Results 1 to 8 of 8
Thread: "Reversing" Harris Flowmeter Fittings
    Apr 2012
    socal
    I picked up a Harris model 355 flowmeter. I cant use it without doing a lot of changing things in my welding area. Well, I can, but the (tank) pressure gauge would be facing the wall. In view, outtput side would be about ½" away from the garage door hinges. this bothers me. The gauge sticks out a little past the side of the (125 cf) bottle.
    My question is:
    Can I simply take the input/output fittings & swap them?
    Theres no place/opening, threaded or not, on the back.
    It will be for argon.
    The tube/pellet/indicator is easily turned to where ever I want.
    I'm just asking before taking it apart.
    Its not a rush, I have a regulator type guage that came with the welder. (Thermal-Arc TA-185)
    -corne-
    What is the sound of one knee jerking?
    Re: "Reversing" Harris Flowmeter Fittings
    You would have to post a picture at least. The flow gauge is the low pressure side, gauge high pressure side. I would say no.
  3. Likes CAVEMANN liked this post
    Mar 2015
    Milwaukee, WI
    You could replace the back stem high pressure gauge with a bottom stem one. When you flip the flowmeter around, you'd be able to see the tank pressure looking down. Not ideal, but I can't think of many options you have. Usually you use that gauge only occasionally to check for adequate supply.
    Feb 2009
    Chicago
    I tried this on mine, you can't do it. I forgot why, either flow was directional or some other internal issue. Some places sell the same flowmeter with them reversed for this reason
    Hypertherm Powermax45
    Esab ET220i
    Razorweld 195 Mig
    Razorweld 200ac/dc Tig
    Tormach 770, Tormach xstech
    Carbide3d Nomad3
    Sherline 4400 CNC Lathe
  6. #5
    Sep 2005
    Cave Creek AZ
    Can you swap the location of your blow pipe and chanter and still play Steam Train to Mallaig? No, you can’t.
  7. Likes Xsbank liked this post
  8. #6
    Jul 2016
    Midwest
    Inlet Outlet swap is a No. You can spin the gauge out and install a 90 degree fitting or similar. Or a 45 or 90 on the inlet but it needs to be a high pressure elbow. 4K #s to be safe. Western Enterprises or Superior have these.
    Thermal Arc 320SP ( Lorch )
    Cobra Pythons
    ESAB 301i AC/DC ( Lorch )
    Thermal Arc 161STL ( WTL )
    Thermal Arc 190S ( Sanrex )
    Victor Gas Apps.
  10. #7
    Jul 2016
    Midwest
    Quote Originally Posted by cornemuse View Post
    My question is:
    -corne-
    The problem with switching inlet / outlet is that your high pressure would come in on the wrong side of the needle and seat. It would likely blow the flow tube.
    Cobra Pythons
    Victor Gas Apps.
  11. #8
    Apr 2012
    socal
    Thanks to all, I will live with it.
Page generated in 1,713,255,858.95929 seconds with 19 queries
