Results 1 to 24 of 24
Thread: Mini split for shop
    Sep 2008
    Dalton, GA
    Mini split for shop
    The welding related angle to this thread is I weld in my shop.
    I plan to install a 24,000 btu mini split in my 1,000 sf shop. I have 2 questions.
    I was told I only need a 20 amp circuit with disconnect. Do I need a neutral and a ground or just 2 hots and a ground? Thinking the wall unit may use 110v.
    Iím thinking a ceiling mount near center of shop would work better than a wall unit but they are considerably more expensive. I want the best coverage and that would save valuable wall space. Attic access is fine with pull down stairs. Heavy insulation is already in place. Anybody used one or the other? What do you recommend? Issues cleaning filter?
    Thank you for your help!
    Burt
    _____________________
    Miller Syncrowave 250
    Millermatic 211
    Miller 375 Plasma Cutter
    Hobart Handler 120
    10FtDrillBit.com
    Feb 2016
    Myrtle Beach
    Re: Mini split for shop
    I’m thinking a ceiling mount near center of shop would work better than a wall unit but they are considerably more expensive. I want the best coverage and that would save valuable wall space. Attic access is fine with pull down stairs. Heavy insulation is already in place. Anybody used one or the other? What do you recommend? Issues cleaning filter?
    I would love to know how you like the system you go with. I have been planning on adding one to my garage at home but haven't had the time to do much research yet. I was hoping to get it done before this summer but not sure if I'll get to it by then.
    Lincoln 350MP
    Millermatic 350P
    Syncrowave 250
    1969 SA200
    HTP Invertig 221
    Mount Tabor VT
    They have blowers, so wall mount is probably near as efficient as ceiling. You want a circular air movement pattern. Usually they mount high on the wall where space is less at a premium.
    Dec 2016
    ceiling mounted cassette types work fine if ceiling is at least +9ft. below that go with a wall mount but you will still have concentrated a/c air flow .
    or you can use the remote mount blower units that will use ducting like traditional a/c.
    if unit is 230v then all you need is 2 hots and a ground to the outside unit. the inside will get it's power from the outside unit.
    they cool very well as outlet temps are much lower than traditional central air.
    Sep 2008
    Dalton, GA
    Quote Originally Posted by filetobeef View Post
    I have 10’ ceiling. Thanks for clarifying 2 hots and ground, no neutral required.
    Burt
    Millermatic 211
    Hobart Handler 120
    10FtDrillBit.com
    Outside of Raleigh, NC
    I currently have two mini-splits operating here on the farm. One is a Mitsubishi unit with a ceiling cassette in a 750 sq, ft well insulated building, and the other is a Pioneer wall mount unit in a 250 sq. ft log cabin. Both are heat pumps that provide both heating and cooling.
    The Mitsubishi is a top of the line unit. They cost more than other mini-splits, but have the best reputation in the industry. We used to use them on in-building cellular sites when traditional HVAC equipment was not an option, and their durability is superb.
    The Pioneer unit has been ok. A power surge wiped out a control board in it (not it's fault), and the replacement part was covered by warranty (but not the labor). It was about 40% of the cost of the Mitsubishi unit ($1,000 for the basic package versus $2,800 for the Mitsubishi package)
    Their efficiency is excellent (20+ seer ratings), but they don't recover quite as fast as a traditional split unit if you have the doors open a lot. The Pioneer unit does not work as well sub-freezing as the Mitsubishi unit does, but that's probably a case of you get what you pay for.
    A 20 amp circuit is all that's required for a 240VAC system. I don't think that either of mine required a neutral, but I ran one anyway so that I could install a 120VAC receptacle next to the condenser for maintenance needs.
    Miller Trailblazer Pro 350D
    Miller Suitcase MIG
    Miller Spectrum 2050
    Lincoln 210MP
    Feb 2016
    Myrtle Beach
    That's good info for sure I just started looking at Mitsubishi units.
    Lincoln 350MP
    Millermatic 350P
    Syncrowave 250
    1969 SA200
    HTP Invertig 221
    Arizona
    The indoor unit is usually 24 volts and will be supplied with a low voltage wire from a transformer in the outdoor unit.
    Miller Challenger 172
    Miller Maxstar 150 STL
    Victor 100C
    Victor Journeyman
    Oxweld OA
    Harris O/A
    Smith O/A little torch
    No, that's not my car.
    Sep 2008
    Dalton, GA
    Met with my friend who is a HVAC guy. He thinks a wall mount is better and has less parts than a ceiling mount.
    I’ll run power to a disconnect box and he will do the rest. I’ll post pictures and give a review in a week or so.
    Burt
    Millermatic 211
    Hobart Handler 120
    10FtDrillBit.com
  10. Likes AlabamaJoe, Capt B liked this post
  11. #10
    Sep 2008
    Dalton, GA
    My friend said exactly the same thing. Plus he said the ceiling mount has a condensate pump and other additional parts. Since they are $400-700 more, I’m going with the wall mount. It will be over a window, which is maybe not ideal, but is the only wall space I have on that wall.
    Burt
    Millermatic 211
    Hobart Handler 120
    10FtDrillBit.com
  12. #11
    Jun 2017
    AJO, ARIZONA
    Quote Originally Posted by Capt B View Post
    It sounds like you're planning on an inverter system, I put 2 on our house 2 summers ago, a 36000 with two air handlers and a 12000 single, you'll need 2 hots & ground, and a 4 wire from the condenser to the air handler, some include line sets and some don't.
    I bought SENVILLE from AMAZON & they've been great! The specs on the 36000 called for a 30 amp circuit, & the little one was a 15 amp. Our hose has never been as comfortable and as a bonus the power bill went down over 80 bucks a month on the equalizer plan. I think that covers it
    IMPEACH BIDEN!
    NRA LIFE MEMBER
    UNITWELD 175 AMP 3 IN1 DC
    MIDSTATES 300 AMP AC MACHINE
    GOD HELP AMERICA!
    ďFreedom is never more than one generation away from extinction.
    We didnít pass it to our children in the bloodstream".
    RONALD REAGAN
  13. Likes wb4rt, Capt B liked this post
  14. #12
    Sep 2016
    Detroit, Michigan
    Another vote for Mitsubishi....I have a Mr. Slim for my shop that's 30K AC and heat pump. It's a wall-mount and my ceilings are a bit over 13' so I put it up as hight as possible. It easily cools my shop that's 1,000 square feet, and the heat is only used in part of the year....I have a radiant floor heat setup for when it gets really cold and part of why I went with mounting the unit up high to work best for cooling.
    You almost can't hear the thing run, and they really don't use much electricity at all. I would buy another in a heartbeat!
    http://mivise.com
    Hobart Champion Elite
    Everlast PowerTig 210EXT
  15. Likes Capt B liked this post
  16. #13
    Sep 2008
    Dalton, GA
    Got the unit connected yesterday. Man, is it quiet. It only pulls 6-7 amps on high AC, so it should be cheap to run.
    Inside unit:
    Outside unit:
    Burt
    Millermatic 211
    Hobart Handler 120
    10FtDrillBit.com
  17. Likes G-ManBart, scsmith42, Capt B liked this post
  18. #14
    Sep 2016
    Detroit, Michigan
    That's almost exactly how I did mine and the metal liner panel color is even similar...lol. You're right...they are incredibly quiet and cheap to run. You are going to LOVE having that unit!
    I love walking in my shop on a hot day and realizing how comfortable it is, and the bonus is it really help prevent rust on bare metal.
    http://mivise.com
  19. Likes wb4rt liked this post
  20. #15
    Feb 2010
    Bandera,TX / MN
    Great topic, good info to know. Thanks!
  21. #16
    Dec 2016
    cover the lines with the split line cover kits so the foam lasts and helps with efficiency.
  22. Likes scsmith42 liked this post
  23. #17
    Sep 2008
    Dalton, GA
    Yes, I’m planning to cover the lines. Will bend up some aluminum to protect it.
    Burt
    Millermatic 211
    Hobart Handler 120
    10FtDrillBit.com
  24. #18
    Jun 2008
    Throw some more straps on the PVC conduit or it will sag, one of the things I dislike about exposed horizontal runs of PVC conduit is it's propensity to sag.
  25. Likes rhunt liked this post
  26. #19
    Mount Tabor VT
    Quote Originally Posted by Norcal01 View Post
    Within 3 feet of the boxes, not more than three feet apart.
  27. #20
    That should work out well for you. Mine is so quiet that you don't even know when it's running.
    Good clean installation too.
    Miller Suitcase MIG
    Lincoln 210MP
  28. #21
    Feb 2016
    Myrtle Beach
    Looks Great! I plan on doing the same hopefully soon.
    Lincoln 350MP
    Millermatic 350P
    Syncrowave 250
    1969 SA200
    HTP Invertig 221
  29. #22
    Feb 2016
    Myrtle Beach
    Just curious did the unit come precharged with refrigerant? I was reading that some do.
    Lincoln 350MP
    Millermatic 350P
    Syncrowave 250
    1969 SA200
    HTP Invertig 221
  30. #23
    Sep 2008
    Dalton, GA
    Yes, comes with Freon for up to 16’ (I think) line set but you need a tech to vacuum the lines after connecting. That’s why I had to have HVAC guy finish the connections. I hung the inside and outside units, cut the wall port for lines and wiring, and ran circuit to disconnect box. Only requires 15 amp, 220v circuit.
    So far I’m well pleased with it.
    BTW, I covered the outside line sets and added clips on the conduit as suggested above.
    Burt
    Millermatic 211
    Hobart Handler 120
    10FtDrillBit.com
  31. Likes Capt B liked this post
  32. #24
    Sep 2016
    Detroit, Michigan
    Another reason you want a licensed HVAC tech to do that step is that you void the warranty if you do that line hookup yourself (you probably know that).
    I did the same basic thing....had the outside unit, power disconnect, inside unit, etc all ready to go. The HVAC guys (we were doing two units in one day) were thrilled to have all that done for them, and since I was paying by the hour, it worked well for me.
    http://mivise.com
  33. Likes Capt B liked this post
Page generated in 1,624,061,154.70405 seconds with 13 queries
