Page 3 of 3 FirstFirst 123
Results 51 to 58 of 58
Thread: Second 2" X 72" Belt Grinder Build
  1. #51
    Re: Second 2" X 72" Belt Grinder Build
    Have fun which ever way you go great project and tool for your shop
    Yes, thanks much. My motor will be placed below the surface where the grinder mounted on, by using a pulley/shaft and pillow block bearings. Still waiting on parts to arrive, but I will post pictures of the project when I get started.
    Will
  2. #52
    Pensacola , Fla
    Ah yes more info reveals for your reasoning, non-rotational grinder now make sense. Have fun
    Tom
    Hypertherm 65
    Everlast PowerTig 255 EXT
    Miler 180 Mig
    13" metal lathe
    Mill/ Drill
    ECT, ECT,
  3. #53
    more images.
    Is the plastic container for keeping the VFD clean?
    If it is spec'd IP 66 the enclosure is dustproof.
  4. #54
    Pensacola , Fla
    yes that is what I am aiming at, these grinder produce a lot of metal dust and that's not good for electronics. Since my grinder is portable the VFD is attached to the cart.
    Hypertherm 65
    Miler 180 Mig
    13" metal lathe
    Mill/ Drill
    ECT, ECT,
  5. #55
    That's what I thought. Great build(s)
  6. #56
    Quick question. I usually simply tack weld "standard" nuts to the steel, but here you appear to be welding a round & threaded cylinder?
    Name:  Screenshot 2021-05-03 12.01.50 PM.png
    Name:  Screenshot 2021-05-03 12.04.12 PM.png
    Can you please share "what" what is?
  7. #57
    Pensacola , Fla
    It is a 3/4" steel rod cut in short lengths drilled out to 5/16" then taped 3/8"X16 after welding. I found many time welding a nut on you still needed to run a tap through due to shrinkage. I also generally tap the metal I weld the rod to at the same time for a longer threaded hole.
    Hypertherm 65
    Miler 180 Mig
    13" metal lathe
    Mill/ Drill
    ECT, ECT,
  8. #58
    Nice - thank you. Yes, I get your point about shrinkage - out of the 5x I recently Tig'ed, 2 got "really" tight!
Page generated in 1,624,279,903.90341 seconds with 12 queries
