Page 1 of 3 123 LastLast
Results 1 to 25 of 64
Thread: Help needed for Copper Tweco 300 work clamp
    Feb 2021
    NY
    Hi everyone
    Just bought a like new but used Tweco CC 300 Junior work clamp from Ebay. I had no idea it was missing a copper shim until I watched a video of replacing one.
    Where can I buy a copper shim for this exact model ?
    I do not think Tweco still makes this model, as that is why I looker to Ebay. Now I am thinking I need to buy one that is new in the box, unopened.
    Any help is greatly appreciated.
    Re: Help needed for Copper Tweco 300 work clamp
    Split some copper tubing that fits over your cable.
  3. Likes Lis2323, Jonath108, rhunt, CAVEMANN liked this post
    Laredo, Tx
    A thin brass ferrule, split down the middle long ways, will also work in a pinch.
    HTP Invertig 400
    HTP Invertig 221
    HTP ProPulse 300
    HTP ProPulse 200 x2
    HTP ProPulse 220MTS
    HTP Inverarc 200TLP
    HTP Microcut 875SC
  5. Likes Jonath108 liked this post
  6. #4
    Jun 2009
    Draper, UT
    I used a short piece of flattened 1/2" copper pipe
    MillerMatic 252, HTP 221 w/cooler, Hypertherm PM45, Lincoln IdealArc 250 AC/DC
  7. Likes Jonath108, rhunt liked this post
  8. #5
    Feb 2021
    NY
    Thanks to you all !
    I have some copper shim sheet , is this too thin.
    Thanks
  9. #6
    NW New Jersey
    Not knowing the thickness, its hard to say. A flattened piece of copper water pipe would probably be better. It will clamp onto the fine strands, and not deform too much. If the shim stock was .030 or larger, it probably would work. Most of my shim stock is brass, and expensive, so I would rather go in the cut off bin, and find a piece of pipe.
    good luck
    Miller Synchrowave 180 sd
    Miller Econo Twin HF
    Lincoln 210 MP
    Dayton 225 ac/dc
    Victor torches
    Snap-On YA-212
    Lotos Cut60D
  10. Likes Jonath108, rhunt liked this post
  11. #7
    Quote Originally Posted by Jonath108 View Post
    Thanks to you all !
    Thanks
    Just cut a strip off and wrap around a few time as needed, insert, and tighten down.
    For a cable hold, use light tube like thinwall.
    Cut, split, and secure clamp to cable.
    Even a few time wraps would work for a while.
  12. #8
    Wrap what you have 2 or 3 times and it will be fine. A lot of stingers and grounds don't use the copper strip at all and I've seen some clamps that use a curved piece of steel under the bolt to spread the load over the cable.
  13. #9
    May 2007
    i like ur attempt w/ the zip ties. i put a small/fuel line stainless hose clamp there, positioning it to where end of leftover tail tucks through slot. i would tell u to put a lil elect tape b/t clamp and insulation, to help from biting insul, but i think u already hold credentials in the elect tape dept
  14. #10
    Feb 2021
    NY
    Thank you,
    Electric tape is my friend, as you noted. The clamp spring stopped the clamp from opening without leverage, that's why I picked up another work clamp.
    I also love Electric Zip Ties !
    Thanks again
  15. #11
    The last time I did this, I just took a utility knife and scraped off any oxidation on the cable conductors, and sanded some copper shim stock until it was bright and shiny, wrapped the copper shim stock around the cable conductor and then coated everything with dielectric silicone grease (including the big Allen screw that mashes everything down) and put the coals to 'er.
  16. #12
    Feb 2021
    NY
    Thanks,
    I will just order some copper shim stock. Do you know what thickness will work best ?
    The bottom of the hold down screw is nice and round, even a bit oily feeling. Maybe that is what's left of any dielectric grease.
    Thanks
  17. #13
    I think there was a bit of confusion with what you were looking for. Copper shim on the stripped cable that's clamped by the big bolt. The piece that goes through the slot behind is not copper but just a strain relieve so the cable doesn't get wonky where the insulation is stripped. A hose clamp is the most common cure. Don't tighten it super tight that it cuts into the insulation, just snug. If you could find some metal zip ties would be better for the heat.
  18. Likes Jonath108, rhunt liked this post
  19. #14
    Feb 2021
    NY
    Thanks,
    I know that the outer ring is to hold the cable, I was missing the copper shim, and just want a good fit and fix if I replace the old clamp with a new one.
    Thanks
  20. #15
    Just wrap the shim stock you have a couple times. If the spring on the clamp is still good no need to replace it.
  21. Likes Jonath108 liked this post
  22. #16
    If you look at the original post, his old clamp has no insulators on the spring and no doubt it's heated up and lost tension. One of the reasons I wont use that style of clamp anymore... That and the cable pullouts from the bolt. I prefer a heavy duty Lenco type now with a well crimped eye lug on the cable.
  23. Likes Jonath108, CAVEMANN liked this post
  24. #17
    I did say if the spring on the clamp is still good, as in has tension to hold the clamp tight.
  25. #18
    Try reading the whole thread for once... He's replacing the old one because it wont grab anything... DUH.
  26. #19
    Congratulations.
    You're a legend.
  27. Likes Jonath108 liked this post
  28. #20
    Mount Tabor VT
    I use a stripped copper conductor of correct size to wind tightly around the stripped welder cable, like a Boy Scout manual shows whipping the end of a rope to prevent fraying.
    It then is an excellent next step to "tin" it with solder.
  29. Likes Jonath108 liked this post
  30. #21
    Congratulations.
    You're a legend.
    At least in his own mind.
  31. #22
    Soft copper tubing will work too. Some old school hardware stores sell by the foot. Match stripped cable copper to size of tubing, cut to length, insert into clamp, and tighten screw. If difficult screwing ,remove screw and use drift punch through screw hole to dimple.
    Having a double ground clamp on a chunk of cable is handy too. If you normally don't need 50' of ground cable, make machine ground say 20' and setup the balance 30' with a ground clamp on each end. It depends on your needs and situation .
  32. Likes Jonath108, Lis2323 liked this post
  33. #23
    Feb 2021
    NY
    Thanks to everyone who shared your advice.
    After finding 1/2" copper coupling or union was too thick, I chucked it up and turned it down until it parted itself off.
    Now I can easily cut to fit in the work clamp and screw down the ball end screw to hold.
    Here a some pics, forgive me for duplication, Iphone has a mind of its own.
  34. #24
    Jul 2016
    Midwest
    Some folks simply solder the cable to the clamp. When it's time to change the clamp or cable they simply heat and remove.
    Thermal Arc 320SP ( Lorch )
    Cobra Pythons
    ESAB 301i AC/DC ( Lorch )
    Thermal Arc 161STL ( WTL )
    Thermal Arc 190S ( Sanrex )
    Victor Gas Apps.
  35. Likes Jonath108 liked this post
  36. #25
    I once tried to solder some 2/0 copper cable end-to-end. As conductive as copper is, that takes some serious HEAT. I suspect I could have given it all 310A that my Sync250 could supply and STILL not have the solder wet out all that great.
  37. Likes Jonath108 liked this post
Page generated in 1,628,095,267.39692 seconds with 13 queries
