Results 1 to 18 of 18
Thread: How do you secure your welder down on mobile?
    Jan 2021
    I have a older Hobart Champion 16. I have requested a manual from Hobart, as their website doesn't acknowledge my serial#
    My question is how you secure them on your truck or trailer. I know plenty are gravity secured with angle iron on the corners, but this unit's back battery cover goes fully to the bottom, so cannot slide out battery unless one lifts unit.
    Thanks
    Sep 2020
    South Texas
    Re: How do you secure your welder down on mobile?
    Bolt it down.
  3. Likes MinnesotaDave liked this post
    Jan 2021
    Quote Originally Posted by Joegreen02 View Post
    Bolt it down.
    Thanks. I was wafting for my Hobart manual. It was sent right after you replied and that's what it also said.
  5. Likes Joegreen02 liked this post
  6. #4
    Make a skid for it so it's easier to bolt in place and take out when necessary. A skid could be designed so the battery can be slid out and also have somewhere to wrap the cables.
  7. #5
    Plus 1 on the skid mount
    Gotta look pro pulling up at the job sites. Show 'em why you charge the big bucks
  8. #6
    McGregor, Iowa
    I second the skid. Makes keeping it out of the weather easier. Just take it out of the truck and stick it in the shop.
  9. Likes sedgehammer, whtbaron, ronsii, snoopdogg liked this post
  10. #7
    Jan 2021
    thanks for everyone's post.
    I was thinking same. After I get the trailer done, i'll get the welder in the shop and see what the bottom lottom looks like. Prolly will be some flat plate. i have plenty to spare.
    To you other 2, them's nice, but I'm just welding for meself.
  11. Likes Lis2323 liked this post
  12. #8
    Here's my Miller 302 Trailblazer setup. I made a cart for inside roll a round use and then modified a smaller trailer to accommodate it by setting complete setup on trailer.
    Once set I add four bolts to secure . It really works great and made a drop on bed for trailer too.
    https://weldingweb.com/vbb/showthrea...ailblazer+cart
  13. Likes sedgehammer liked this post
  14. #9
    Quote Originally Posted by sedgehammer View Post
    Same
  15. Likes sedgehammer, ronsii liked this post
  16. #10
    Jan 2021
    Yeah, thanks, wasn't thinking on that. if one removes the welder/skid, nice if cables come along......
  17. #11
    Vertical receiver mounted cable hangers.
  18. Likes whtbaron, Pipeliner, ronsii, mcspeed, Munkul liked this post
  19. #12
    Jan 2021
    That's nice in more ways than 6!
    Me bride even liked it.......
  20. #13
    Apr 2020
    I try to rubber mount it one way or another so it dosent rattle the truck any more than it has to
  21. #14
    Hockey pucks work good for vibration mounts.
  22. #15
    Thanks
    I have the same problem with my Lincoln. The battery cover can't be removed due to the design of my skid. I have to lift the welder every time I change a battery.
    Mine's bolted down through the holes provided on the bottom the welder. The only problem (battery) is that the rear access cover is butted up against a strongback, and gusset, on the skid frame. I thought of leaving out he reinforcements, but it's a skid designed for the 3pt on a tractor, so it's pretty bouncy when running over rough ground.
  23. #16
    Must be an Albertan thing. I incorporated that idea after hearing of its use from one. LOL.
    Pucks sit in the bottom of the four square tube sockets.....
  24. Likes ronsii liked this post
  25. #17
    Big Lake/Monticello MN
    When I sold my SA-200 to a pipeline guy, he had me set in on the bed behind the cab (right on top of a cargo strap).
    Then he fired it up and used it to weld the welder to the bed...
    I guess that's a welder welded welder to a welding bed.
    He also had a big hole cut in the back of the cab for access to that side of the machine...
    Syncro 350
  26. #18
    That's a redneck hack that welds their machine down.
Page generated in 1,713,293,169.46655 seconds with 19 queries
