Results 1 to 25 of 27
Thread: 1980 Miller Dial Arc 250, Tripping Breaker At Start Up!!!
    May 2015
    Hi,
    Tried to use my Miller today and it's tripping out on start up.
    It is also making a hum, it never did before at start up then trips the 50 amp breaker.
    Never had this problem before, also the cord to the outlet and the breaker are fine with my Mig 180, so...
    I'm thinking I have a Welder problem?
    Does anyone here have any ideas on this?
    This Welder is a Beast and not looking forward to taking it to a shop, rather fix it myself, if possible!
    Thanks!!!
    Jun 2016
    Back to the jungle
    Re: 1980 Miller Dial Arc 250, Tripping Breaker At Start Up!!!
    Killer rig. You need 60 amps for the breaker. Better to hardwire the thing
  3. Likes Louie1961 liked this post
    Jun 2014
    Southern Illinois
    The hum and the tripping, my first thought is a rectifier diode. I could be way off but I would research that first
    Steve
    Miller Dialarc 250 (1990)
    Miller Maxstar 140 STR (2003)
    Lincoln MP210 (2015)
    Victor and MECO torches
    Ceres, California
    check the weld diodes one might be shorted.
  6. #5
    CT
    HOLY SH!T man, I've missed seeing you around here. Welcome back.
    Miller Multimatic 255
  7. #6
    Big Lake/Monticello MN
    Yep, I'm going with diodes too.
    I popped one while welding once. Machines starts to hum like its fully loaded - dead short.
    Syncro 350
  8. #7
    May 2015
    Hi,
    Thanks everyone, have not got it open yet but had no problem for years, now this.
    I guess if I see nothing, (burnt?) then I will just have to test, all the diodes, and see, if one is bad with the Fluke VOM?
  9. #8
    Jun 2014
    Southern Illinois
    There is a diode test function on most Fluke meters. Download a manual from Fluke to get the process for checking them
    Steve
  10. #9
    May 2015
    Quote Originally Posted by Sparkie1957 View Post
    Hi,
    Thanks, I'll have to find them first, but downloaded the closest Owners Manual from Miller, so should be ok!
  11. #10
    May 2015
    Hi,
    Ok, opened her up and found 4 Diodes, 2 of each goes to the same terminals...
    Just nutted in on one end and then a wire going to the attachment point, looks easy enough to pull one at the time and test.
    Did not see or smell any burning or something getting hot?
    IF I do find a bad Diode, would you just buy and replace all of them while I'm in there???
  12. #11
    Jun 2014
    Southern Illinois
    I would suggest looking online, perhaps EBay. They don’t have to come in a Miller bag. There are threads on suitable replacements. I would change them all out
    Steve
  13. Likes 12V71 liked this post
  14. #12
    I agree, change all 4.
    The cheapest cost diodes I've found were on ebay for the DC wind power projects.
    Way cheaper than Miller.
    Syncro 350
  15. #13
    May 2015
    Hi,
    Thanks, will look into that.
    I labeled and tested all 4 diodes, one was bad, so I'm going to put in 4 more!
    Thanks to everyone for the help so far!
  16. #14
    May 2015
    Hi,
    Found these on EBAY, of course, I know, I need 2 pos and 2 neg polarity.
    They do say these are for Miller Welders, just checking before ordering.
    Is there a certain Diode you guys use???
    https://www.ebay.com/itm/Part-037-30...4AAOSw33FfoCyY
    https://www.ebay.com/itm/Part-037-30...YAAOSwEJdfoC0-
  17. #15
    May 2015
    Hi,
    I E-Mailed the Seller on EBAY and he told me more about the Diodes as far as size ect.
    Seems a decent company so I ordered 4 new Diodes for about $110...
    That's what Miller wants for one almost.
    Called Digi-Key and got the phone run around.
    The Guy on E-Bay used the same numbers as Miller and there were really no question on if they would work...we will see!
  18. #16
    Jun 2014
    Southern Illinois
    Sounds like a good deal. You’ll have a great welder for many more years when those are installed
    Steve
  19. Likes seagiant liked this post
  20. #17
    May 2015
    Hi,
    Thanks for the help again, I was Merchant Marine for 40 years and the last 20 in the Engine Room.
    Did a lot of repairs and fabricating...
    Almost every ship I worked on had a big, 3 PH, Lincoln or Miller stick Welder, and with 3 PH and DC, you really had a smooth running machine.
    Saw this Miller Dialarc 250 on CL for $325 and jumped on it.
    Came with 50 ft. Leads a new Stinger and sat on a Miller OEM Iron Wheeled Cart.
    Has worked fine for years, this is the only problem, but it is 40 years old, but...
    She will burn a rod!
  21. Likes Louie1961 liked this post
  22. #18
    Jun 2014
    Southern Illinois
    I had a Dialarc 250, I think it was a late 80’s. I restored it and having powder coated and had a custom aluminum diamond tread top bent for it. Great welder!
    Steve
  23. Likes seagiant, Louie1961 liked this post
  24. #19
    May 2015
    Hi,
    NICE!
    I like that top, might have to look into that.
    Those old OEM, Iron Wheel Carts, are the Bomb!!!
  25. #20
    May 2015
    Hi,
    My Diodes came in, will put them in tomorrow...
    Hope that cures my Welder, we will see!
  26. #21
    Jun 2014
    Southern Illinois
    Think positive! Then negative! Lol. I’m sure you will have a good welder when your done
    Steve
  27. #22
    Sep 2016
    Detroit, Michigan
    Quote Originally Posted by seagiant View Post
    Hi,
    Wow...color coding for current direction....awesome idea! That's way better than a tiny little arrow printed on the side. You may already know this, but you don't want to forget the thermal paste between the diode and where it mounts. It helps the diode dissipate heat better and extends their life. It appears they had a couple of tubes of that in the package, so you should be set.
    http://mivise.com
    Hobart Champion Elite
    Everlast PowerTig 210EXT
  28. #23
    May 2015
    Hi,
    No, the paste was not included, I bought that earlier.
    I labeled everything, so should be a snap!
  29. #24
    May 2015
    Hi,
    Ha! Ha! Ha!...
    Well, the new Diodes are in, and she's running, even more quite, than before...
    All you can hear now is the fan running, and she's not tripping out, of course.
    Admittedly, I don't stick weld everyday, but being able to use different electrodes makes this Miller more versatile than my Mig!
    Thanks to everyone for the help and education, I now know more about Welders, than I really wanted to!!!
    Happy, I was able to take care of it myself, of course!!!
    Oh yea, I was wrong, they did include, a SMALL vial of heat paste!
  30. Likes bead-boy, G-ManBart, Louie1961 liked this post
  31. #25
    CT
    [QUOTE=seagiant;8806731]Admittedly, I don't stick weld everyday, but being able to use different electrodes makes this Miller more versatile than my Mig!/QUOTE]
    Well I might not go that far. A 250 amp MIG is WAY versatile than a 250 amp stick welder, in my opinion. Now if you are talking about a less powerful MIG, then it might be up for debate. ;-)
Page generated in 1,713,270,209.11071 seconds with 20 queries
