Page 2 of 2 FirstFirst 12
Results 26 to 48 of 48
Thread: Brush mower
    Soda springs,Id
    Re: Brush mower
    Quote Originally Posted by arcflash View Post
    Did you read the thread? The cutting unit will be powered by an 18-1/2 hp as called out on first post.
    Sorry, my mistake!!
    Ol' Stonebreaker
    Hobart G-213 portable
    Miller 175 mig
    Victor O/A setup
    Makita chop saw
    Feb 2010
    Bandera,TX / MN
    Re: Brush mower
    Back to the question at hand. What size blade mounting bolt?
    Re: Brush mower
    I think my 5 footer has 1-1/4 on each blade..... I run an old english 20hp diesel for doing up to 5-6 inch trees/roots/saplings it's a mite underpowered and I do NOT have a slip clutch on it... so when it gets overloaded or bound it just kills the motor
    Mount Tabor VT
    Re: Brush mower
    My Bush Hog 105 is very old. It is considered a medium duty hog. I believe the blade bolts are a very high strength 1-1/4 the blades pivot on. I'd guess each 18" long blade is 10 LBS. Manual specs 450 Foot pounds of torque on them & something like 1000 for the main nut holds the stump jumper to the shaft. I've never lost a nut, but the main shaft broke a few times.
    The tractor I powered it with for 33 years is rated at 39 HP at PTO. I did twist the internal (inside the transmission) shaft. Had to replace.
  5. #30
    Feb 2010
    Bandera,TX / MN
    Re: Brush mower
    These blades come in at 12" and 6 lbs. If I need to add a torque tamer in the drive that wont be a problem. The shaft will be tied to the sprocket with a power lock hub.
  6. #31
    Sep 2012
    Wheatland, Wyoming
    Re: Brush mower
    With the size you want to shred it would be much quicker and safer to rent a mini hoe and dig them out, pile them up and burn baby burn.
    Chris
    Auction Addict
  7. #32
    Re: Brush mower
    Ran across this on another forum...Name:  uufFfgr.jpg
  8. Likes ronsii liked this post
  9. #33
    Re: Brush mower
    I like it!!!!! I like it a lot
    You do have to be a bit careful with those newer small engines as they shrunk the shaft a bit so it's really easy to shear them off have lost more than one myself just by regular brush/rock mowing
  10. Likes 12V71 liked this post
  11. #34
    Mar 2009
    Carnegie, PA
    Re: Brush mower
    I like the idea. It would make a devastating brush cutter if you would do that to a gravely walk behind with a saw blade on a 30" mower.
  13. #35
    Jul 2013
    Re: Brush mower
    Quote Originally Posted by WFM View Post
    Gravely had a saw blade option, limited guarding, it was rated to cut something like 8" trees.
  14. #36
    Feb 2019
    Snyder TX
    Re: Brush mower
    I have an old Jari Monarch sickle bar mower. When it is tuned up it will out mow any rotary mower out there. 8' weeds? No problem. 1 1/2" trees & shrubs? No problem, it will mow them as fast as you can walk.
    Sickle bar mowers are not being sold anymore in US as far as I know, but if you can design one with combine parts, you will be a mowing dude!
  15. #37
    Feb 2010
    Bandera,TX / MN
    Re: Brush mower
    Those JARI's where made in Little Falls MN 50 years ago. I got to know the plant manager and got leftovers from the production run.
  16. #38
    N 48 38.680 W 080 40.837
    Re: Brush mower
    Quote Originally Posted by cwby View Post
    I have a small collection of Gravely sickles to go with my power unit. Those Gravelys are getting old, but they are tough!
  17. Likes 12V71 liked this post
  18. #39
    Re: Brush mower
    I have a Solo Combi sickle bar mower that the engine can be used on other attachments. It uses a clutch that doesn't engage until you throttle it up. The 2 cycle engine twists on and off in about 15 seconds. Sadly I don't have the engine anymore so need to adapt something else. Rented a Jari once and the Solo was much better. The biggest problem with the Jari was that it was way too fast to walk behind, especially on uneven or unknown ground. If the ground was soft the narrow wheels would sink in. The Solo had small pneumatic lug type tractor tires and a more controllable walking speed. The video above confirms the Jari is too fast. What if the operator stepped in a hole or something?
  19. #40
    Apr 2014
    MN/WI
    Re: Brush mower
    They are still sold, but not made in USA. I bought a BCS 2 wheel tractor and there are sickle mower options for it :
    https://www.bcsamerica.com/product/d...ckle-bar-mower
    Lincoln Idealarc TIG-300
  20. #41
    Re: Brush mower
    Quote Originally Posted by bead-boy View Post
    Those BCS sickles have been around for a long time. Even though they're made in Italy and not N.A. they've proven to be decent units.
  21. #42
    Re: Brush mower
    Anybody remember the old David Bradley walk behinds? My Great Grandfather had one with just about any attachment you can think of including the sickle mower.
  23. #43
    Re: Brush mower
    Yup, still see those for sale the odd time.
  24. #44
    Re: Brush mower
    Quote Originally Posted by John Bartley View Post
    I wish I would have grabbed it when he passed. He used to haul us kids around on a wagon/cart behind it.
  25. #45
    Re: Brush mower
    I see 5-6 of em' a year on CL when I'm looking for other things tractorwise... so there's probably a few more that I don't see cause it's not like I'm on the computer everyday looking
  26. #46
    Feb 2010
    Bandera,TX / MN
    Re: Brush mower
    I have a lot of attachment for my bradley but not the sickle mower. Maybe I can find one of those to rebuild too.
  27. #47
    Feb 2019
    Snyder TX
    Re: Brush mower
    Hard to find the sickle blades that fit. Standard hole spacing on ag blades is 2" or 2 1/4". The Jari blades are 1 3/4" IIRC. I wish I could find replacements that fit - my bar needs to be rebuilt.
  28. #48
    Re: Brush mower
    Check with a Gravely/Ariens dealer, preferably one that's been around a while. As I recall the Gravely bars were also a closer hole pattern/spacing than conventional ag.
Page generated in 1,624,523,283.67968 seconds with 13 queries
