Page 2 of 2 FirstFirst 12
Results 26 to 39 of 39
Thread: Welding Cast Iron and Steel Together???
    May 2015
    Re: Welding Cast Iron and Steel Together???
    Hi,
    Thanks, learned a few things there.
    Did not know Starrett, was that involved with Athol, just thought they made the vises for Starrett.
    The supporting ledge was good info also, will sharpen my eye, when looking at old used vices.
    I bought my vice from an old boy, closing a welding shop for $75!
    I think it is pretty close to $500 new or was a few years ago when I looked.
    It has been a pleasure to use, and gets used almost everyday!
    May 2015
    Hi,
    The painting begins, nothing fancy, just brushing it on with light coats.
    Had some very light gray and mixed in some black to darken it up a bit.
    Looks like Bridgeport Grey now, which is better!
    Starting work on the tightening device now.
    I'll throw up some pics of that later on.
    May 2015
    Hi,
    Finished painting today, and started on the tightening device for the swivel base...
    Admittedly, getting ideas from the Starrett Vise, never made one before, but looks like basic machining.
    May 2015
    Hi,
    Worked on the handle that will be attached by a roll pin to the round block.
  5. #30
    May 2015
    Hi,
    Ok, now I have to make a "Wedge"!!!
  6. Likes G-ManBart, whtbaron liked this post
  7. #31
    Sep 2016
    Detroit, Michigan
    Quote Originally Posted by seagiant View Post
    Hi,
    Wow...nicely done!
    http://mivise.com
    Hobart Champion Elite
    Everlast PowerTig 210EXT
  8. Likes seagiant liked this post
  9. #32
    May 2015
    Hi,
    Thought I would go ahead and put this up.
    This is what I ended up with, but not really a bad looking vise now, and a LOT better than what I had starting out.
    More things to do, will probably cold blue the raw steel and oil, ect., ect.
    Nothing fancy, but seems a good working vise now!
  10. Likes bead-boy, G-ManBart, arcflash, husq2100 liked this post
  11. #33
    May 2015
    Hi,
    Well I just put the vise completely together and it works great!
    Admittedly, I'm a little proud of myself, for going to the work and trouble, to get this thing back to square one, and operating as it should. (I have 360 degree rotation now!)
    I have to admit, the thought did cross my mind, to just weld it together, and forget about the swivel function, but could not do it, as I thought I could fix it right, and had the tools to do it.
    Using my marvelous Starrett, as a model, to go by, the Rock Island works, just as good now, and is probably stronger, than made.
    Takes very little tightening, to hold the vise to the base, and of course unlike, the previous Owners, will not be beating on it, with a hammer!
    I have Leg Vises, for that!
  12. Likes whtbaron, davec liked this post
  13. #34
    Apr 2021
    Plumber/welder here. Had call leaking water line in school galvanized pipe threaded into cast fitting --leak at threaded joint. I used cast iron rod, 7018 and tried 6010 and failed to stop the dripping---so to me it can't be done--and I would not warrant or risk liability saying it can after 4 hours of buttering the cast then the mld steel with 7018 then cast grinding down then welding with 3 diff rods. just saying-motown ( 40psi city water)
  14. #35
    Mar 2021
    Near Roanoke, VA
    Whatever you got going on,, BOLT that vise down now,,,
    62 years ago, I walked past a vise that size,, and I had to turn the handle,, 1/50th of a second later, the vise fell on my left foot.
    I was almost 10 years old.
    Per the doctors prediction,, that smashed foot healed, but, I can predict rain due to cramps in that foot.
    I have had that capability for over 20 years,,
    I am not a safety freak,, but, turning that handle calls EVERY PERSON that walks past,,,
    and it is amazing how easily the vise will fall,,,
  15. #36
    Mar 2021
    Near Roanoke, VA
    Quote Originally Posted by Birmingplumb View Post
    My run-ins with welding cast iron says that you can only be successful if the weld is in compression,, not tension.
    BUT, that is how you are supposed to use cast iron in the first place,, similar to concrete, in compression.
    About half the time that cast iron is broken, the item is being misused, and tension is applied.
    If the part is welded, and put back into use,, guess what? the cast iron part in tension,,, BREAKS AGAIN!!
    The weld is blamed as "poor".. when in fact it is the misapplication of the part that causes "the weld to fail !! "
  16. Likes seagiant liked this post
  17. #37
    Sep 2007
    Gold Coast, Australia
    Good work on the vice seagiant!
    thought id ask here instead of starting a whole new thread.
    Welding mild steel to Nodular Cast Iron:
    The cast iron is a 3rd member, the mild steel is the plates to allow for "pegging" of the ring gear to help prevent defelection under loads. I have read of them being GTAW with a "super special filler rod that is VERY hard to get" (that guy likes to think of himself as some sort of diff guru) and I know of another that just welds them with GMAW and Er70S wire.
    I undertsand pre heat and post heat are both very critcial.
    So, if you were limited to either GTAW or Oxy/Acetylene would you weld or braze? which rod whould you choose?
    I have never GTAW brazed before (only welding), but have a mate that has done a bit of Oxy brazing.
  18. #38
    Mar 2021
    Near Roanoke, VA
    Quote Originally Posted by husq2100 View Post
    I lucked out, and the US Navy taught me how to braze,, with oxy-acetylene,,
    I would have no concerns about brazing the steel to the iron,,
    If I had to TIG weld it, I would TIG it with nickel filler metal,, (I would "bet" that nickel is the "super special" filler that other welder mentioned)
  19. #39
    Jul 2016
    Midwest
    If brazing I'd use flux coated Nickle Silver. Tig welding I'd use 312 Stainless. If you decide to Tig it you can look for a 1# pkg of Harris Supper Missile Weld or Weldcote Super 120 stick rod. Knock the flux off and clean with a scotchbrite pad. Tig away and save some money. The Ni Silv will be in a 10# box. Good luck !
    Thermal Arc 320SP ( Lorch )
    Cobra Pythons
    ESAB 301i AC/DC ( Lorch )
    Thermal Arc 161STL ( WTL )
    Thermal Arc 190S ( Sanrex )
    Victor Gas Apps.
Page generated in 1,628,149,477.52222 seconds with 13 queries
