Results 1 to 6 of 6
Thread: Lincoln Pro MiG 140 Dead
    Mar 2021
    Hi,
    I’m new and know little about what I am doing with a mig welder I bought on a whim some years ago at Lowe’s
    Sn M39806
    11173
    was working well but then sputtering and died.
    trigger is good
    wire feeds easily
    flux core .035
    no gas
    No spark at all now.
    connections are tight.
    and perhaps moist critically right in the middle of a honey do project.
    anything would be greatly appreciated
    Crobar
    Sebeka and Bemidji MN
    Re: Lincoln Pro MiG 140 Dead
    This will sound dumb, but I've seen the knobs on those get turned slightly off from the click point. Still feeds wire but no weld.
    If yours has continuous dials, then that doesn't apply...
    But, make sure your "ground clamp" is clamped on a bare ground down spot.
    If good contact is not made, no weld.
    Syncro 350
    Mar 2021
    Good clean contact point just a couple inches from weld point.
    new ground clamp.
    will check dials for good positioning as I do believe it is something odd like that.
    thanks for your response
    Crobar
    Mar 2021
    No go
    still no spark
    maybe I need to test components?
    Don’t know which is most likely to die first.
    Aug 2013
    Austell GA USA
    If you feel up to it. Below is something to get you started. See if you have power to the control board.
    Ceres, California
    Find a volt meter and connect it to the polarity studs. pull gun trigger. see if you have voltage at this point and your wire feeds. If so, short the gun tip to the work clamp while meter is still connected to the studs. pull trigger, if voltage does not change the miggun is open. If you don't want to take a chance on damaging the tip, feed out 6 inches of wire and put work clamp on the end. if gun good the wire will turn red.
    If you do not have voltage at the polarity studs you have a problem inside the welder case.
Page generated in 1,624,445,684.76016 seconds with 12 queries
