Results 1 to 11 of 11
Thread: Miller Dialarc HF
    Feb 2021
    NY
    Miller Dialarc HF
    Hi everyone
    I took a look at the serial number and this welder was made in 1978!!!
    I have had it since 2015 , and it runs 7018 and 6010 real smooth.
    Anyone stick weld in dc at 310 amps ? What would even need that to run ?
    Re: Miller Dialarc HF
    1/4" electrodes. I have used mine at maximum for gouging with an air arc.
  3. Likes Jonath108 liked this post
    Sep 2016
    Detroit, Michigan
    The non-HF Dialarc is only a 265A machine, so the fact the HF version is 310A tells me they were probably thinking that would be useful mostly for TIG.
    http://mivise.com
    Hobart Champion Elite
    Everlast PowerTig 210EXT
  5. Likes Jonath108 liked this post
  6. #4
    May 2015
    Hi,
    I thought the HF Version WAS for TIG???
  7. #5
    Sebeka and Bemidji MN
    Quote Originally Posted by seagiant View Post
    Hi,
    Tig and stick.
    Might gouge but I didn't try it with mine.
    I've scratch start DC tig welded with mine. Works great.
    Syncro 350
  8. Likes Jonath108, seagiant liked this post
  9. #6
    From all the manuals I've seen, all the Dialarcs are 310 amps.
    The plates on the machines are kind of misleading sometimes.
    In general, for overall wattage output, tig ends up with higher amps due to lower welding voltage.
    DialarcHF manual:
    Standard Dialarc duty cycle chart.
    Syncro 350
  10. Likes Jonath108 liked this post
  11. #7
    Feb 2021
    NY
    That being said,
    does that mean the percentage would be based on 270 amps when dc stick welding in high mode, as opposed to the printed "310" on the machine in high ?
    Just wondering if I am figuring wrong with how many amps, when I am running at 60% in high mode and dc stick welding ?
    Thanks
  12. #8
    Sep 2016
    Detroit, Michigan
    Hi,
    Sorry, I worded that poorly. I meant a higher amperage limit (if that's the case) would be useful for TIG....310A for TIG isn't a crazy number, but it's pretty high for most stick welding (that mere mortals might do).
    http://mivise.com
  13. Likes Jonath108, seagiant liked this post
  14. #9
    Sep 2016
    Detroit, Michigan
    DialarcHF manual:
    Hmmm...now I'm confused! I've had a couple of Dialarcs, so I found the serial number of the oldest one I've had (JF920141) and looked up the manual. It shows a duty cycle chart similar to what you posted, but the graph for output ratings is different.
    It lists 300A as max for AC and 265A max for DC outut, which matches with the range selector switch. The newer Dialarc I had also had a max of 265 DC listed on the range selector switch.
    I haven't owned an HF version, but all that I have seen pictures of have a max of 310A listed both AC and DC on the range selector. My head hurts now...lol
    http://mivise.com
  15. #10
    Feb 2021
    NY
    Thanks
    I guess 1/4" 7018 could take up to 310 as well.
  16. #11
    I worked in a tank shop that had a Dialarc 250 for a maintainence welder. One of the guys needed a machine and all the 3 phase machines were being used. He proceeded to burn 1/4" 7024 to weld the inside seam of a tank about 10ft. diameter. You could smell the machine burning up! They told him but his response was just about done. He was a more senior employee but I think in most shops you'd get fired for doing something stupid like that. Generally AC/DC machines put out more current on AC than DC (transformer machine anyway).
Page generated in 1,628,091,289.98217 seconds with 13 queries
