Results 1 to 10 of 10
Thread: Flange wizard magnet and cutting edge how hot can you get them?
    center NJ
    I do a bunch of cutting of weird stuff 3/8 - 2 inch thick small parts . I can’t believe I waited so long to buy them . I love it . Well if I cut fast the clamps get warm semi hot I can pick them up fine to move them. But cut Quality is low .
    If I go slow I can get amazing cut cut quality like CNC plasma love it . But the clamps get hot , I have to use gloves to move them.
    How hot is to hot ? Will it lose the magnetic force and break them ?
    Mar 2005
    Under a Rock
    Re: Flange wizard magnet and cutting edge how hot can you get them?
    Quote Originally Posted by Bigrich954rr View Post
    YES absolutely.
    excessive heat will ruin a magnet.
    Been there/done that.
    Hypertherm PM 45
    1961 Lincoln Idealarc 250
    HTP 221
    Mar 2005
    Under a Rock
    I had to look up flange wizard... never heard of it.
    but the warning is on their website front page.
    Warning: Excessive heat can damage the magnets.
    Keep magnet block away from sensitive electronic devices.
    Keep magnet block in “OFF” position when not in use.
    Hypertherm PM 45
    HTP 221
    center NJ
    Yea but wondering what they call Excessive heat when talking about an oxygen cutting torch
    center NJ
    YES absolutely.
    How hot did you get it ?
    How do you keep them from getting hot while preheating and cutting the metal ?
    Mar 2005
    Under a Rock
    No idea. But hot enough to ruin it.
    The clamp was a stronghand clamp with small magnets... I only cooked one out of the 4 little magnets...
    my fault, they are only meant for setup .. then removed after tacking.
    In your case, just be careful I guess.... who knows how hot HOT is...
    it's all good until it's no good.
    Hypertherm PM 45
    HTP 221
    Mar 2005
    Under a Rock
    On the other hand, I have a Mag clamp (ground clamp) on my stick welder.... and it HAS got hot from time to time.... especially if metal shavings get under the magnet.
    and the mag clamp still works fine... so, who knows
    Hypertherm PM 45
    HTP 221
    I have a Mag clamp. Mines is weak, i suspect from heat. Ironically a weak mag clamp gets hot from being weak.
    May 2007
    call'em up, and ask them. there in so. cal, u'll probabaly have to leave a message, and the girl will call u back, she's polite/clean spoken, and with it
    center NJ
    Yea I’ll have to give a call when I get time
Page generated in 1,623,866,172.99609 seconds with 11 queries
