Results 1 to 9 of 9
Thread: Fly Wheel repair
    Oct 2019
    Australia
    Fly Wheel repair
    The grounds keeper where my shop is busted the flywheel in his Honda mower. He immediately went out and bought another Honda mower, but brought the busted flywheel to me for an opinion on repair so he can have a backup mower.
    It's cast iron, the shaft is tapered, and unfortunately it split through the keyway. So even though I can weld it up, I'm thinking the machining cost afterwards might be more than just buying another flywheel. Also there is balancing to consider as well.
    What do you recon?
    Re: Fly Wheel repair
    You also have that bonded on magnet to deal with. Shouldn't be too hard to find another flywheel. I wouldn't waste my time on it, myself.
  3. Likes CAVEMANN liked this post
    Aug 2018
    'ta town, KS
    I would weld it, and machine it, but I would do that at work. Beefier machines, and they have a keyway broach set to use that I don't have to buy. But check out a machinist forum that is local. A hobbyist or retired machinist may be able to make it right for a case of beer.
    Mac
    Apr 2016
    I googled "honda mower flywheel" - there was one that looks just like your photo on first screen for $125 or so. Not sure if it's same one, but pretty cheap insurance vs welding and machining if it is.
  6. #5
    Soda springs,Id
    Let me guess. He broke it trying to remove it.
    Ol' Stonebreaker
    Hobart G-213 portable
    Miller 175 mig
    Victor O/A setup
    Makita chop saw
  7. #6
    Oct 2019
    Australia
    He tells me it broke at full revs. He suspects the the retaining screw was done up so hard on the taper, the force caused or contributed to the break.
  8. #7
    Oct 2019
    Australia
    Thanks for the advice and help guys. I checked out ebay and they can be had from local supply for $65 ozzy kopeks delivered. It's a no brainer so I handed it back to the mower man and passed on the details. He's happy with that and so am I.
  9. #8
    Northern California
    Quote Originally Posted by Woznme View Post
    You were wise enough to shop for the replacement and recognize it for the bargain that it is. He was smart enough to recognize your wisdom. A truly rare convergence!
    South Bend Heavy 10L Lathe
    Kent 9x42 Vertical Mill
    AHP Alpha-TIG 200x
    1974 Lincoln AC-225
    HF 4x6 Bandsaw
    Kalamazoo 8CW Horizontal Bandsaw
    Welding: It's like sewing with fire.
  10. Likes MinnesotaDave liked this post
  11. #9
    Jun 2017
    AJO, ARIZONA
    It's a shame it didn't shear the key, that's what happens on a lot of "small" engines.
    NRA LIFE MEMBER
    UNITWELD 175 AMP 3 IN1 DC
    MIDSTATES 300 AMP AC MACHINE
    LET'S GO BRANDON!
    "Those who would give up essential Liberty, to purchase a little temporary Safety, deserve neither Liberty nor Safety.” BENJAMIN FRANKLIN
Page generated in 1,656,113,255.87992 seconds with 13 queries
