Results 26 to 50 of 60
Thread: When To Change Argon Cylinder?
    Apr 2020
    pekin, IL
    Re: When To Change Argon Cylinder?
    Another thing I forgot to mention is adjusting your frequency up to between 100 and 150 htz. This gives you a more focused arc and will narrow your puddle and bead.
    Jan 2021
    Somewhere South of Denver
    Quote Originally Posted by bplayer405 View Post
    I was playing with that a little bit yesterday. I think because of my issues, I wasn't getting the expected results. With things hopefully back to normal I would like to try it again.
    Jim
    PrimeWeld TIG225X
    2017 F-350 CCLB 6.7L
    2013 Polaris Ranger 900 XP in 2006 Fleetwood Gearbox 220FB using 3" Andersen WDH
    I don't always tow heavy, but when I do, I use my Superduty.
    Here fishy, fishy... .`.`..`. >< ((( >
    Aug 2019
    northeastern PA.
    also, the tilt on the torch should be little from 90*. YOu want to just peak at the tungsten. Just seems to me that in one of the pictures of the welds there is loss of gas coverage. Keep practicing.
    Sep 2016
    Detroit, Michigan
    To clarify, increasing the frequency reduces the heat input a bit, which will make things worse if he doesn't increase maximum amps.
    http://mivise.com
    Hobart Champion Elite
    Everlast PowerTig 210EXT
  5. #30
    Jan 2021
    That's the relationship I was trying to figure out Saturday. Somewhere there is probably a mathematical formula that explains that. Nothing was working right Saturday. Sunday, much better results, but not enough Argon in the tank to experiment with.
    Jim
    PrimeWeld TIG225X
  6. #31
    Mar 2021
    Near Roanoke, VA
    I was reading the owners manual to a welder I am considering buying.
    The manual started off by saying ONLY TIG weld with argon,, no mixes,,, PERIOD.
    For a couple paragraphs the manual went on describing many ways that contaminated argon tanks are obtained.
    If a filler does not properly purge a 75%- 25% tank,, the residual CO2 can contaminate the tank of argon.
    then,, the manual went on,, and on,, and on,,,,, about contaminated argon,, and other strange mixes.
    The manual even said it would be cheaper to buy a larger welder, than consider welding with helium, as helium is so expensive,,
    PM me if you want to know where I found the manual with this info,,,
  7. #32
    city of Four Flags
    My .02 is get equipment info from the company that makes/sells equipment. Get gas info from a gas supplier.
    Yes, I am aware that opinions of some gas sales people are not the best, but like in welding, you have good weldors, you have amazing weldors and you have weldors that cannot chew gum and walk at the same time. The same thing happens in the gas industry.
  8. #33
    Jan 2021
    Another day of practice. Beads are coming out decent. I made it through two filler rods without trashing the tungsten. That's real progress for me. When I shut down, I looked over all my equipment a lot more carefully and noticed that the copper braid on my ground clamp looks like it got too hot. My welding table that I attach the clamp to is 3/4" plate steel. I don't have any braid but I do have 2/0 welding cable and ring terminals that I might be able to fit in there.
    Jim
    PrimeWeld TIG225X
  9. #34
    Laredo, Tx
    Quote Originally Posted by HRTKD View Post
    Home Depot has Lincoln brand work clamps with all copper parts, including nut/bolt for about $7. I'd be willing to to bet it would be 1000% better than that basic clamp, and might even work better overall for the whole system.
    HTP Invertig 400
    HTP Invertig 221
    HTP ProPulse 300
    HTP ProPulse 200 x2
    HTP ProPulse 220MTS
    HTP Inverarc 200TLP
    HTP Microcut 875SC
  10. Likes HRTKD liked this post
  11. #35
    NW New Jersey
    Best practice when welding aluminum is to attach Work/ground clamp to the aluminum itself. If you are using the table itself as the ground path for the aluminum, you may find pitting and arcing marks on the back of your work. If you're trying to make something pretty out of aluminum, you might not appreciate the pockmarks/craters. The same could be said for stainless, to a lesser extent mild steel.
    good luck
    PS. - You might ry to get the copper parts of the clamp in contact with the work, it looks like the nose of that clamp is steel. Putting lots of amps through that before the copper might cause it to run hotter.
    Miller Synchrowave 180 sd
    Miller Econo Twin HF
    Lincoln 210 MP
    Dayton 225 ac/dc
    Victor torches
    Snap-On YA-212
    Lotos Cut60D
  12. Likes HRTKD liked this post
  13. #36
    Jan 2021
    Thanks for the suggestions. Next practice session I'll try connecting the ground to the aluminum and see what happens. I'll check out the clamps at HD next time I'm there.
    Jim
    PrimeWeld TIG225X
  14. #37
    Mar 2015
    usa
    i can tell right now you put the cart before the horse. aluminum is tempramental and hard to weld if you dont know what your doing. spend a while welding steel until you understand the basics. youll only slow your progress by continuing with aluminum, without first understanding the basics
    invertig 221 water cooled
    millermatic 211
  15. #38
    If you have an O/A rig, you could melt some copper (solid electrical wire conductor would work) onto the steel contact points of your work clamp...or even braze a couple of pre-1980 pennies to the contact points...
  16. #39
    Sep 2016
    Detroit, Michigan
    Harbor freight has a really nice 400A work clamp that runs about $15....seems just as nice as the Tweco it copies for a lot less.
    For some work I use a cheap machinist's vise to hold the work. I welded a tab on it for the work clamp so it's a solid connection. At times that seems to work better than clamping directly to the work...just an option to consider.
    http://mivise.com
  17. #40
    Apr 2020
    pekin, IL
    I needed to upgrade the work clamp on my Weldpro tig machine. I could barely get the thing to open 3/4" wide. Found one at Blain's Farm and Fleet from KT Industries for just over $10. Opens the widest on any I've tried out so far and would fit over 2" exhaust fairly easily. So far it's working well.
    By the way, I'm down to around 125 psi on a 42cf tank and my machine was still welding fine. I was at least able to complete my project last night.
  18. #41
    May 2015
    Hi,
    Good thread, I'm in the same boat as the OP, except most of my problems are probably me.
    I first learned to stick weld, then went to MIG.
    Finally saw a good deal on a Thermal Arc 185 TIG and bought that.
    Big difference, to me!
    A lot more things to learn about, machine settings, grinding the Tungsten, ect., ect.
    Things, experienced Tig Welders, probably don't even think about, but new info for the beginner.
    I am today, going to go refill my Argon tank, and now that I am retired, try to fiqure this, TIG out.
    Seems a very good skill to have, and worth the time to learn!
    Miller Dialarc 250 AC/DC
    Thermal Arc 185 TSW Stick/Tig AC/DC
    Cebora 175 MIG
    Hypertherm PowerMax 45 Plasma Cutter
  19. #42
    Mar 2015
    usa
    theres alot of variables tig welding steel but even more so with aluminum. a new guy can chase his tail for a long time with hardly any progress
    millermatic 211
  20. #43
    Jan 2021
    Quote Originally Posted by cornchip View Post
    Just because something is difficult, doesn't mean I'm not going to try it. I'm making progress and learning a lot at the same time.
    Jim
    PrimeWeld TIG225X
  21. #44
    SoCal-LA
    You are not alone. I teach newcomers alum first. Easier to see, and easier to discover problems and sort them out. Like your pepper flakes. Name:  image_27052.jpg
    I see right off that your standard collet body and cup don't work well with alum. Turbulent air fouled gas flow recontaminates the surface of alum that the cleaning action of reverse polarity lifts contaminants off. A switch to a gas lens solved that same problem problem for me. Steel with that cup and collet body is not so much of a problem so newbies plod along thinking all is well. Then when graduating to alum the world crashes in on them. Sort out your problems now and the gains transfer right over to steel. Not so the other way. I have a saying the steel is easy to learn, but hard to master. Alum is hard to learn but easy to master. Any one of my graduates feel alum is easier to weld.
  22. Likes seagiant, 12V71 liked this post
  23. #45
    Jan 2021
    So what you're saying is that once I have aluminum figured out, everything else is gravy? I like that!
    In the picture you provided, I take it that the gas lens is on the left? What's a good source for gas lenses? Given my track record with the collet/collet body, I need to have a replacement gas lens waiting.
    Jim
    PrimeWeld TIG225X
  24. #46
    Laredo, Tx
    Only if you are cognizant of real world physical characteristics of steel. Really I think of it like, the same good practices and habits you need to do to learn/master aluminum, reap the same rewards when welding steels.
    HTP Invertig 400
    HTP Invertig 221
    HTP ProPulse 300
    HTP ProPulse 200 x2
    HTP ProPulse 220MTS
    HTP Inverarc 200TLP
    HTP Microcut 875SC
  25. #47
    SoCal-LA
    I have a saying. "Alum tig is hard to learn but easy to master. Steel tig is easy to learn but hard to master". Kind of like learning to drive a car. Many a driver can never make the switch to a manual transmission and give up in short order. But if you learn to drive on a stick, you know how to drive most anything.
  26. #48
    Mar 2015
    usa
    i didnt say give up or dont try it. but you dont even know the very basics of welding yet, or so it sounds. learn to walk before you try to run. aluminum is difficult if your not sure what your doing ,as i said before, as many variables can be a bit off and cause trouble. if you dont yet have the knowledge to identify the cause of the problem then how can you correct it.
    your thought of a low argon bottle making bad weld was probly a small breeze going through the garage instead. steel is more forgiving and has less variables to be concearned with. its like this, if you want to learn to drive, you wouldnt get in a 50' long tractor trailer with 18spd transmission. no you would want toyota corrola with auto trans. but do as you wish
    millermatic 211
  27. #49
    SoCal-LA
    That is the mindset of many schools. Steel historically has been cheap and the student has go navigate a gauntlet of processes before they are allowed to weld tig. So with the abundance of steel to pick off the floor steel it is. That was the way it was in my weld lab in college. Not that I did not learn anything but I spent a semester in oxy/acet then a year in a stick arc booth just to get to tig. I told the instructor that I had a job offer if I could tig alum and he put me in his booth next to his office. 2 weeks later I was welding thinwall alum tube. Key was getting real time instruction with both instructor and student behind the lens at the same time. With the abundance of knowledge on this forum there is no reason not to start with alum.
  28. Likes bplayer405, HRTKD liked this post
  29. #50
    Jan 2021
    Making progress on laying beads on flat material. It isn't perfect, but it's way better than I was seeing a couple weeks ago. I filled in some holes and that worked better than I expected. I have a bunch of welding coupon material coming this week. I need to progress to welding joints.
    A couple changes that I made that are positive.
    1. Removed the protective layer on the 3/4" steel that I'm using for my welding table. Top, joined sides and the bottom where the ground clamp attaches.
    2. New ground clamp from US Forge. It's better, but the OEM cable is kind of wimpy. I'm trying to figure out if I can simply replace the cable (maybe 8 awg at best) with thicker cable or if I need to replace the dinse connector also.
    3. Used the gas flow meter at the torch to adjust the Argon flow. I had to increase the flow to get to ~14 CFH.
    Jim
    PrimeWeld TIG225X
Page generated in 1,624,075,721.68069 seconds with 13 queries
