Results 1 to 8 of 8
Thread: Roughneck 1e
    Apr 2012
    Roughneck 1e
    Older roughneck 1E every thing works as it should except the 220 outlet has one leg at 125v (goes into rotor) and the one coming from the 120 outlet has 118v. any thoughts. Checked all the normal things,
    I don't understand why the one leg is higher than the rest.Thanks in advance
    Mar 2021
    Near Roanoke, VA
    Re: Roughneck 1e
    If you asked an electrical engineer about how that transformer on the pole splits the high voltage (like over seven thousand volts) into two low voltage lines, out of phase with each other,,,
    he would go on for a half an hour, then finally tell you that the two voltages being that close to 120 is good!!
    Mar 2015
    Milwaukee, WI
    Re: Roughneck 1e
    My Miller Roughneck 1E has a single duplex outlet on its face for 115VAC (nominal). I've never seen one with a higher voltage option for generator output.
    Mar 2015
    Milwaukee, WI
    Re: Roughneck 1e
    Quote Originally Posted by Denis G View Post
    Edit: I checked the schematic that I have and saw that there are two parallel generator windings and it is an option for some models. Sorry. My mistake.
    Apr 2012
    Re: Roughneck 1e
    Thanks for the response, I will have to tear into this thing. Any thoughts is appreciated. Did miller make a service manual for these things Have one for the trailblazer handy to have around.
    May 2008
    Orange, TX
    Re: Roughneck 1e
    I have a Roughneck 1 Technical Manual effective with SN R377879. PM me an email address and I can send it to you.
    MM200 w/Spoolmatic 1
    Syncrowave 180SD
    Bobcat 225G Plus - LP/NG
    MUTT Suitcase Wirefeeder
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    Apr 2012
    Re: Roughneck 1e
    PM sent
    May 2008
    Orange, TX
    Re: Roughneck 1e
    email sent Wednesday. Check your Junk Mail.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
Page generated in 1,623,920,971.70926 seconds with 11 queries
