Page 2 of 5 FirstFirst 1234 ... LastLast
Results 26 to 50 of 114
Thread: How would you repair this crack in aluminum tube?
    Re: How would you repair this crack in aluminum tube?
    I don't think you have enough experience to attempt the repair. Aluminum is a way different animal than steel. It doesn't turn red hot for one thing, you just all of a sudden have a big hole where it melted and dropped. I would suggest having someone experienced with aluminum take a look. If you can clean it really good maybe an epoxy could be used as a temporary fix until it could be replaced.
  2. Dislikes Brazin disliked this post
  3. #27
    Quote Originally Posted by Noidea87 View Post
    I run a crew that maintains the equipment on these. We do own it, our engineer designed it and then it was fabricated and installed. This would be a fix to keep it going a while until we can replace it. Basically keep it from getting worse
    Sounds like the repair method should be dictated by "our engineer who designed it."
  4. Likes metalman21, William McCormick liked this post
  5. #28
    Nov 2014
    Southern CT
    Usually if tubes are damaged by water freezing the tubes are bulged out.
    Ernie F.
  6. Likes ronsii liked this post
  7. #29
    Feb 2019
    Snyder TX
    Then get your engineer to design & specify the repair procedure. That why he makes the BIG bucks!
  8. Likes William McCormick, Saburai liked this post
  9. #30
    I don't disagree, but I would plan to practice before I attempted it. That's why I didn't really want to cut the whole beam out and weld it in. I feel pretty confident I could practice and then weld in a piece of angle, or weld up the crack though. These pictures are from a year or so ago so this repair probably won't even be attempted until this summer so I'd have time to practice with aluminum before we make the trip over to the area to repair. Once I had a repair plan I would get some aluminum scrap and mock up some things to practice with in our warehouse.
    We have a Miller 211 autoset
  10. Likes ronsii liked this post
  11. #31
    Jul 2020
    i am not very experienced but if it was me i would c clamp that thing back into place grind a bevel down into the crack, weld it back, grind it back flush, and weld a solid plate over top of the repair to give it some backbone. not sure if thats a good idea just my best guess.
  12. Likes ronsii, shovelon liked this post
  13. #32
    Aug 2018
    'ta town, KS
    If it is a temporary fix... get some al angle beat the crack closed and weld the angle over the aforementioned section... I would use 2x2x1/4 minimum stitch weld all the way around. That should buy some time until the "Fix" is completed.
    Mac
  14. #33
    Quote Originally Posted by Mac's Crew View Post
    So stitch weld instead of full weld all the way around the edges? I thought i read somewhere a stitch weld was stronger but that didn't make sense to me. Is there a reason for the stitch?
  15. #34
    Aug 2018
    'ta town, KS
    Warping... it will move, just like steel. And welding changes the temper of the metal around it. Al gets gummy as it goes closer to O material. So the areas directly around the welds will be where the next failure will be... 100% weld you can but personally I would not.
    Mac
  16. Likes Noidea87 liked this post
  17. #35
    That makes sense. Thanks.
  18. #36
    May 2007
    if that access hole allows u to slip some backing strips in behind crack(s) (even butting small pieces together - 6061 angle), id v/prep it out generously w/ good sized holes/radius at ends. that would give u excellent penn w/ ur 5356. burning into that backing and filling the valley will be easy/forgiving for u begginer tack in backing to both sides of bevel every so many inch's so it dont open from heat and feather them out. preheat all round it, as u might already know heat runs/sucks quick w/ alum. even a couple of them 20 dollar propane/etc bottles w/ screw on heads for plumbers to warm that puppy up is better than nothin. is that the coranado bridge in the background? i used to stay at hotel corando whn i was a kid. there aint no freezin down there, the closest thing u guys could get to a freeze is a slurpy from 7-11
  19. #37
    So cut some small strips of 6061 and tack it inside the crack, then weld over that? We have a oxy/acty rig we could preheat the area with if that would help. This is in LA as in Louisiana so yeah not much water freezing haha, but it does occasionally happen.
  20. #38
    I don't want to be a downer but if it needed to be designed by an engineer you don't have the required skill or experience to even attempt a weld repair. Have someone experienced have a look it. It's not a DIY project for a beginner. It's going to be very dirty being out in the elements, especially being so close to the water.
  21. Likes shovelon liked this post
  22. #39
    May 2007
    yea, if u can slip them inside somehow through that acces hole and hold in place while u tack (get creative) . that would be the way to go. that way u get full penn, and everything ties together. oxy acet should be ok, just make oxidized flame /over oxygen, and hold it back some from workpiece, cuz that acet/carbonizing don't help alum any, but yes use it. o, that LA, lol, ok
  23. #40
    Los Angeles
    You better practice OUTSIDE yer warehouse- the wind is gonna give you fits when you go to weld it in place
    MM211 (Sold)
    Klutch 120v Plasma cutter
  24. #41
    May 2007
    he wants to learn, and doing new things "hands on", is how u learn. u ought to try it urself sometime
  25. #42
    haha that's a good idea. I plan to set up some type of wind break when we work so we'll see how it goes. I mean what would a pro do stick weld it or something?
  26. #43
    And get some "seasoned" aluminum that's been sitting outside near the water for a year.
  27. #44
    Yeah that is the thing. In my job we have to kind of be a "jack of all trades, master of none" I do a little bit of all types of ****. They bought us a welder and we've fixed a few things, but the only way to get better is to do it. If we keep just paying welders what's the point. Gotta learn somehow.
    Would a pro do a better job, absolutely, but if I never try I will never learn. If this weld fails the whole thing won't come down so I feel comfortable practicing on some scrap and then giving it a shot. I would not feel comfortable cutting the whole section out and putting a new cross member in. I want to get some more experience welding aluminum because we use aluminum a lot, and it would be nice to have the ability to quickly fab up simple things in our shop instead of paying out the nose for a pro shop to make it.
  28. Likes ronsii liked this post
  29. #45
    May 2007
    exactly. i like ur attitude
  30. #46
    Yeah good point. I have a lot of aluminum scrap laying around that has that layer of oxidation on it. Planned to hit it with acetone then wire brush the hell out of it with a stainless brush
  31. #47
    Los Angeles
    get to practicing with yer MM211 and spool gun. Aluminum is a different beast even in the best of conditions.
    I would practice on clean AL first though Lots can go wrong quickly so might as well start off with the good stuff to eliminate at least one problem.
    MM211 (Sold)
  32. #48
    I get it you want to learn? It hasn't been established yet if it needs to be an engineer approved repair by someone qualified. It's not much different than advising a trailer to pull on the highway is not a suitable project for a beginner.
  33. #49
    Apr 2018
    Montana
    Maybe this is just my newb impression but, is there any reason it can't stay in place (per the original engineered design) and instead be reinforced instead? The engineer can come up with the future replacement for the individual piece or an entire structure can be prefabbed on its' own timetable then.
    I probably would've tried to add cross braces or outside wraps with flat stock on angles to help stabilize it if nothing else, (especially if I thought I'd have to remove the original brace for replacement at any point in the future). I wouldn't want the thing collapsing while the original is out/weakened and I'm fitting the new replacement!
    I would've thought step one is to stop further damage...and to strengthen any weakness occurring. Kind of like putting a cast or brace on a broken bone.
    Lincoln 140HD solid .023 and 75/25% Ar/Co2 or 100% Co2
    Lincoln SP-140T innershield .03 or Aluminum spool gun
    Dayton 230A AC Stick
    Harris Oxy/Ace torch setup
    Chicago Electric Stud Welder
    LTP 5000D Lotos 50A Plasma
    Vulcan Protig 205
  34. #50
    SoCal-LA
    Quote Originally Posted by h couillion View Post
    I have been holding back on commenting on this but this is what I would have done. With that said I understand alum very well. Mig in short spurts is the way to go using er5356 wire. In fact if I was doing the job I could do the repair and reinforcing stronger than original until the piece could be replaced.
  35. Likes ronsii liked this post
Page generated in 1,635,287,430.23002 seconds with 12 queries
