Results 1 to 10 of 10
Thread: After 8yrs my $9.95 4 1/2" grinder died...
    Nov 2013
    I certainly don't use it every day, or even every month, but this sucker has been through Many projects with me for Many years. Like probably most of you I have a few grinders on the bench, each one with a different purpose and preloaded for that use (this had a HF 4 1/2" thin cutting disk, my Metabo a flap disk I use a lot more).
    Today I've been slitting 1/4 mild steel plate, about 6' of, to create a 45* bevel in. It's getting hot and I swear, I'm feeling hot "pricks" on my bare finger at the seam in the housing. Next, the funny smell and lowering rpm.
    I open it up, just because, to have a look at things. Turns-Out, the brushes are just worn down to nothing (I see a loop of "spring" against the commutator ). I gotta say, I'm impressed though! I mean, it lasted long enough without problems to consume the only consumable part in it! Ya can't complain about that!
  2. Likes AlabamaJoe, wb4rt, Shootr liked this post
  3. #2
    May 2015
    Re: After 8yrs my $9.95 4 1/2" grinder died...
    Hi,
    The usual problem with the cheap CHI-COM, angle grinders were the bearing.
    I worked a coastwise Dredge and they would buy DeWalt Grinders by the case.
    When they went, it was always the bearing, but they were used ALL day, everyday.
    It was just cheaper to throw it and grab a new grinder.
    They figured they got their monies worth!
    Dec 2016
    the bad news is that they are now $11.99 grinders!
  5. Likes Shootr liked this post
  6. #4
    Soda springs,Id
    I had a little Makita 4" grinder that lasted about 20 yrs. Changed bearings and brushes in it once and after a while it just decided to leak all of the smoke out.
    Ol' Stonebreaker
    Hobart G-213 portable
    Miller 175 mig
    Victor O/A setup
    Makita chop saw
  7. #5
    Arizona
    I have one of their sawzalls - 10 years later of off and on use and it's still working just fine. It's nice for a hobbyist like me to only spend $50 to have an arsenal of grinders so I'm not constantly swapping discs and wheels.
    Yeswelder MIG-205DS
  8. Likes pprobus, seagiant liked this post
  9. #6
    Jun 2009
    New York
    Most of the Harbor Freight grinders used to come with a spare set of brushes.
    Millermatic 211
    Everlast 200DX
    Thermal Arc 181i
    Klutch ST80i lunchbox stick welder
    Lincoln Weld-Pak 100
    Century Stick welder
    Powermax 30 plasma cutter
    Henrob 2000 torch
    Logan 200 lathe (60 years old)
    Clausing 6339 Lathe (for sale)
  10. Likes 12345678910 liked this post
  11. #7
    Jun 2009
    New York
    Id mail you an extra set of mine, but the cost of the padded envelope and postage is about the cost of a new grinder, unbelievably .
    Millermatic 211
    Everlast 200DX
    Thermal Arc 181i
    Henrob 2000 torch
  12. #8
    Jan 2009
    Sonoma County
    The proper application for the HF $9.95 grinder is with a wire brush wheel for cleaning up between weld passes - where it won't be run more than a few seconds per run. Anything more than that and a better grinder is called for.
    I had a couple of those that I mounted in a Northern Tool chop saw frame. That was a mistake. I don't think I ran either one very hard, they ran at near full rpm, but the first one let the smoke out then the next one's fan disintegrated. I cleaned that one out and retired it to momentary wire wheel use.
    More recently I was on my way to buy the DeWalt 11 amp angle grinder. But I stopped by HF's Sidewalk Sale on the way and found HF's $75 Hercules twin to the DeWalt, also 11 amps, for half price in real shabby packaging with 3 day warranty. I like it! There was nothing wrong beyond the wrench and manual missing. It's night & day better than HF's older orange 5 amp or blue paddle-switch 7 amp grinder, that have held up well but felt lacking in power.
    And a comment on Ryobi's 18 volt angle grinder. Don't. Less power than the HF cheapie and it runs at half the RPM of a real grinder, while it strains the battery so hard that only the heavier battery can run it. Buy something better.
    HF MIG-180 with all the mods.
    Grizzly H8153 Stick/Tig Pulse 130/160.
    Wards PowrKraft AC-230. Stick & carbon arc.
  13. #9
    Aug 2012
    AR
    I certainly don't use it every day, or even every month, but this sucker has been through Many projects with me for Many years..... I gotta say, I'm impressed though! I mean, it lasted long enough without problems to consume the only consumable part in it! Ya can't complain about that!
    What can I say, but that they just don't make cheap grinders like they used to......
  14. #10
    Dec 2016
    have that blue paddle 7A hf grinder. the plastic casing is slowly dissolving away,the cord is stiff and it vibrates like crazy but thing runs and runs. for $20 at the time? can't go wrong.
    come to think of it,never had a hf tool leak smoke yet iirc.
Page generated in 1,624,255,773.77025 seconds with 13 queries
