Results 1 to 25 of 25
Thread: No weld storage rack
    Made this to hold Harbor freight storage cases. These were pretty much a disaster of cases piled on top of each other. Used 1"x12" pine for the sides. 1.25x1.25x1/8" aluminum angle for slides, fastened with #8x3/4" stainless steel truss head screws. Used some 3/8" plywood for the back. Name:  IMG_20210219_195235977.jpg
  2. Likes ronsii, Lis2323, N2 Welding liked this post
  3. #2
    Re: No weld storage rack
    Painted it with rust-oleum charcoal gray. It holds 18 of the 2" high cases and 4 of the 4" high cases, which I need 2 more. Roughly 3'x 3'.Name:  IMG_20210221_181139993.jpg
    That definitely looks like it organizes those cases good I like it!!!
    Looks like more and more welding people are going to switch to wood with the price of steel going up daily!!!!
    This was just leftover stuff I had laying around. Obviously the cases are the most expensive part, but yeah probably 25$ or so worth of wood. I believe I used about 35-40' of aluminum angle .
  6. Likes ronsii liked this post
  7. #5
    LOL!!! just pulling your chain a little
    I actually have one of those cases... but the first time I used it one of the clasps broke just unlucky me I guess
  8. #6
    There not the most robust. I think they will hold up ok for my uses, bouncing around in a truck, not so much.
  10. #7
    Mine broke just trying to close the latch!!! had a similar thing happen to one of the HF 10 dollar black n yellow tool boxes... broke the plastic lip right under the latch first time I tried to latch it.... so I picked one of the HD 10 dollar orange homer boxes up basically the same size - but has a regular steel loop cam type latch!! works every time
  11. #8
    Mar 2004
    hueytown, ala
    MJD
    mine isn't as professionally built as yours, if fact it's built at two different times. I had to have a labels on boxes, How many boxes do you pull out before you find what you are looking for ???
  12. #9
    Sep 2008
    Dalton, GA
    Wow jniolon! How often does the maid come by?
    That’s a beautiful shop but mine never looks so clean. I’m jealous. So well planned and organized.
    What’s in those card catalogs? Looks like a good idea.
    MJD - good project as usual. Looks a lot handier than mine. I keep stacks of 4 on a shelf but always need the bolts in the bottom one. I may try your idea.
    I enjoy seeing others’ shops. Always good ideas and projects.
    Burt
    _____________________
    Miller Syncrowave 250
    Millermatic 211
    Miller 375 Plasma Cutter
    Hobart Handler 120
    10FtDrillBit.com
  13. #10
    The plan is to purchase a label maker or at least a silver sharpie to label them. As of now there are no misc. ones. I need to label them like" SHCS 8-32 _ 5/16x 18" or " 3/8x16_ 5/8x 11". So in that instance I can narrow it down to which box. Before was a chore just getting to the box I needed.
  14. Likes ronsii liked this post
  15. #11
    I have similar cabinet as jniolon under my workbench, which is another good storage option. One of my next things to make is a rack to hold tig filler rod tubes.
  16. Likes ronsii liked this post
  17. #12
    Mar 2004
    hueytown, ala
    wb4rt !! de wb4pjy
    not card catalogs but bolt drawers and the letter files to the left of them for misc fittings, metal stuff, etc
Size:  118.1 KBName:  n&b storage 001.jpg
Size:  70.8 KBName:  nbstorage007.jpg
  18. Likes psacustomcreations, Lis2323 liked this post
  19. #13
    Mar 2004
    hueytown, ala
    wb4rt
    several years ago when I started my truck project I wanted to increase my shop coverage on my insurance by several thousand dollars to cover truck in progress and parts, etc. My insurance man came out and was overwhelmed. He suggested I make pictures for claim purposes should I ever need them... I did a whole group on just tools and this one on shop general pics... gave them to him on a flash drive... these show come more of above...
    https://jniolon.classicpickup.com/to...p/shoppics.htm
  20. Likes Broccoli1 liked this post
  21. #14
    Dec 2015
    I think I got a little chubby going looking at all that organized stuff..
    As I look through my assorted bins of hardware
    Sent from my SM-N960U using Tapatalk
  22. Likes snowbird liked this post
  23. #15
    I did have to weld the bases on my bolt bins. Bending over looking for sh*t gets old, when yer gettin' old
    SAE UNC below. Stainless steel UNC in gray bins.
    SAE UNF below
    Miscellaneous and metric fine and coarse thread. I might get it organized before I die. Maybe not.....
  24. #16
    When you see a guy with a hose clamp organizer shelf... it's time to through in the towel.. because there ain't no way I'm ever gonna get that organized
  25. Likes wb4rt, snowbird liked this post
  26. #17
    I have an old Ideal brand one. I'm far from really organized though. Pole barn spikes are a good alternative, plenty of length to really make sure you have to remove at least 20 to get at the one you need.
  27. Likes ronsii, snowbird liked this post
  28. #18
    Yeah, I use gutter spikes and for lots of things too
  29. #19
    Well it's nice to see you've moved on from giving me grief about the Ranger.....
    And FYI not all the hose clamps are on a rack.
  30. Likes ronsii liked this post
  31. #20
    Apr 2016
    CA
    Huh? Have you looked at the price of woods lately?
    2x4s $5+ 4x8 OSB $30+ O.o
  32. #21
    I think you'd need a card catalogue when you have zillions of bins and parts like that.
  33. #22
    2x4’s $5+ 4’x8’ OSB $30+ O.o
    Yep, we had to get a sheet of a/c plywood the other day
  34. #23
    Yeah, I have to pick up 8 sheets of 1-1/8" tongue and groove subflooring for a trailer deck tomorrow... EEK is right.
  35. Likes ronsii liked this post
  36. #24
    Did you apply for your second mortgage yet....
  37. Likes 12V71 liked this post
  38. #25
    Nah... We'll just see how long Lowes is willing to float me.
  39. Likes ronsii, Lis2323 liked this post
Page generated in 1,624,076,451.05547 seconds with 13 queries
