Results 1 to 9 of 9
Thread: Which Everlast welder should I buy?
    I currently have an AHP AlphaTig 200x TIG welder that has served me well for 5 years, but it's been having issues
    I figure I'd get a new Everlast welder. I have 220v access and I mainly TIG weld steel, but sometimes do stick 6011 or 7018. I'd like the ability to TIG aluminum and I mostly have max amps set at around 130. I'm thinking the 210 EXT?
    Do these welders come with evrything, torch, pedal, etc? Do they have the superflex cable?
    Nov 2013
    Re: Which Everlast welder should I buy?
    If Aluminum is in your future, I'd consider paying the difference for a 250A machine (or you're going to limit yourself to 1/8 or maybe 3/16). Alum just sucks-up those Amps
    As far as I know, their machines come with those accessories but they have their own line of "SuperFlex" like torches and that's probably not going to be what's in the box...
    Nov 2008
    Yes, if you buy direct from us, you get two torches, a pedal, regulator, work clamp, stick torch and small consumable starter kit. As well as a 240 to 120V adapter.
    You can upgrade to a better package, and we can custom assemble you a package if you call in direct. If you'd like to get one, let me know. 877 755 9353 ext 204.
    I'd look at either the 210EXT or the 255EXT (for more power, additional wave form, spot timer function, better stick welding capability).
    Esab Migmaster 250
    Lincoln SA 200
    Lincoln Ranger 8
    Smith Oxy Fuel setup
    Everlast PowerPlasma 80
    Everlast Power iMIG 160
    Everlast Power iMIG 205
    Everlast Power iMIG 140E
    Everlast PowerARC 300
    Everlast PowerARC 140ST
    Everlast PowerTIG 255EXT
    Jul 2020
    Quote Originally Posted by Pcmaker View Post
    Pcmaker - any updates on which way you are leaning or which unit you bought?
    I bought a new mill so the welder has to wait awhile
    Sep 2016
    Detroit, Michigan
    Just an FYI, but Everlast and AHP are located in the same building...pretty much dealing with the same company. I own a 210EXT and it's a nice machine, but it's not really meant for thick aluminum. You'd be happier with a 250A machine if you plan on doing anything 1/4" thick on a regular basis.
    http://mivise.com
    Everlast PowerTig 210EXT
    Nov 2008
    Learn to use the Advanced AC pulse It'll soar over 1/2".
    Esab Migmaster 250
    Lincoln SA 200
    Lincoln Ranger 8
    Nov 2008
    Learn to use the Advanced AC pulse It'll soar over 1/2"...
    Esab Migmaster 250
    Lincoln SA 200
    Lincoln Ranger 8
    Nov 2013
    I have to say,,, when my old PP256 crapped-out and was replaced by a 255EXT, that Advanced Square Wave really did make a noticeable difference in thicker aluminum.
Page generated in 1,624,502,630.21281 seconds with 13 queries
