Page 2 of 2 FirstFirst 12
Results 26 to 31 of 31
Thread: How clean is clean enough for TIG welding?
    Aug 2019
    northeastern PA.
    Re: How clean is clean enough for TIG welding?
    what machine are you using? We don't know what parameters you have set up on the machine or even available. I'm wondering if you have the machine inadvertently set for a/c on one of the adjustments and the balance is upset. Is the machine new or new to you? Can you verify the gas flow at the torch? Is your shielding gas 100% argon?
  2. Likes shovelon liked this post
  3. #27
    SoCal-LA
    Crushed collet.
  4. #28
    Dec 2015
    I'm using an AHP AlphaTig200x, 140 max amps, DCEN, using the pedal
  5. #29
    SoCal-LA
    Quote Originally Posted by Pcmaker View Post
    Yep, crushed Chinese soft copper collet. Check it. In fact pull the front end off and see if your back cap is chocking off the gas hole.
  6. #30
    SoCal-LA
    Also when I was beta testing the Alpha Tig I burned up a couple of power cables. The lugs got loose and cause not only the wires to get hot but the rubber was outgassing fumes causing fouling of the weld and electrode.
  7. #31
    Dec 2015
    I need help choosing a good torch, cable, etc.. that will fit my welder. Something that you can put one of those clear pyrex cups on
Page generated in 1,624,346,481.32011 seconds with 12 queries
