or inverter machines.
    Syncro 350
Page generated in 1,713,268,435.70017 seconds with 18 queries
