Results 1 to 15 of 15
Thread: Baby Chinese Inverter Welders
    Mar 2015
    NW Florida
    Bought one of these little China inverter welders just to see what they are about. I must admit that so far I am pretty amazed. I used it to build some mounts for the front end loader I put on a tractor of mine. Burnt several 3/32" 6013 rods. I have no doubt it will burn 1/8" rods OK too. For less than $100 it is nice and portable. Sometimes I just can't get to my old transformer welder in the shop.
    Craftsman 230/140 AC/DC Miller HF-251D-1
    Millermatic 130 Linclon 40 amp plasma cutter
    Hypertherm Max 20 O/A cutting and welding stuff
    5HP Ingersoll air compressor
    Laredo + Midland/Odessa
    Re: Baby Chinese Inverter Welders
    Yeap, I still have my Tooliom 135S 4lb inverter stick welder. It will run 1/8" 6011s, and just barely enough grunt for 1/8" 7018s @ ~112-115A. Cute lil bugger. Is yours on 120V or 240V?
    Mar 2015
    NW Florida
    Mine is 240 volt. I have a 10,000 watt generator I can hang off the back of my tractor so I can weld anywhere on my property.
    Yea, they do become quite gut-less on 120V because the arc voltage really shoots down. On 240V, they're not all that bad for basic portable welding.
  6. Likes ronsii, hdonly0 liked this post
  7. #5
    Mar 2015
    NW Florida
    In between all the rain and cold, I got my loader on the tractor. Little "Baby Welder" did a surprising good job.
  8. Likes R&I, Shootr liked this post
  9. #6
    Feb 2021
    Is that a 600 or a 800...love those things!...Michael
  10. #7
    Mar 2015
    NW Florida
    Quote Originally Posted by R&I View Post
    It is an NAA/ 1953 Jubilee. I have a 1960 651 Workmaster also.
  11. Likes R&I liked this post
  12. #8
    Jan 2005
    The little bit better 120 volt China inverters do quite well on 120 volts.. I liked the little Ironton from Northern tool.. You can't throw all the machines in the same boat on 120 volts..The very bottom feeders do suffer on 120 volts.. If you stick with 3/32 rod in 7018, some run the same as on 240 volts..
    Blue Demon 140 MSI
    Blue Demon 200 AC/DC
    Esab 160i caddy
    Esab CV353
    INE 1500
    Lincoln 250 Idealarc
    Thermal LM-200
    Thermal 60i- 3phase
    Thermal 15c
    Topshak 40 plasma
    Miller Regency 200/LN-72
    Viking 250 mig/2410 feeder
    Weldcote 140
  13. #9
    Mine runs a little cooler on 120V, but it still runs well.
  14. Likes ronsii liked this post
  15. #10
    Jul 2016
    Midwest
    Some of the little 160 amp category 120/240 units with PFC do a nice job on all electrodes 5/32 and under on 240v. 1/8 and under on 120v.. Very impressive on extension cords and genertors even on 120v.
    Thermal Arc 320SP ( Lorch )
    Cobra Pythons
    ESAB 301i AC/DC ( Lorch )
    Thermal Arc 161STL ( WTL )
    Thermal Arc 190S ( Sanrex )
    Victor Gas Apps.
  16. #11
    Jan 2005
    I have yet to find one better then my 240 only small INE unit.. It a step above the Thermal 161s for sure..Jim, has one, and it a lot nicer then his Esab 161i He also had my Old Sanrex TS-160,The Thermal does not have the output of the Esab on 120 volts, but it's still a better machine running both with 3/32 7018 rod.. I am still shocked how some of the cheaper 120 volt only China machines run.. I think my Thermal LM-200 still might be my favorite,very easy to set the arc force for major differences in the arc type. having a 0-100 scale is simple, and effective. It's pretty much the same as a MST-400, just less output, and better with smaller wires
    Blue Demon 140 MSI
    Esab 160i caddy
    Esab CV353
    INE 1500
    Thermal LM-200
    Thermal 60i- 3phase
    Thermal 15c
    Topshak 40 plasma
    Weldcote 140
  17. #12
    Jul 2018
    Cumbria, UK
    My uncle bought one very similar to the one in the OP. It didn't even have an earth wire.
    He used it for roughly 2kg of rods before it died the other day.
    You get what you pay for...
  18. #13
    Feb 2021
    Quote Originally Posted by hdonly0 View Post
    I have a 1955 860 that was used(hard) at a junkyard....took some work to bring it back from the dead but boy they are handy!! I got lucky and got the live pto...
    What is that on the back of your NAA?
  19. #14
    Yup, it almost always holds true!
  20. Likes Munkul liked this post
  21. #15
    Mar 2015
    NW Florida
    That's my "Baby Backhoe"Name:  Done.resized.jpg
Page generated in 1,713,263,035.73098 seconds with 20 queries
