Results 1 to 17 of 17
Thread: Nicked Propeller Repair
    Mar 2014
    Troy MI
    My friend and customer ran his boat in shallow water and the propeller hit the ground, which nicked the edge of the propeller. I have seen more damage when a propeller hit a branch in the water. The following four pictures show the damage to the propeller.
    1. Nicked propeller
    Name:  1. Nicked propeller.jpg
    2. Nick-1
    Name:  2. Nick-1.jpg
    3. Nick-2
    Name:  3. Nick-2.jpg
    4. Nick-3
    Name:  4. Nick-3.jpg
    The first step was to sand off the paint so that it wouldn’t contaminate the weld. I also sanded off the mushroomed Aluminum near the nick.
    5. Sanding paint off
    Name:  5.  Sanding paint off.jpg
    Smith Oxyacetylene Torch
    Miller Dynasty 200DX
    Lincoln SP-250 MIG Welder
    16" DuAll Saw
    15" Drill Press
    7" x 9" Swivel Head Horizontal Band Saw
    20 Ton Arbor Press
    Bridgeport
  2. Likes farmersammm, albrightree liked this post
  3. #2
    Mar 2014
    Troy MI
    Re: Nicked Propeller Repair
    I used a bar clamp to rigidly clamp the propeller to my welding table so that it wouldn’t move while I was working on it.
    6. Propeller clamped
    Name:  6. Propeller clamped.jpg
    I used a piece of copper to keep the weld from sagging.
    7. Propeller ready for welding
    Name:  7. Propeller  ready for welding.jpg
    Here are three pictures of my welds.
    8. First Welds
    Name:  8. First Welds.jpg
    9. Weld-2
    Name:  9. Weld-2.jpg
    10. Weld-3
    Name:  10. Weld-3.jpg
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
  4. Likes farmersammm, albrightree, N2 Welding liked this post
  5. #3
    Mar 2014
    Troy MI
    And here is my setup for grinding the welds.
    11. Welds ground down
    Name:  11. Welds ground down.jpg
    12. Close of one blade
    Name:  12. Close of one blade.jpg
    All finished and painted.
    13. Propeller all done and painted
    Name:  13. Propeller all done and painted.jpg
    -Don
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
  6. #4
    Sep 2012
    Wheatland, Wyoming
    Good to go I'd say. Nice repair.
    Chris
    Auction Addict
  7. #5
    Mar 2021
    Near Roanoke, VA
    Is there any way to get it rebalanced??
    I know there is a real high end mower blade balancer,, that would probably balance it,,
  8. #6
    Sebeka and Bemidji MN
    Looks like a nice repair - about what I would have done as well.
    I talked to a prop repair guy once (who had retired and sold his patterns) - he said he didn't balance them after repair.
    I always wondered how off balance one could be before causing vibration issues.
    They seem to run for years with unevenly weighted chunks out of them.
    Pure speculation, I guess welding to shape has to be better than that
  9. #7
    Mar 2014
    Troy MI
    I would guess if the original propeller was balanced the repaired one would be pretty good.
    My friend does plan on getting it balanced.
    -Don
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
  10. #8
    Mar 2014
    Troy MI
    I live in the suburbs of Detroit MI. We have a company called Harris that can balance anything from tiny very high speed Titanium bellcups for paint robots to large rotors that feed coal dust into power plants. Before I retired in July I used to regularly work on projects with them. I’m sure that they can balance a propeller.
    -Don
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
  11. #9
    Quote Originally Posted by Don52 View Post
    -Don
    I bet when they check it, it's pretty dang close already
  12. #10
    Dec 2003
    Fairfield,CT
    Nice job.
    www.tjsperformance.com
    Dynasty 300 DX
    HTP 240
    HTP Microcut 380
    Hyperthem 85
    Bpt. Mill/DRO
    4' x 8' CNC Plasma Table
    Instagram: tjsperformance
  13. #11
    NW New Jersey
    Great pictures !! thanks for posting. https://www.weldingweb.com/images/smilies/biggrin.gif
    Snap-On YA-212
    Lotos Cut60D
  14. #12
    Oct 2012
    Michigan
    If your buddy needs another source to get his prop balanced Proper Props in Wyandotte does great work. 734-764-2470
    Tim
    metalcraft by moose
    Southeast Michigan
    https://www.facebook.com/Metalcraftbymoose
    Stupid Hurts!!
  15. #13
    Mar 2008
    Georgetown, Texas
    That's a great looking repair job. A guy in Austin that repairs props uses a stick welder with aluminum rods for the aluminum props.
  16. #14
    Mar 2014
    Troy MI
    Quote Originally Posted by moose View Post
    Thanks, I’ll let him know.
    -Don
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
  17. #15
    Aug 2019
    northeastern PA.
    Nice job Don. What filler did you use?
  18. #16
    Mar 2014
    Troy MI
    Quote Originally Posted by BillE.Dee View Post
    Maxal 4943
    -Don
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
  19. #17
    its not if the prop is balanced, its the pitch, rake and cupping that you worry about on a prop. also excellent repair!!!! its how the prop "bites thru" the water.
    lincoln 125sp
    monkey wards 250 ac/dc
    miller 211 w/spool gun
    ahp 200 sx tig
    lotos ltp5000d
    of course duramax diesel
  20. Likes Mikel_24 liked this post
Page generated in 1,624,348,276.74058 seconds with 15 queries
